Old 12-10-2003, 09:12 AM   #766
DaveW's Avatar
LOL David J! I was scrolling the threads late last night and came across a post by Ron A... i have been so pleased with his cells lately that i had to snag his Avatar for some shameless and innocent product endorsement!! Hope you guys dont mind!
- Dave
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 12-10-2003, 09:18 AM   #767
Josh Cyrul's Avatar
DaveW - The Double Pink/Oranges have been by far the best front tire this year (at least in the mod class). I am sure that Jaco is not going to discontinue them!!
Ozwald - Anti-dive will decrease steering vs kick-up. Anti-dive will drive flatter and react faster where kick-up will make the car smoother, sometimes even lazy but with more steering...
SpeediePHATT - Look in the Cleveland report area on this web site. They took a bunch of pictures of the CEFX12.
Adam - Yep, I will be there!
KMW - I'm not sure where they measure droop from on this car. I believe it's from the bottom of the front steering block screw and that was 1mm. In the rear I went off the bottom set-screw holder part of the hub carrier and that was 3mm... I tried 64p on my car and it was very loud for some reason!! The spacer on the rear hub carrier gives more rear camber change - more steering...
Keith - How am I supposed to do that?? I don't have any info!!
Ray - Thanks for the info!!
Brain L - No 6 turns...lol...
XrayEye - The Double Pinks are usually around a 35-37 shore. The Orange part varies from about 40-50....
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 12-10-2003, 09:34 AM   #768
Mercury Racer's Avatar
What do you usaully run? Anti-dive or kick-up? and if if so... why?
what about anti-squat and pro-squat?
Does this apply to all RC cars?
thanks in advance!
Mercury Racer is offline   Reply With Quote
Old 12-10-2003, 11:23 AM   #769
ralph m's Avatar
R/C Tech Charter Subscriber
Trader Rating: 31 (100%+)
KMW-Josh,
I found that there are 2 different rear hub carriers with the same part numbers, probably a revision. The older one has a shorter set-screw boss. This can make the duplication of setups difficult.
Referencing a droop # using the screw in bottom of the c-hub can be problematic as well. It will be in a different position when using the plastic versus the aluminum c-hubs. If I'm using a setting of 2 with the plactic c-hubs it works out to be a 1 with the aluminum's.
Josh, thanks for posting your set-ups and helping us out with the XRay.
Ralph
ralph m is offline   Reply With Quote
Old 12-10-2003, 12:28 PM   #770
Josh Cyrul's Avatar
Mercury Racer - I usually run flat - no anti-dive or anti squat. In the rear - more anti squat usually gives you more steering off-throttle and more rear bite on-throttle. Pro-squat gives less steering off-throttle and more steering on-throttle. It can be decieving though - Anti-squat will make the car feel smoother on the first initial steering input where Pro-squat will make the car react faster..... I know it applies to TC's... I'm not sure about off-road...
Ralph - I'll measure my car from the lowest point of the suspension arms (at the outer hinge pin) for my droop setting and I'll post it tommorow (I'm going to practice tonight)....
Old 12-10-2003, 06:23 PM   #771
sands's Avatar
So... when you say pro-squat - that's on the rear suspension tipped down to the front?
thanks
sands is offline   Reply With Quote
Old 12-10-2003, 07:57 PM   #772
Kick-up and Anti-dive in the front...
Anti-Squat and Pro-Squat in the rear...
Currently taking a break from R/C, running 1/1 scale cars, they are cheaper then running Modified TC!!!
retired from RC in 2007, running 1:1 scale now
[email protected]
Greg Anthony is offline   Reply With Quote
Old 12-10-2003, 10:09 PM   #773
Send a message via AIM to Bobby Flack
You didn't answer the question Greg...
Sands..You are correct, pro-squat is when the hinge pins are angled down in the front.
Bobby Flack is offline   Reply With Quote
Old 12-10-2003, 10:12 PM   #774
Toledo this weekend Bob? Or do you have to "work"????
[email protected]
Old 12-10-2003, 10:12 PM   #775
Work..
Old 12-10-2003, 10:53 PM   #776
sorry
u need to get a better job!
[email protected]
Old 12-11-2003, 12:39 AM   #777
highwayman's Avatar
... so does it follow that if i added anti-squat, i'll have a bit of understeer since the car will have more rear bite?
... when are the times or conditions that you do run anti-dive or anti-squat?
highwayman is offline   Reply With Quote
Old 12-14-2003, 10:19 PM   #778
Default Novak
Josh, Cd here just wanted to give you a shout out! Are you coming to the Novak? Also if you could send me your e-mail addr. my painter wants to get some of your kick Aaaaaaa grafix sheets for my SB bodys, hopefully I will see you at the Novak and I can pick something out, I still don't know if I am going yet.
Talk to you later CD
Chris Doseck is offline   Reply With Quote
Old 12-15-2003, 02:43 PM   #779
Josh,
It was fun seeing you and Jake mix it up at the CRL. It was a nice end to a great weekend. He talked about it all the way home. Looks like you are getting your new stuff figured out. Good luck on your new ventures.
ohiorcdad is offline   Reply With Quote
Old 12-15-2003, 07:14 PM   #780
Josh Cyrul's Avatar
sands - Yep...
highwayman - On throttle you would have more rear bite.... Off throttle you may have more steering. Adjusting things just depends on what you want the car do at any particular track. Myself, I haven't run anything other than flat in a long time - I just don't like the feel of kick-up or anti-squat...
Chris - I'll be at the Novak race!! Practicing with 19t yet?? [email protected]
ohiorcdad - Thanks!! It was a lot of fun and I figured it would be a better way to end the weekend with a bit of fun. I know I learned a lot from racing with Blackstock and a few others when I was younger so I hope Jake had a good time and it was good practice for him!!!
Josh Cyrul and T.O.P. Racing E.J. Evans Electric On-Road 18 11-29-2008 09:02 AM
josh cyrul at the 'birds b-man777 Electric On-Road 5 02-06-2008 09:23 AM
Josh Cyrul -> Novarossi rmdhawaii Nitro On-Road 11 09-20-2007 07:34 PM
josh cyrul and peak motors b-man777 Electric On-Road 43 02-15-2006 03:24 AM
Josh Cyrul on MTV2 teammediocre Chat Lounge 1 04-15-2005 05:46 PM
