Old 01-14-2004, 07:29 PM   #916
JoshR 85's Avatar
HeY hEy!!!
Hey Josh wassup??? nice to see you at Trackside, and to bad that you didn't get to race mike blackstock at the end because the car was caught at the sweeper and made ya go wide and loose.... o-well i geuss but you had a great race though. I noticed that you were talkin to someone that you kept smoking ur diffs thurs. and also i think once wed. would you happoen to know if you'll be back up for the 4th leg of the UCTC (Feb. 27-29)???
JoshR 85 is offline   Reply With Quote
Old 01-14-2004, 09:42 PM   #917
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
Talking spur and pinions
hello josh...
what's the difference between bigger and smaller spur/pinions when using the same ratio....???
i.e.:
90/15 = 6
78/13 = 6
supposing I'm running my car with both spur/pinion combinations i wrote above, what the differences on performance??
thanxxx...
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 01-15-2004, 12:24 AM   #918
Default TC3
Hi Josh,
thanks again for the quick reply,
when you say you use the losi rear hubs, do you mean the XXX rear hubs or the XXX-S?
as the XXX-S rear hubs will make the car's rear track width wider due to the offset of the outter bearing
thanks
Intel
Intel is offline   Reply With Quote
Old 01-15-2004, 06:57 AM   #919
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
Intel,
The non-offset rear hubs is what he was speaking of.
Blake
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 01-15-2004, 07:10 AM   #920
I was wondering when the truck bodies I saw from the autoshow were going to be released? I want to run one on my sedan.
I saw your dad in the footage on the Toyota site...wish they would have used a model instead because personally, I don't find Jerry very attractive.
Unregistered is offline   Reply With Quote
Old 01-15-2004, 02:50 PM   #921
TC3
TC3's Avatar
@josh
i am wondering why top guys like u always find a good setup within a few runs.
do you have a special order when changing the setup?
for example, if ur car hast to much steering entering the corner and not enough coming out of the corner. ther are a few things that could be done: changing body, caster, rollcenter , antirollbars...
how do i know where to start
TC3 is offline   Reply With Quote
Old 01-15-2004, 03:30 PM   #922
Josh Cyrul's Avatar
FTSPEEDWAY - Thanks for the invite. I'll have to stop by and check it out!!
JCB - I sent my entries in... I hope they got them!!
JoshR85 - I didn't have diff trouble. I tried cutting every other tooth off of the diff gears to make the car more free. I also broke a rear belt because of that...lol... No diff trouble - just testing.. I don't think I'll be back - I have to go to the 200mm Pre-Worlds in Brazil!!
SalvadoriRacing - The 15/90 will have more roll when you get off of the throttle. The 13/78 should have more punch off the corner.
Intel - The XXX-S hubs and the TC3 hubs are the same - UNLESS - you are talking about the "offset" hubs that Losi sells...
Unregistered - lol... The only question is... who are you??...lol
TC3 - No special order. We've just raced on a lot of different tracks where different combinations work well. Usually we can tell what the car is doing right away and adjust accordingly. It also depends on the car - I know the Asc guys don't make the same adjustments as I do now with my Xray....
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 01-15-2004, 04:31 PM   #923
Originally posted by Josh Cyrul
.........I don't think I'll be back - I have to go to the 200mm Pre-Worlds in Brazil!!
HI JOSH....
thanks for answering.....i have 2 questions...
about the preworlds..... I'm really happy with the notice that you'll come here in Brazil to run the preworlds.....All of brazilian drivers would like to meet world level drivers like you....
I'm the webmaster of IFMAR WORLDS 1/10 I.C. 2004 website....you can visit >>>> www.rc-riverside.com
can you say what car you'll run???
About the spur/pinion......should i use bigger spur and pinion for "open" tracks and smaller spur and pinion when i run at "tight" tracks???? or these setting will improve only acceleration progressivity and does not matter the track layout???
thanxxx!
Salvadori Racing
Old 01-15-2004, 07:40 PM   #924
Regional Moderator
BHenderson's Avatar
Send a message via AIM to BHenderson Send a message via MSN to BHenderson Send a message via Yahoo to BHenderson
hi Josh,
I noticed that you mentioned that you cut every other tooth off your front diff and I saw it in the pics here on rctech, was there a noticable difference in the drivetrain? I am looking into ways to "free up" my drivetrain on my Evo2 and wondered what other thoughts or things you have tried to free up the drivetrain?
Thanks in Advance,
Brandon
BHenderson is offline   Reply With Quote
Old 01-15-2004, 07:56 PM   #925
lazyboy's Avatar
Send a message via AIM to lazyboy
hey josh,
quick qeustion, i was thinking about a x-ray for my next car, but im kinda leaning towrads sumtin else cuz my friend that owns a x-ray say that they are not easy cars to set up, so i was just woundering what your imput would be about the car??
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 01-15-2004, 07:56 PM   #926
lazyboy's Avatar
Post
sry guys i clicked the post button twice
Random Guy
FT B4
Trackside hobbies
Old 01-15-2004, 09:27 PM   #927
hi Josh.... can we also ask you about your fw05r in this thread?
shogun is offline   Reply With Quote
Old 01-15-2004, 09:28 PM   #928
Hey josh,
since you now run an FW05r why don't you also post another "ask josh" thread in nitro room?
You can also help a lot of nitro racers especially Fw05 users. Just a suggestion!
Old 01-15-2004, 11:13 PM   #929
R/C Tech Founder
R/C Tech Charter Subscriber
Josh is still waiting for lazy old me to create the Pros forum. But in the meantime, it's perfectly fine to talk nitro in here.
I am still waiting to upgrade the software, it's a long process getting there. I'm still testing the new stuff, I don't want to screw the forums up.
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 01-16-2004, 06:46 AM   #930
ChrisP's Avatar
Futurereal,
I can't imagine the carnage if you were to change the software prematurely and rctech was to go down..even for a short while. My local forum for southwestern ontario had a server crash, and the entire local racing community were like lost souls drifting in a void
Take your time, this place rocks, that's pretty evident by the size and the quality of the user-base that you've built up here
ChrisP is offline   Reply With Quote
Josh Cyrul and T.O.P. Racing E.J. Evans Electric On-Road 18 11-29-2008 09:02 AM
josh cyrul at the 'birds b-man777 Electric On-Road 5 02-06-2008 09:23 AM
Josh Cyrul -> Novarossi rmdhawaii Nitro On-Road 11 09-20-2007 07:34 PM
josh cyrul and peak motors b-man777 Electric On-Road 43 02-15-2006 03:24 AM
Josh Cyrul on MTV2 teammediocre Chat Lounge 1 04-15-2005 05:46 PM
