Old 05-25-2004, 08:57 AM   #1336
rtypec's Avatar
Last year, they had assigned seating for the invite drivers under the patio looking thingy. The drawback is that the tables for the factory guys are a little smaller so it's more of a huddle. The tables under the big tent are unassigned and are much longer so you can really spread out.
rtypec is offline   Reply With Quote
Old 05-25-2004, 08:58 AM   #1337
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
Josh - Wish I could drive like you, than I wouldn't get so frustrated. Good luck at Reedy!
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 05-25-2004, 02:07 PM   #1338
lazyboy's Avatar
Send a message via AIM to lazyboy
Josh,
how would you compare the C12 CEFX to anyother 1/12 scale? and what is it like setting one up for someone that has never drivin a 1/12 scale before?
thanks lazyboy
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 05-25-2004, 07:10 PM   #1339
JDXray's Avatar
Send a message via AIM to JDXray
i have the same question, as lazyboy, but i have driven 1/12th, hehe
JDXray is offline   Reply With Quote
Old 05-26-2004, 12:25 AM   #1340
Josh Cyrul's Avatar
rtypec - Thanks for the info!!
John - lol... Thanks!!
lazyboy - The C12 is a lot different to drive than most other 1/12 cars. We've found the car to be extremely stable. The car just isn't nearly as twitchy around the initial steering input. The car also loves chicanes as it does not scrub speed when changing directions. The downfall has been the lack of steering into hairpins - once we achieve that then we fight with forward traction. Neither of these has been a problem in stock but it is definatly noticable in mod (we are testing to fix the problems!!). Setting the car up is much easier in my opinion. You use a set screw in each suspension arm to adjust the camber, you use another set screw to adjust the spring tension and then it's simply changing shims on the king pin to adjust the ride height. The rear end is similar to other cars so it's pretty basic....
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 05-26-2004, 05:43 AM   #1341
chicky03's Avatar
Send a message via AIM to chicky03
I got a chance to race the C12 at the snowbirds and finished second in stock with it. The car was great. A lot of people were traction rolling with other cars and I could not make the car traction roll if I wanted to. I would get to the turn and crank the wheel and the car just went around perfectly. I liked it a lot.
Paul
chicky03 is offline   Reply With Quote
Old 05-27-2004, 04:36 AM   #1342
PSI Racing's Avatar
Default Servos
Josh, I know I asked you awhile back about what servo you use for steering on your nitro touring car.
I just wanted to know if you ever used the 2343's for steering, and how do they compare with the 2344's?
Do you see a big difference between the speeds of the servos, or do you feel a bigger difference with the torque?
Also, what servo does Ralph Burch use in his nitro touring car?
PSI Racing is offline   Reply With Quote
Old 05-31-2004, 08:03 AM   #1343
Lonestar's Avatar
Josh,
thanks for your answer about my tire pressure Vs. roll question, and my apologies for taking so long to thank you... it's always nice to see world-class racers answering our questions.
So basically, the trick is to run as stiff a setup as possible, without the car hovering all over the place because of an overheated contact patch, due to high pressure, is that correct?
Thanks,
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 06-02-2004, 11:11 AM   #1344
Josh, what servo do you run?
aviaar is offline   Reply With Quote
Old 06-02-2004, 12:31 PM   #1345
Moderator
Pro ten Holland's Avatar
Default Question for Josh Cyrul
Hello Josh,
I contacted you about a while ago on the CEFX forum about this: have you looked into the possibility of running in the exhibitional 1/10th onroad (pro ten) class at the 2004 USA nat's?
It would be really cool if a big name like you would enter, especially with your own chassis! This could bring the class back in the spotlights again, where it should belong! (and it would help you sell 1/10th cars )
http://www.rc-lemans.de/
Pro ten Holland is offline   Reply With Quote
Old 06-02-2004, 01:38 PM   #1346
John Doucakis's Avatar
Default FRONT DIFFERENTIAL
Hi Josh,
This is John from Greece.
Please reply to the following question.
After watching a video from the recent 2004 Roar carpet nats which you dominated I was curious to see what did you use upfront, a spool, a diff or a oneway. To my surprise, I saw from some pics in the rctech.com coverage of the race, that you used a conventional differential upfront.
Is this correct and if so how come and you did not use a spool or a oneway, since any of the two last choices seem to be the favorite ones of most top drivers.
Personally I am a fan of using a differential upfront especially because it helps me to dive inside my competitors, brake late and still hit the apex of the turn just right where as with a oneway it would almost be impossible to brake late and with a spool the car would run far too wide in the entry of the turn.
Also do you adjust your diffs to be tight, having a "heavy" feel or are they as loose as possible, just enough so they do not slip under power.
Thanks for your valuable answer and I hope to see you again at the Worlds in October!
John Doucakis is offline   Reply With Quote
Old 06-02-2004, 03:32 PM   #1347
Neil Rabara's Avatar
Hey Josh
I didn't get a chance to introduce myself at the Reedy Race, but we did get to talk about set up on sway bars.
Neil Rabara is offline   Reply With Quote
Old 06-02-2004, 04:26 PM   #1348
Josh Cyrul's Avatar
PSI Racing - I prefer the higher torque in my gas cars. I used to always choose the speed for the steering but after I tested a few different servos I then opted for the high torque as I liked the feel - less twitchy off center but it did seem to have more steering in the higher speed (higher load) corners. I'm not sure what Ralph uses...
Lonestar - Pretty much.
aviaar - In what class??
Pro ten Holland - To be honest it would depend on the rules, I don't think they should be 6 cell anymore and I don't think they should follow the same dimensions as the old cars (width, lenght or body style). The old cars were much too fast and too big for the tracks we were trying to race them on. I would like to see the class come back but there would have to be many changes....
John - On high traction carpet nearly all drivers choose the front differential. The spool and one-way are just too difficult to drive and do not yeild a much better lap time to make them nessisary. I do adjust the differential according to how much steering into the corner vs. on-throttle steering that I need. Usually my front diff is a bit heavy vs the rear that is only set tight enough so it does not slip.
Neil - Make sure you do next time!! I meet so many people it's hard to keep up!!!
Old 06-02-2004, 04:50 PM   #1349
The Evicerator
Josh, Did you figure out why everyone hates me yet? Thanks again
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 06-02-2004, 04:55 PM   #1350
Sorry Josh, I meant in your Xray Touring car.....I see something above about servos, but I'm not sure that's in your Xray.
Josh Cyrul and T.O.P. Racing E.J. Evans Electric On-Road 18 11-29-2008 09:02 AM
josh cyrul at the 'birds b-man777 Electric On-Road 5 02-06-2008 09:23 AM
Josh Cyrul -> Novarossi rmdhawaii Nitro On-Road 11 09-20-2007 07:34 PM
josh cyrul and peak motors b-man777 Electric On-Road 43 02-15-2006 03:24 AM
Josh Cyrul on MTV2 teammediocre Chat Lounge 1 04-15-2005 05:46 PM
