Old 02-21-2004, 02:30 AM   #1081
"Only unasked questions are stupid..."
CEFX ... Cyrul Engineering FX
www.cefx.net
Stuff that Josh Cyrul designs/makes...
Alfalfameister is offline   Reply With Quote
Old 02-21-2004, 06:06 AM   #1082
Kropy's Avatar
Send a message via AIM to Kropy
Doug, a CEFX body is a body that Josh designed and manufacturs contact your local hobby store for avalibilty. I know Honda House in Chatem has them in stock.
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline   Reply With Quote
Old 02-21-2004, 06:32 AM   #1083
F1Junkie's Avatar
R/C Tech Charter Subscriber
Default New Body???????
Hi -
I saw this on the RC Tech site and was wondering if it is coming to production anytime soon...
Anyone with other info on the body?
Thanks in advance
Dave
http://rctech.net/events/snowbirds20...r_atomic_2.jpg
F1Junkie is offline   Reply With Quote
Old 02-21-2004, 07:31 AM   #1084
sands's Avatar
KT hobbies has them as well. (i think)
sands is offline   Reply With Quote
Old 02-21-2004, 09:09 PM   #1085
Jeff Brown's Avatar
Josh....
If the bowling alley changes the oil on the lanes from 3/4 to about 2/3.... how many boards do you usually adjust to the left or right on your approach to make up for it? Thanks!!!
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 02-22-2004, 01:34 AM   #1086
Exclamation
No way.... Josh...You friggin BOWL too???
NitroHead is offline   Reply With Quote
Old 02-22-2004, 09:12 AM   #1087
EddieO's Avatar
Just, curious when the new 1/10th scale car will be out and if there will be a conversion to turn it into a 235mm onroad car? The class seems to be taking off all over....
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
Old 02-22-2004, 10:25 AM   #1088
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Josh, I am going to assume you are getting back up to speed with orders? Thanks.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-22-2004, 03:40 PM   #1089
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
Originally posted by Josh Cyrul
trackdesigner71 - For what car??
sands - You car is extremely stiff!! I've never even tried the car like that!! Especially on the shock oil!! I run Asc 30wt in the rear and Asc 50wt in the front with the standard pistions (4 holes)!! Usually, softer set-ups are easier to drive and are more consitant. You have to remember - it is a TC and not a pan car - it is going to have some body roll.
doug - I currently use my CEFX 1/12 body, I run a Protoform Alpha on my TC, Delta Lola on my 1/8... Any classes you want to know other than those?
futureal - Yep.. still kickin!!
stefan - Thanks for the kind words and support on mytsn!! Also, thanks for the new contact!! I'm curious to do a bit of testing!!
429racer - Use lighter front shock oil, shorter front camber link.
Ray - The ackerman mod was to give more highspeed steering. It actually gives the car less ackerman.
TRL - I ran the exact same set-up from the Novak Race in Wisconsin. I still choose double pinks... I had bad luck in qualifying but if you take the several crashes with traffic out of my qualifier then I would have been 2nd or 3rd qualifier... I thought my car was extremely good... The CEFX car is delayed do to a few issues but I am doing all I can to get it out asap!!
Brian - Those were prototypes. I have a really good baseline now as to what I'm going to do to those cars to make production kits in the future... Those will come more towards the end of the summer (I think)...
peter - Just go to www.cefx.net and use the contact page. Write your question there and I will get it and reply.
CRASH - Are you running long wheel base? Did you grind off enough material?? We cut probably .125 off the a-arm....
nnick - The 1/12 body is already out as well as the body mask kits. We have a bunch of new products comming in the next 1-2 months so keep an eye out on our site - www.cefx.net
Oh and Josh You got mail
trackdesigner71 is offline   Reply With Quote
Old 02-22-2004, 06:13 PM   #1090
sands's Avatar
Default setup
I tried a softer setup with 33lb rear and 22.5 lb front springs. Also went to 60 front and 35 rear oils (all I had in oils) with no holes blocked
It pushed a little on corner entry so I shortened the front camber link a hole and it hooked up.
Felt the same as before when everything was working, but was more consistent in the race.
Thanks for the advice!
BTW, have you tried to tilt the front arms down ~3* with 6* caster blocks? It made a huge impovement in power off transition. - Not like you don't know what your talking about anyway!
Old 02-22-2004, 07:45 PM   #1091
teammediocre's Avatar
So when are those sick a$$ 1/8 scale bodies gonna be available?
teammediocre is offline   Reply With Quote
Old 02-22-2004, 09:16 PM   #1092
KMW
KMW's Avatar
The 1/8th scale bodies are available through Delta Inc., part nos. 12969 or 12971 (3 pack):
http://www.deltainc-usa.com/deltahopupsproceed1.htm
KMW is offline   Reply With Quote
Old 02-22-2004, 10:17 PM   #1093
Default CANADA
Josh
Thanks for the reply
Do u ever come up to Canada and race? , If u do, u should come to the http://68.151.50.95/Invitational/// Assfault invitational. its in edmonton.
Doug
Cheers.
Doug Smith
RC America - X-ray - Hudy - Motive
doug smith is offline   Reply With Quote
Old 02-23-2004, 09:23 AM   #1094
Josh Cyrul's Avatar
Greg - Umm, I dunno...lol.. I've had lots of e-mails lately...
Scott - Thanks!!
trackdesigner71 - It's been a long time...lol.. I just remember thick t-bar, .020 front springs, 3 degrees camber, 2 degrees castor, asc diff grease on the dampners....
CRASH - Yep, definatly have to drill the hole deeper!!
Matt04 - All of the Xray team has tested the al. vs plastic. We all like the plastic shocks better so that may be the reason....
F1junkie - That is CEFX's C-LMP675. I want to test with it a bit more (especially wing configurations) but hopefully we can have it out in a few months.
Josh Cyrul is offline   Reply With Quote
Old 02-23-2004, 09:30 AM   #1095
Josh Cyrul's Avatar
Jeff - If it's goes from 3/4 (75%) oil to 2/3 (66%) oil then I would probably move my feet 2-4 boards to the left and throw the ball out 1-2 board farther to the right. This allows for the drier lane conditions and more hook...lol...
NitroHead - A lot of the r/c guys bowl!! Kinwald, Baker, Burch, Scott, Wynn, and even Hodge sometimes!!
EddieO - No 1/10 car here (especially not a 235mm car)... I may make a 1/10 oval car but not without more testing...
Kraig - Yep, did you have an order in that I missed?? Things have been crazy so e-mail me and let me know!!
sands - Good to hear.. I haven't tried running kick-up or anti-dive in my TC yet... I'll get to that next time I go testing....
doug - Nice track!! I'll keep the race in mind, just ask me again more towards the May/June time....
Josh Cyrul and T.O.P. Racing E.J. Evans Electric On-Road 18 11-29-2008 09:02 AM
josh cyrul at the 'birds b-man777 Electric On-Road 5 02-06-2008 09:23 AM
Josh Cyrul -> Novarossi rmdhawaii Nitro On-Road 11 09-20-2007 07:34 PM
josh cyrul and peak motors b-man777 Electric On-Road 43 02-15-2006 03:24 AM
Josh Cyrul on MTV2 teammediocre Chat Lounge 1 04-15-2005 05:46 PM
