Old 07-02-2004, 08:35 AM   #1471
TeamButter's Avatar
Send a message via AIM to TeamButter
Josh- Cool!! Hope to see you down here.
LosiRob- LOL!!! We do ocassionaly work around here!! LOL (R/C Cars, Beaches, Sun, Boating,...)
Xray / BMI Racing / KO Propo / Team Epic / Parma-PSE / High Velocity Racing / TeamButter / P3 Graphics / MDI Racing
TeamButter is offline   Reply With Quote
Old 07-02-2004, 10:10 AM   #1472
new92's Avatar
Originally posted by TeamButter
Greg-We run a 19 turn class in 12th. Unfortunately it does not have that big of a following. We are primarlily a Touring Car state!! You thinking of coming down for that race?
Oval is the big thing in N Fl though. Its fun but cant touch touring. I wish there were more touring tracks closer by. With gas prices the way they are and driving a Chevy truck, well, alot of out of town races are hard lol.
new92 is offline   Reply With Quote
Old 07-03-2004, 09:58 AM   #1473
whynot's Avatar
Trader Rating: 18 (100%+)
Default Evolva
Josh,
When you set up your clutch on your Evolva do you shim it so that the clutch bell wont push down onto the clutch shoe.I was putting a couple of shims under the first bearing but it seemed to still be touching the clutch shoe,So I continued to put shims under the bearing until I noticed that it was spinning more free and not touching the clutch but It took about 1.5 mm of shims to keep it off the clutch.Is this how I should run it?And I am running a small amont of end play alsoI would say about .2-.4 mm in that area.And I tighten the clutch nut to about 1.25-1.3 mm.If you get a chance can look over this and tell me what you think.
thank you very much in advance. Hope to see you at the Great Lakes Challenge
mike
whynot is offline   Reply With Quote
Old 07-04-2004, 09:45 PM   #1474
Thanks for the info on the one way Josh it is much appreciated
sprint is offline   Reply With Quote
Old 07-04-2004, 09:59 PM   #1475
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
josh - we had a race yesterday at one of the local tracks. it was a nitro race with a bit of electric on the side. so by the end of the nitro day (3mains) we finished our electric mains unfortunatly the track was full of nitro gunk and foam residue it made the track kinda slippery when go off the racingline. at the first lap i got a good jump on the grid and led the race when at the end of the straight something happeded and all i know is that the car flew towards the fence and hit the perimiter fence sideways at when i was able to take good a look at the car it was CUT IN HALF. i was holding my half of my car in each hand. i really felt bad and hope that i never have to feel that way again. but "THATS RACING"
I GUESS I'LL JUST HAVE TO LOOK AT IS AS A TUITION FEE ON MY RACING 101 CLASS.
S-T-R-l-K-E-R is offline   Reply With Quote
Old 07-05-2004, 06:50 AM   #1476
rbboy's Avatar
Send a message via MSN to rbboy Send a message via Yahoo to rbboy
Default solid diff
josh: how would a solid rear diff drive feel on a G4 with a one-way infront? or a solid front diff w/ a rear differential drive? thanks for the set-up sheets you sent me...
www.xtremerchobbiesph.net
rbboy is offline   Reply With Quote
Old 07-05-2004, 09:48 AM   #1477
after an evening of wrenching i'm able to resurrect my fallen FK hope its just as dependable as before!!
here is a picture
reborn
Old 07-05-2004, 09:50 AM   #1478
another view
Old 07-05-2004, 09:50 AM   #1479
sorry made a mistake
Old 07-05-2004, 10:35 AM   #1480
etzkev's Avatar
Send a message via AIM to etzkev
Awww man striker! I want to see a pic of it when it was torn in half!
-Kevin
etzkev is offline   Reply With Quote
Old 07-05-2004, 11:15 PM   #1481
kev will do!!! as soon as i upload the pisc from my digi cam
Old 07-06-2004, 09:11 AM   #1482
etzkev's Avatar
Ok, sounds good!
Old 07-06-2004, 09:32 AM   #1483
rayhuang's Avatar
Josh,
Any word from Xray on a harder short arms and hard plastic c-hubs? I Think I want stiffer parts.
Thanks,
Ray
Old 07-06-2004, 09:50 AM   #1484
mtveten's Avatar
Trader Rating: 27 (100%+)
I am looking for a little help with the rear camberlink options on FK. Can someone please tell me how I would mount the camber link in either of the outer holes on the shock tower?
I am also noticing that most of team setups I am am seeing use the inner link postion ( shorter link) on the carrier, can someone please tell me what they have experieced when running the camber link in the outer postion on the hub?
Is anyone still using the rollcenter bridge, if so what do you gain with it?
Thanks,
Mark
mtveten is offline   Reply With Quote
Old 07-06-2004, 09:56 AM   #1485
Rob Mincey's Avatar
Well, if you're going to use the outer holes on the Factory car, you'll have to bevel the inside edges of the rear hubs so that the turnbuckles/camber links don't hit the top of the hub, limiting up travel. On my Evo2, I prefered the outer holes on the hubs due to the increased stability it provided. But, on the Factory car, I use the inner holes and have found that the inner holes with the short arms are as stable as the outer holes with the long arms.
I haven't used the roll center bridge, so I can't really give an opinion on that one, though.
Rob
Rob Mincey is offline   Reply With Quote
Josh Cyrul and T.O.P. Racing E.J. Evans Electric On-Road 18 11-29-2008 09:02 AM
josh cyrul at the 'birds b-man777 Electric On-Road 5 02-06-2008 09:23 AM
Josh Cyrul -> Novarossi rmdhawaii Nitro On-Road 11 09-20-2007 07:34 PM
josh cyrul and peak motors b-man777 Electric On-Road 43 02-15-2006 03:24 AM
Josh Cyrul on MTV2 teammediocre Chat Lounge 1 04-15-2005 05:46 PM
