Old 01-31-2004, 01:03 AM   #1021
SpeedTech's Avatar
Originally posted by Josh Cyrul
Speedie - Thanks!
SpeedTech - Sorry, much has come up... I will get back to you soon...
elvo - Thanks for the info..
Hi Josh,
Thank you very much, look forward to receiving information regarding your products.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 01-31-2004, 10:43 PM   #1022
Best of luck J!!!
May you ROAST them at the birds!
Then SMOKE them at the Fort!!!
NitroHead is offline   Reply With Quote
Old 02-01-2004, 10:07 AM   #1023
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
Hey Josh you think I could have your base 12th scale stock setup?
trackdesigner71 is offline   Reply With Quote
Old 02-01-2004, 04:28 PM   #1024
THeGame's Avatar
Send a message via AIM to THeGame
Default Josh
What servo would you recommend for running 12th scale using the EX-10 Helios. I looking for something Digital.
Good luck at the snow birds..
THeGame is offline   Reply With Quote
Old 02-01-2004, 04:59 PM   #1025
David Joor's Avatar
R/C Tech Charter Subscriber
Default Re: Josh
I can tell you what Josh would say
He would suggest the KO PDS-947 FET, it was the only 12th scale digital servo by them for years, but they just came out with a new ICS version that is programmable, PDS-949 ICS
http://www.kopropo.com/servos.htm
Avid Racing Concepts LLC.
http://www.avidrc.com
AE | Reedy | KO | Tekin | Powermaster | Avid | Upgrade | BCE | Paint by Smiley
David Joor is offline   Reply With Quote
Old 02-01-2004, 10:12 PM   #1026
THeGame's Avatar
Default David Joor
thanks .. whats up with the FET ? .. Can I use that with a GT7..?'
witch servo for the sedan ?
Old 02-02-2004, 02:58 AM   #1027
David Joor's Avatar
2343 for sedan, I assume that you can use the FET with GT-7 since it is the only KO servo for 12th.
Old 02-02-2004, 07:15 AM   #1028
johnbull's Avatar
HAPPY BIRTHDAY JOSH.
Regards
Joe And Josh Anastasi,
JOHN BULL RACING. MALTA.
johnbull is offline   Reply With Quote
Old 02-03-2004, 09:03 PM   #1029
sands's Avatar
Default Setup question
There are a bunch of us at my track that run xrays. My setup seems to be the stiffest with 38lbs front and 28 lb rear springs 50wt front with all holes closed and 40wt rear with 2 clicks on the shocks. Camber links are middle bottom on the front and lower inside rear (camber bridge).
Other guys run essentially the stock setup, maybe a little stiffer. I didn't like it because the car really leaned into the corners and came close the traction rolling.
Is this a driving style thing or is there a benefit to running a softer setup with more angled and shorter camber links? When my car is working (not consistent, still learning TCs on carpet. 1st season in about 10 years... used to run 1/10 pan car) I can turn within 2 laps of TQ and show in the A main.
BTW, I think I'm getting close to a consistent, easy to drive setup - or is a stiffer setup less forgiving to driving line / smoothness errors?
The car's symptoms are a corner entry oversteer if I'm not ultra smooth going to power off .
Realize your in Florida right now. I tried moving the left set of cells up one spot on the chassis and that helped a lot.
Same question though: is a stiffer setup less forgiving to drive? In your experience, which has better corner speed, assuming a balanced setup?
sands is offline   Reply With Quote
Old 02-05-2004, 04:22 AM   #1030
Send a message via ICQ to elvo
Default C12 Anti-roll bar effect
Josh,
on the CEFX C12, is there a way to adjust the anti-roll bar effect of the front end? Something like put small spacers under the front mounting holes of the spring plate maybe?
BTW: Love the C12 already.
elvo is offline   Reply With Quote
Old 02-05-2004, 01:19 PM   #1031
mcsquish's Avatar
Default Servo
Since Josh is having fun where it is warm, yes you can use them with the GT7. The FET is internal and you do not use the extra wire from your speed controler. FYI Angel, it is 28 deg.
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Never argue with an idiot, they'll just drag you down to their level and beat you with experience.
Dirt Burners Racing - R.I.P. BB / Kolors by Kropy / CEFX / One Eighth Racers
mcsquish is offline   Reply With Quote
Old 02-07-2004, 07:32 AM   #1032
Kropy's Avatar
Send a message via AIM to Kropy
Josh, Good luck at the birds
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline   Reply With Quote
Old 02-08-2004, 03:43 PM   #1033
gijoe64's Avatar
Trader Rating: 30 (100%+)
Hello, Josh
I am starting a new class at my local track 1/10 GTP pan. I wanted to know why this class went the way of the Dodo Bird. Their
are some fast guys at my track and more racers are looking for cars. Just wanted to know what you think about this class, and
if you ever raced 1/10 pan.
gijoe64 is offline   Reply With Quote
Old 02-08-2004, 03:50 PM   #1034
gijoe64
That's a great class that died.We tried to revive it here in florida a few years ago only to have people in our series screw it up.We had limited success by having a 4 cell stock or 19t with 200mm touring car bodies on narrow pan chassis. It worked great until the others wanted 6 cell and unlimited motors. I heard from someone in Calif. that they have three heats of them every week at one track.
BullFrog is offline   Reply With Quote
Old 02-08-2004, 04:29 PM   #1035
gijoe64's Avatar
Thank for the reply, I love it. It's faster than TC and just as fun as 1/12. I know in Japan it
is becoming very popular again. and some guys are using GTP bodies on Touring Cars.
Josh Cyrul and T.O.P. Racing E.J. Evans Electric On-Road 18 11-29-2008 09:02 AM
josh cyrul at the 'birds b-man777 Electric On-Road 5 02-06-2008 09:23 AM
Josh Cyrul -> Novarossi rmdhawaii Nitro On-Road 11 09-20-2007 07:34 PM
josh cyrul and peak motors b-man777 Electric On-Road 43 02-15-2006 03:24 AM
Josh Cyrul on MTV2 teammediocre Chat Lounge 1 04-15-2005 05:46 PM
