Old 04-05-2004, 02:40 PM   #1246
Kropy's Avatar
Send a message via AIM to Kropy
Greg, how about ask the Super Freak
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline   Reply With Quote
Old 04-05-2004, 02:50 PM   #1247
Hi Josh,
What is the best tire additive to use with Sorex 28R or 32R.
Which inserts???
When do you use soft wheels?? hard wheels??
Thanks and congratulation for your victory,
Hugo
Hugo is offline   Reply With Quote
Old 04-05-2004, 07:30 PM   #1248
rayhuang's Avatar
Josh-Congrats on the win at the Gate-unbeatable that day!!! Wow!!
What tracks were you planning on testing 1/10th electric on rubber tires for the Worlds in Kissimee?
Do you know of any tracks in the summer that have weeknight or Saturday afternoon racing on asphalt in Detroit to Toledo area?
Old 04-06-2004, 06:16 AM   #1249
RandyB's Avatar
Hey Ray Hobbystop west will have parking lot racing this summer in their new location held on saturday afternoons.
woooo hoooo
RandyB
RandyB is offline   Reply With Quote
Old 04-06-2004, 06:56 AM   #1250
Randy... More info please!!!!!
JC, ygm...
Currently taking a break from R/C, running 1/1 scale cars, they are cheaper then running Modified TC!!!
retired from RC in 2007, running 1:1 scale now
[email protected]
Greg Anthony is offline   Reply With Quote
Old 04-06-2004, 09:27 AM   #1251
rayhuang's Avatar
woooo hoooo
RandyB
Excellent news. Saturday afternoon is much better for me than Sunday!!!
Old 04-06-2004, 04:28 PM   #1252
Send a message via Yahoo to nomaak
hey josh, i was going thru some older pictures from rc tech race results. and i saw some from your tc3 days. at this particular carpet race you had losi xxx-s shock towers on a tc3. and the tc3's were using rear shock towers on the front. what does all this do? and will you graph it onto the x-ray? 'cuase on my chassis (T1) the shocks lean at a more inclined angle than the other cars. plus if i use the outer- most mounts on the a-arm....the shocks seem to almost lay down.
thank you (or any other pro) for your help.
nomaak is offline   Reply With Quote
Old 04-06-2004, 04:41 PM   #1253
stefan's Avatar
Send a message via AIM to stefan
Originally posted by NitroHead
Nice to see some other Beemaa owners here!
Im trading one of my X5's for a 745li Friday 4/2/04 and I've placed my order for a triple black 4.8l X5. Should be here in eight weeks or so...
Good job, gives me job security and mo' money
stefan is offline   Reply With Quote
Old 04-06-2004, 07:46 PM   #1254
whynot's Avatar
Trader Rating: 18 (100%+)
Unhappy Evolva
Josh
I am having a problem with the rear suspension on my evolva when I push down on the chassi to work the rear shocks it seems that as soon as the shocks start to compress all the pressure is already pulling on the rear body mount making it bow and not giving me a smooth working of the shocks please help. thank you in advance.
mike wannett if you have any tips on set up or cluch
settings please let me know,thanks
whynot is offline   Reply With Quote
Old 04-06-2004, 07:52 PM   #1255
RandyB's Avatar
I will dall the stop and get some info for yall tomorrow
Old 04-07-2004, 08:26 AM   #1256
Josh Cyrul's Avatar
PSI - I use the new KO servos - 2344 - lots of torque and plenty fast enough for gas racing!!
Hugo - I'm not a big rubber tire person but I would say that most of it depends on the track and temperatures that you race under. As far as I know the best additive has been Paragon (not the ground effects but their other type). In some cases (especially on asphalt or high temps) no tire traction is needed!! Rims, usually soft if I need traction - hard if I need to take traction away....
Ray - I will be racing all rubber tires now until we go back indoors in late October!!! Where I'm not sure yet!!
nomaak - I just wanted to try a more vertical shock layout on my TC3 - it usually took away traction - perfect for big races like the Snowbirds where traction rolling is a big problem. If you use Xray's short a-arms and foam tire front shock tower you can set the shocks up at nearly the same angles that I used on my TC3 - no extra's need to be made or drilled!!
whynot - Check that you assembled everything correctly... If you can take some pics and post them so I can check it out....
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 04-07-2004, 08:35 AM   #1257
RandyB's Avatar
Josh you should check out lazer seedway while its no the most technical track around its big and its not a parking lot
Old 04-07-2004, 03:55 PM   #1258
so i guess i wont need those mods for blacktop, huh?
Old 04-07-2004, 09:14 PM   #1259
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Josh, what KO servo did you use in your oval cars down in Florida?
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 04-07-2004, 10:22 PM   #1260
Trader Rating: 14 (100%+)
Josh,
congrats on your run at the Gate. you were in a class by yourself. I downloaded the A mains and your Xray was flying.
I was lurking around and saw you have a Subaru?????? if so what all have you done to it?????? I'm trying to talk my dad into getting one as his truck is killing him on gas....... and I want something fun to drive too any pics???????
I was wondering how your car felt with short arms. mine still has the long arms on it but with a different chassis (batteries moved ahead and in) it felt a little slow in the corners. (3 degree caster blocks and a sway bar) but for a belt drive car it was good. (too used to the shaft drive cars).
anyway good luck racing onroad this summer.
I'm going Karting instead!!!!!!!!!!!!!!!!!!!
Jason XLB
Insane_Biffer
Team Tekin, KoPropo, Power Push Batteries, Tempgun.com
PROTECT ME FROM THE THINGS I WANT.
THAT WHICH FEEDS ME DESTROYS ME.
Life is short - live it! Your only old when your dreams are replaced by regrets.
TimXLB is offline   Reply With Quote
Josh Cyrul and T.O.P. Racing E.J. Evans Electric On-Road 18 11-29-2008 09:02 AM
josh cyrul at the 'birds b-man777 Electric On-Road 5 02-06-2008 09:23 AM
Josh Cyrul -> Novarossi rmdhawaii Nitro On-Road 11 09-20-2007 07:34 PM
josh cyrul and peak motors b-man777 Electric On-Road 43 02-15-2006 03:24 AM
Josh Cyrul on MTV2 teammediocre Chat Lounge 1 04-15-2005 05:46 PM
