Old 01-21-2004, 08:02 AM   #961
theisgroup's Avatar
antoniop: look up. siz posts back are the part numbers for the short arms front and rear
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 01-21-2004, 08:09 AM   #962
antoniop's Avatar
ooops oh my.
antoniop is offline   Reply With Quote
Old 01-21-2004, 10:16 AM   #963
JCB
JCB's Avatar
Default Short Arms...
Hey Josh,
Ok, I'm going to install the short arms on my EVO2. Do I need anything else to do this? Also, I'm running the blade type sway bar in the front. Can I still use this or do I have to switch to the wire type bar? Any help/instructions would be appreciated.
Thanx,
JCB is offline   Reply With Quote
Old 01-21-2004, 10:23 AM   #964
jc510's Avatar
Hey Josh,
How do you break in your diff's on your 1/12?
When will the Forum on your site be back up?
jc510 is offline   Reply With Quote
Old 01-21-2004, 10:30 AM   #965
Send a message via AIM to miniRMAC
Default greenthing
what are those green mini battery thing on your 1/12th scale
miniRMAC is offline   Reply With Quote
Old 01-21-2004, 10:50 AM   #966
antoniop's Avatar
ooops oh my.
Old 01-21-2004, 01:34 PM   #967
Tim Stamper's Avatar
Default Re: greenthing
I haven't seen the pics but i'm guessing he is using the 1/4AAA cells like the ones for $2.00 a pop that Hank sells on hobbytalk.
I think that he uses 6 cells so he can get 7.2v to his electronics. I recently stepped up to 6 cells and that little KO-947 really flies now.
They are 150Mah Nimh cells.
I had been using a 6.0v pack for over a year now and it really help out in keeping the voltage up for my servo so the car doesn't get sluggish.
Hope that helps.
Tim
This space for rent
Tim Stamper is offline   Reply With Quote
Old 01-21-2004, 02:24 PM   #968
David Joor's Avatar
R/C Tech Charter Subscriber
What sort of problem are you having with the forum? If the site is different looking (has the huge C12 Ad at the top) than you are on my server and the forum is functional as far as I have tested. The forum is still functional as well on the older site but the posts just won't be carried over.
Basically the site is moving to a new server and new design, I was kept all the login information and posts, but DNS may take as much as 72 hours before users see the new site. If that is the case, all posts on the old site will no be on the new one once the shift is complete.
Avid Racing Concepts LLC.
http://www.avidrc.com
AE | Reedy | KO | Tekin | Powermaster | Avid | Upgrade | BCE | Paint by Smiley
David Joor is offline   Reply With Quote
Old 01-21-2004, 07:43 PM   #969
David Joor's Avatar
Default Forum Problems
I fixed the forum for those getting the theme error, please let me know here if you still have a problem.
Old 01-22-2004, 10:44 AM   #970
Josh Cyrul's Avatar
Neil - I used a dremal. I did cut the rear pulley too but when racing mod I was having trouble and actually broke 2 belts.... It just was too much for mod....
429racer - When I've tested I found it to make a big difference in corner speed in stock!! You will loose a little bit of low speed steering but I think the car set-up is easily adjusted to get it back.
SalvadoriRacing - I saw the e-mail, just haven't had time to reply!! Thank you though and I will be sending you questions soon!! With the ackerman I like running 2 degrees of toe-out (total - 1 degree per side). With the origional Xray steering when you ran this toe-out then you had tons of ackerman. With the extensions you have minimal ackerman but still with the toe out I like...
dontfeelcold - I think the belt cars have come a long way and I do think at the Snowbirds it will be a great race. My Xray car now is extremely good and we've been able to test a lot of motor stuff since the Novak race. Let's just say I'm anxious to get down there!!
JCB - You might have to dremal the front mount by the servo a little. I think it depends on the servo though!! As far as the sway bar - yes, you have to use the wire type - the blade doesn't fit...
miniRMAC - That's the reciever pack - it runs the servo and radio gear so all of your main battery power goes to the motor..
David Joor - The site rocks!! You da man!!
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 01-22-2004, 10:53 AM   #971
rayhuang's Avatar
Josh-Are you coming down to the Gate pre-Snowbirds (ie this weekend or next)? Weve had a pretty good 19t foam class lately.
My big question is on Foam tires. Is there a point when the traction gets so highon carpet-that its advantageous to go to softer foams? LIke from plaid/purple to cyan/magenta (orange-dbl pink/dbl. pink)?
Old 01-22-2004, 10:54 AM   #972
JCB
JCB's Avatar
Hey Josh,
Thanks again for the info. FYI, I run the KO-2173 servo. So other than changing my front sway bar, is that all?
Also, I just bought you one your 1/12 bodies for my RC12L3 but had problems when mounting the body. It sits up way too high and there is no way of me lowering it. It starts to hit my ESC. I guess I will hold on to it when I purchase a new 1/12 car. Not sure what I'm getting yet. I did get a glimpse of your car at Cleveland, but not when it will be available. Thanks again and good luck at the Birds!!
Old 01-22-2004, 11:33 AM   #973
Default Losi shock tower
Hey Josh
I was just wonder how you got the losi shock tower to fit on your TC3. Also Did u run a NTC3 steering rack in ur car.? Any help would be greatly appreciated.
DoN
ADDRacer36 is offline   Reply With Quote
Old 01-22-2004, 11:42 AM   #974
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
hello josh......
The new CEFX website design is wonderful!!!
I'm planing to free up my transmission, but instead of cut the diff pulley tooth I'll try to run narrower belts.
The original belts are 4mm width and I'll try 2 and 3mm width, what do you think and recommend?????
thanxxx.....
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 01-22-2004, 12:15 PM   #975
pucho's Avatar
Send a message via AIM to pucho
Hey Josh,
For Official Pre-birds practice and warm-up go to our site
www.rpmspeedway.com
pucho is offline   Reply With Quote
Josh Cyrul and T.O.P. Racing E.J. Evans Electric On-Road 18 11-29-2008 09:02 AM
josh cyrul at the 'birds b-man777 Electric On-Road 5 02-06-2008 09:23 AM
Josh Cyrul -> Novarossi rmdhawaii Nitro On-Road 11 09-20-2007 07:34 PM
josh cyrul and peak motors b-man777 Electric On-Road 43 02-15-2006 03:24 AM
Josh Cyrul on MTV2 teammediocre Chat Lounge 1 04-15-2005 05:46 PM
