Old 06-09-2005, 09:42 AM   #2236
jjmudd's Avatar
Thanks Josh.
We would still love to have you up to Canada on the August 19 - 21 weekend for our Canadian Asphalt Invitational. We now have Barry Baker, Todd Hodge and Andrew CartWright confirmed and would love to have a Kyosho rep at our race!!! If you are interested, pm me or email me at, [email protected] and we'll see if we can't make it work for you. You could bring your family...we do have the World's largest mall here in Edmonton...let your wife spend some of your $$$!!
John Hughes
jjmudd is offline   Reply With Quote
Old 06-10-2005, 06:15 AM   #2237
Thumbs up Cool, thanks for replying Josh, just two more questions then if I may
Originally Posted by Josh Cyrul
Sorry guys, I haven't been around much as I was out at the Reedy Race and then came home where my wife became ill and we spent nearly a week in the hospital with her so it's been a bit busy to say the least....
jjmudd - Yep, exactly the same for any engine....
Mabuchi 540 - Gearing wise, the C12's rear pod is longer than most all the other 1/12's out there right now. This allows us to gear the car much higher without having to run a tiney spur gear to do so. We still keep the suspension geometry close by moving the t-bar pivot farther back. The back of the chassis has 2 holes, one for a CEFX t-bar and one for an Asc t-bar. The kit includes Jaco Purple fronts and Jaco Pink rears. The diff balls are standard 1/8 (this is the standard size used in all Kimbrough, PRS, RW, Robinson and any other gear for a 1/12 car). As far as upgrade parts - the kits now are including all the new batches of parts (motor plates, king pins, dampner tubes) as well as all the new Evo2 parts as we have now completely switched over to the new inventory. Hop-up parts you can get are the upright servo mounts and of course any of the green stuff if you prefer green over the standard silver look.
Well 3 if you want to be picky.
What size is the included spur and with it how many teeth would I need on the pinion to get the previously mentioned "at least better than my CGM running 540 stock" (currently between 43.75mm and 46.49mm rollout and plenty fast enough on my local tightish track)?
And lastly, I am having a lot of trouble finding an online store that takes CC and will ship to New Zealand at a resonable price (one shop would only ship via UPS for $90 example)...that actually has the C12 in stock.
Do you know where I could get a couple from in the next 2-3 days?
I'm only getting two to cover every possible breakage I could think of considering NZ has no agents and it's some distance to send away for one little bumper for example.
Thanks in advance.
Edit: One more total newb to 1/12th question, I'm just wondering if the kit comes with a standard setup? You know make the steering rods this length, adjust such and such to this length for the camber (as a starting point) I'm sure you get the drift.
Mainly because other than a gauge to measure ride height for my TC I don't have any setup gauges as such and have always gone by kit setups (+ or - ing the starting lengths). Hope that makes sense.
Mabuchi540 is offline   Reply With Quote
Old 06-12-2005, 02:47 PM   #2238
*bump* steer.
Old 06-13-2005, 10:24 AM   #2239
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Hey Josh, can you recommend tires for 1/12 mod on ozite carpet for me please?
Old 06-13-2005, 11:42 AM   #2240
The Evicerator
Josh,
I hope that everything is going better for you this week! Take care!
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 06-17-2005, 03:31 PM   #2241
AdrianM's Avatar
Default A blast from the past...
This is an old vid but it is still pretty cool. It will probably live forever on the net...
sorry...bad link....some questionable pop ups behind the video!
Adrian Martinez
Old 06-20-2005, 05:41 AM   #2242
mcsquish's Avatar
Randy, I know that he runs two stage foams front and rear. Or Pink and I think Dbl pink.
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Never argue with an idiot, they'll just drag you down to their level and beat you with experience.
Dirt Burners Racing - R.I.P. BB / Kolors by Kropy / CEFX / One Eighth Racers
mcsquish is offline   Reply With Quote
Old 06-22-2005, 08:09 AM   #2243
Josh Cyrul's Avatar
Randy - Scott had it covered. I usually run the Jaco 2-stage tires on both the front and the rear. If I'm not running those then I'm on double pink fronts with pink rears (rarely white rears on carpet)....
Evicerator - Thanks!!
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 06-23-2005, 02:52 PM   #2244
I've seen/read a number of times that the "Jaco 2-stage" tires seem to be the way to go for even better control than the purple/pink combo that comes in the C12 kit. But I have been unable to find them listed anywhere.
I did a google search "jaco 2-stage" and only got two references. Once the kit tires run/wear out I thought I would have a set of those ready to use, any ideas/suggestions where can I might be able to get them online?
Old 07-18-2005, 08:53 AM   #2245
rayhuang's Avatar
Congrats Josh on your ROAR Sedan Nats win!!!
Old 07-18-2005, 10:40 AM   #2246
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Yea good job Josh. I'm sorry the win was less spectacular because of the controversy, but everyone agrees you were the winner without a doubt.
I didn't get to see the mains cause we left Sunday morning for Memphis but I can only assume you figured something out since your car looked like a real handfull to drive during qualifying. You did a great job getting it into the main considering the circumstances.
As usual it was good seeing you and I was glad to get a chance to sit down and chat a little. Man that baby is cute as a button! You ever figure out who her father is???
BigDogRacing is offline   Reply With Quote
Old 08-05-2005, 08:30 PM   #2247
page 7, that won't do. TTT
Racin Rev is offline   Reply With Quote
Old 08-05-2005, 10:43 PM   #2248
Josh Cyrul's Avatar
Ray - Thanks!!!
BigDog - Thanks! I did figure out a lot for the final as my car was a ton better just in time. As far as who the father is - I guess you have to ask my wife that one!!
Racin Rev - Thanks...lol..
Old 08-06-2005, 07:31 AM   #2249
jag88's Avatar
Hey Josh, what's two stage rubber (foam) ?
Thanks.
jag88 is offline   Reply With Quote
Old 08-07-2005, 10:26 PM   #2250
reilly's Avatar
Hey Barry,
I know I'm not the "Man" but I do have the answer, the two stage Jaco tires
are like the 12th scale tires they brought out last winter. the "core" is a lighter and stiffer foam wrapped with the same foam as we run know such as double pink. Josh can explain the benefits of this tire, but from the results their faster.
Hope that helps for now.
James
CEFX, Express Motorsports, Parma, Reilly Paint
reilly is offline   Reply With Quote
Josh Cyrul and T.O.P. Racing E.J. Evans Electric On-Road 18 11-29-2008 09:02 AM
josh cyrul at the 'birds b-man777 Electric On-Road 5 02-06-2008 09:23 AM
Josh Cyrul -> Novarossi rmdhawaii Nitro On-Road 11 09-20-2007 07:34 PM
josh cyrul and peak motors b-man777 Electric On-Road 43 02-15-2006 03:24 AM
Josh Cyrul on MTV2 teammediocre Chat Lounge 1 04-15-2005 05:46 PM
