Old 11-05-2003, 10:48 AM   #331
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Josh, will your bodies be available from you or through distributors?
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 11-05-2003, 12:11 PM   #332
Send a message via AIM to Bobby Flack
Jeff Werner.. I would try everything Josh listed there except the tires. The best combination for a good balance is Pink rears, Pink LF, and a Black RF. All JACO rubber of course.
Bobby Flack is offline   Reply With Quote
Old 11-05-2003, 12:51 PM   #333
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
Man looks like I will have to buy some tires to see which one of you is correct...lol
What tire dia do you guys recomend? This will be 4 cell stock or 19t.
Rear Wing Choices? I think the car has a pod mounted wing, do you usually run the body mounted type?
Thanks guys for all the help. Have not ran oval in a few years...my Hyperdrive 0500 car with Dillon Tweek system looks old now compaired to these new oval racers. Looking forward to running the oval again!
Josh you running Oval at the Birds and what car will you use?
Jeff
Jeff Werner is offline   Reply With Quote
Old 11-05-2003, 01:48 PM   #334
Josh Cyrul's Avatar
Darryl - LOL... Umm, somewhere I think...lol... I'll call the Chief and get it if I can't find it!!
Kraig - Right now, we are very small and just trying to learn all of this. We have set up our pricing and will just be selling to hobby shops. I will not be selling the bodies direct to people....
Bobby - ?? When have you beat me in oval racing?? J/K
Jeff - Give Bobby's tire set-up a try and see what you like better - I think the pink left front makes the car loose off the corner and the black right front pushes into the corner too much...lol.... I like running no bigger than 2.32 and no smaller than 2.18...... I think everyone uses the body mounted wings now - that's what I've run the last few times out. I will be racing oval and I have no clue what car!!
Josh Cyrul is offline   Reply With Quote
Old 11-05-2003, 01:56 PM   #335
Josh,
Do you have a website?
Where can we see pics of the bodies?
How does a hobby shop get in-touch with you?
Thanks.
savio7 is offline   Reply With Quote
Old 11-05-2003, 02:39 PM   #336
Super Moderator
Kraig's Avatar
Josh, sounds good and keep us informed. I am sure we could help sell some bodies for you.
Old 11-05-2003, 03:01 PM   #337
coastaltony's Avatar
Default bodies
Good luck on the new body line.
coastaltony is offline   Reply With Quote
Old 11-05-2003, 10:24 PM   #338
I haven't.. but the old man has! Anyways, thats the standard jaco setup for just about every flat track. I wouldn't expect you to know that since you were running those other things for so long.
Old 11-05-2003, 10:33 PM   #339
kiyano's Avatar
Josh,
send me an e-mail [email protected]
Thanks in advance
kiyano is offline   Reply With Quote
Old 11-06-2003, 07:20 AM   #340
Josh Cyrul's Avatar
savio7 & kraig - We don't have a web site yet. After Cleveland that is something we hope to look into and get set up.... I can however e-mail pics... I wonder if I could post them on here... Hmmm....
[email protected] is how any hobby shop can contact me....
Thanks coastaltony!!
Bobby - Yeah, yeah....
Old 11-06-2003, 07:22 AM   #341
A pic would be cool. Is the sedan a Stratus type or Alfa type design or other?
Thanks again for the oval help.
Jeff
Old 11-06-2003, 09:56 AM   #342
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
Hey Josh, I told you that Im headin down to the 'Birds in February. Just look for the guy in the blue Superman shirt (I may also be wearing a bandanna).
Also, I dont know if you run Stock TC much but do you have a good way to setup the stock motor for that sort of a track?
trackdesigner71 is offline   Reply With Quote
Old 11-06-2003, 10:29 AM   #343
EricF's Avatar
Josh,
can you possible help with this, I know that my car is a Yokomo SD but I'm just curious if there a basic things to try if fix this type of situation.
Here's my set up:
Front:
shock: sss, 61.5mm, gray gt4 srping, trinity 50 wt, #3, out on stock tower, stk. on arm, droop: 6mm, .8 shim under front arm mount, spacer under steering spindel, camber: stk on carrier -middle, 2nd row middle
Rear:
shock: sss, 62.5mm, gray gt4 spring, trinity 45 wt, #3, up and out on tower, 2nd from hub on arm, droop: 4.5mm, no shims/spacers, camber: stock on hub, stock on tower
58.5 mm tires (28 mm wide) tan front (37) magenta rear (35), ride hgt.: front- just under 5mm, rear- 5mm (track min. 5mm), stock arm spacing 3/1 front, 2/2 rear, gm3 104/30, front diff tighter than rear (mod setting), camber set for even tire wear, proto alfa 2.0 small wing.
track size: 93' x 43'
I know that 51 asked you this before, but do you think that you can make to Az. for the REedy Crossover Challenge in Feb 21 & 22?
Thanks,
Eric
AE 12R5.2 & R6(x2) - TC7.1 convert, F6 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 11-06-2003, 11:57 AM   #344
Josh Cyrul's Avatar
Jeff - When I get one painted I'll post it. The 1/12 will be first with the touring to follow in a few weeks (I hope)....
trackdesigner - Umm, for stock I usually just ran full brushes with purple springs. Sometimes I cut a little bit off the sides of the brushes. This helped the motor have less drag brake and run faster in the last minute of the race (less heat)....
Fike - I can see about the Crossover race but I won't know for a while. As far as your set-up I'm not really sure what you are asking me?? I have your set-up now but I don't really know what it all means or what you would like your car to do better. I'm just at a bit of a loss.... Explain, more info, please...
Old 11-06-2003, 12:03 PM   #345
Josh,
You have email at [email protected]
LMK. Thanks.
Josh Cyrul and T.O.P. Racing E.J. Evans Electric On-Road 18 11-29-2008 09:02 AM
josh cyrul at the 'birds b-man777 Electric On-Road 5 02-06-2008 09:23 AM
Josh Cyrul -> Novarossi rmdhawaii Nitro On-Road 11 09-20-2007 07:34 PM
josh cyrul and peak motors b-man777 Electric On-Road 43 02-15-2006 03:24 AM
Josh Cyrul on MTV2 teammediocre Chat Lounge 1 04-15-2005 05:46 PM
