Old 05-12-2004, 07:20 PM   #1306
rayhuang's Avatar
Default Xray
Josh,
I ran my new Xray for a pack tonight and was in need of more on-power steering. Basically all on exit. Maybe a tad less off-power.
I used your Nats set-up except I didnt have time to shorten the front camber link. I am in middle bottom.
I aslo double checked the set-up to make sure I wasnt too different on anything else besides the front camber link and I was. I had more rear uptravel (3mm), more rear toe-in (2 degrees) and softer rear spring (Blue).
For more-on power and less off-power in stock-would you shoot me one or two things to try please?
Also-would you elaborate on rear diff setting of free?
Thanks,
Ray
Old 05-13-2004, 02:18 AM   #1307
Default TC3 vs. X-ray
Josh,
I recently switched from a TC3 to a X-ray FT, and I was wondering whether you noticed the same difference I did.
The Xray seems to respond a lot slower than the TC3 does, this makes the Xray a lot more stable and easier to drive.
It does make me believe the TC3 should be faster on tight circuits.
Do you have any opinions on this or any setup suggestion?
vassago is offline   Reply With Quote
Old 05-13-2004, 11:29 AM   #1308
rayhuang's Avatar
Josh,
You know I am thinking about my last post and everything thats different on my car than yours would lead to less steering on exit-so I guess I answered my own Q.
Ray
Old 05-13-2004, 11:54 AM   #1309
Ray,
Did you notice on Josh's nats setup that he used stiffer rear springs than front? Unless I looked at the spring colors wrong.
Ozwald Bates is offline   Reply With Quote
Old 05-13-2004, 12:54 PM   #1310
Josh,
My Radio Shack Radio Control '58 Impala Low-Rider Won't go fast enough go beat my neighbor's Meijer RC Turbo Hopper. What can I do to make it faster?
Unregistered is offline   Reply With Quote
Old 05-13-2004, 12:55 PM   #1311
rayhuang's Avatar
Originally posted by Unregistered
Josh,
My Radio Shack Radio Control '58 Impala Low-Rider Won't go fast enout go beat my neighbor's Meijer RC Turbo Hopper. What can I do to make it faster?
Your so weird!!!
Old 05-13-2004, 12:57 PM   #1312
JDXray's Avatar
Send a message via AIM to JDXray
LOL
JDXray is offline   Reply With Quote
Old 05-13-2004, 03:18 PM   #1313
PizzaDude's Avatar
Does anyone know how the XRAY springs compare to the Asso ones?
How do they rate/compare?
Regards,
Pizza
PizzaDude is offline   Reply With Quote
Old 05-16-2004, 11:15 AM   #1314
Josh Cyrul's Avatar
Aaron - Hmm, he must have kept it for himself!!
littledog - Nope..
Ozwald - I like running very light dampening. What shock positions are you running? Try stiffer springs (more like my carpet nats set-up)...
Chill Will - I did it to gain reaction and steering into the corner and through chicanes...
Ray - Everything that you have different from my set-up will make the car push more on-throttle and turn in harder off-throttle... droop, toe, spring, camber link....
vassago - Just because a car "feels" faster doesn't always mean that it is. This is one of the things I love about my Xray car right now - it's easier to put on a more aggressive set-up to get the corner speed like I want without it being impossible to drive. I don't think the TC3 is faster on a tighter track - I think that was proved at the Carpet Nats....
Ozwald - You did look at the colors wrong...lol.. I was one step softer in the rear...
PizzaDude - If Xray's are 30lbs and Asc's are 30lbs the Xrays are softer... Depends how you look at it - Xrays are 2-3lbs off to the soft side or Asc's are off 2-3lbs to the stiff side....
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 05-16-2004, 11:17 AM   #1315
Thanks a lot Josh, great to see people like you taking time to answer questions.
Old 05-16-2004, 11:19 AM   #1316
JDXray's Avatar
Josh you think upgrading from a Xray t1R to a Factory kit or Evo 2, is a good change? Or should i just stay with the T1R.
Also
Have you tried any other body top instead of the Alfa? And which do you prefere.
Old 05-17-2004, 07:25 AM   #1317
rayhuang's Avatar
Thanks as always and great job at Warm-up. Looks like you and Burch and the rest of the Xray camp are getting the CS27's figured out. Glad to see you were running the Alfa outdoors too.
Ive made all the changes to the XRay for next practice day.
Old 05-17-2004, 08:20 AM   #1318
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Regards,
Pizza
Check this out too
http://www.rcingreece.com/index.asp?...rison&super=38
Nick
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
Team Xray T4'17, Team Xray X10'18, TOP Racing Rebel
nnick is offline   Reply With Quote
Old 05-17-2004, 09:50 AM   #1319
Josh,
I'm running the adjustable pistons per the instructions. Are you using the fixed pistons?
Old 05-17-2004, 01:20 PM   #1320
blr
Default Two questions
Hi Josh,
Two questions:
First, can you give me some starting points on gearing for Xray T1FK with a 10x1, 19t, and a stock motor?
Second, how does droop affect the Xray? Does letting the front arms droop more decrease the amount of steering coming out of the corner?
Thanks,
Brad
blr is offline   Reply With Quote
Josh Cyrul and T.O.P. Racing E.J. Evans Electric On-Road 18 11-29-2008 09:02 AM
josh cyrul at the 'birds b-man777 Electric On-Road 5 02-06-2008 09:23 AM
Josh Cyrul -> Novarossi rmdhawaii Nitro On-Road 11 09-20-2007 07:34 PM
josh cyrul and peak motors b-man777 Electric On-Road 43 02-15-2006 03:24 AM
Josh Cyrul on MTV2 teammediocre Chat Lounge 1 04-15-2005 05:46 PM
