Old 10-09-2003, 09:03 PM   #196
lazyboy's Avatar
Send a message via AIM to lazyboy
Default Re: sorry dont mean to pick ur brains.
Originally posted by kevin2
hey sorry to bother u but i tried the rear losi hubs and they slid back and forth did u put another spacer in there?thanks for the help
kevin im not total sure but i think you run two spacers but im just takeing a guess tho... but try that and then when josh replys do what he says and not what i said kk
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 10-09-2003, 10:40 PM   #197
kevin2's Avatar
Send a message via AIM to kevin2
Smile
i put on both spacers that is in 2 spacers and the hub slid left and right i dont know if i should put 3 on but now im runnin the associated one. i might swich back
kevin2 is offline   Reply With Quote
Old 10-10-2003, 02:55 AM   #198
hooked_on's Avatar
Josh: I enjoyed watching you race at Brendale last weekend, in the end you were out of luck with the one way bearing letting you down and a back maker getting in your way in the 1/8th final. Now that you have finished up with Trinity, does this mean you will stop running the G4? I have heard around the traps you had some major imput into designing the car? What are your thoughts on the car? And any chance of getting hold of your setup from last weekend? Curious!
Look forward to hearing from you.
H-O
- - - - 2013 Dick Johnson Racing Team Mate Member - - - -
hooked_on is offline   Reply With Quote
Old 10-10-2003, 10:39 AM   #199
NR
NR's Avatar
Trader Rating: 52 (100%+)
Default Stock TC3 Setup
Josh
You are obviously a great guy that has time for begginers which is very nice of you.
Josh in Regards to the advice you were giving mad racer i think it was about the Stock TC3 Set up does this work just as well with Foam set up.
Would i have to make any other adjustments?
Thanks Josh.
And good luck with your next endeavour.
Kind Regards
Nathan
NR is offline   Reply With Quote
Old 10-10-2003, 10:43 AM   #200
NR
NR's Avatar
Sorry Josh i know this is your thread.
Although come on Barry help josh out a bit here lol he has to many questions to answer im sure you could help him.
Im sure you would not mind Josh would you?
So Barry what do you think in regards to a stock set up on the TC3 any different opinions?
Josh gave the set up 2 pages back.
Thanks Josh Barry
Kind Regards
Nathan
Old 10-10-2003, 07:29 PM   #201
In all regards to Josh(he is the man on Carpet)heck I go to him for advise(and Blackstock)whenI go to Cleveland...
as for asphalt well....He sure is getting the hang of it fast..lol
what advise he gives is usually right on the money...
so its all gravy over here..
Barry
Barry Baker is offline   Reply With Quote
Old 10-11-2003, 01:44 AM   #202
NR
NR's Avatar
Cheers Barry
I knew you would both have very similar tips as you are both extremely good.
Barry do you ever race Stock or is it TOO Slow for you lol.
Barry any chance of you coming out to Australia?
Regards
Nathan
Old 10-11-2003, 03:23 PM   #203
Send a message via AIM to Bobby Flack
Can I file the backside of my trigger to get more speed?
Bobby Flack is offline   Reply With Quote
Old 10-11-2003, 03:31 PM   #204
Bobby I heard if you let the smoke out of your speed control it makes it go faster...lol
Old 10-11-2003, 03:34 PM   #205
Ahhh.. ok... I knew there was something you guys weren't telling me.
Old 10-12-2003, 05:55 AM   #206
NR
NR's Avatar
Default Barry
Barry you skipped my reply lol lol. ..... ohh thats right you get busy sometimes dont you.
Old 10-13-2003, 12:08 PM   #207
Josh Cyrul's Avatar
CypressMidWest - Yep, I'll be there!
kt tracing - It's just the added load on the gears that the spool creates, it just helps to take that little bit of play out so the mesh stays tight...
RCsilly - Sorry I wasn't able to make it out, I went down to Toledo and tested my new 1/12 body...
kevin2 - You have to use motor shims to take up the "play". Another of the Asc nylon shims will be too much....
AMGRacer - Yep, that's what broke! The car was good and I had a good time there so it's not a big deal - there will be another race..lol...
hooked_on - Running the G4 in the future? I'm not really sure but hopefully I'll know in the comming weeks. I didn't design the car but I just wrote race and test reports after each time I raced the Reflex. Team Magic did the rest from there. I'll check out my car and post a set-up once I have time to write it all down.
Josh Cyrul is offline   Reply With Quote
Old 10-13-2003, 12:13 PM   #208
Josh Cyrul's Avatar
PinkTC3 - There are a few different foam tire set-ups. Associated has Mike Blackstock's set-up from the 2003 Carpet Nats on their site. That would be a good set-up to start with.
Bobby - I thought you were replacing the trigger with a toggle switch??
Old 10-13-2003, 12:23 PM   #209
Rocket Ronbo's Avatar
Send a message via AIM to Rocket Ronbo
Default paris memorial @ vegas
Hi Josh
Are you still going to Vegas? if so when do you arrive?
Well I will see you there if you go...
Ron (over 40 but under 50) Rossetti
Rocket Ronbo is offline   Reply With Quote
Old 10-13-2003, 12:25 PM   #210
Currently I've been running purple/gray on my 12th scale car. And I'm interested in trying a different compound up front, I believe the shore rating is 35 on the inside with a 45 on the outer ring (I cant remember what the color name of it is, I think it's Cyan). would this work? I'm looking for a tire that will chunk a little less. Thanks.
racerdx6 is offline   Reply With Quote
Josh Cyrul and T.O.P. Racing E.J. Evans Electric On-Road 18 11-29-2008 09:02 AM
josh cyrul at the 'birds b-man777 Electric On-Road 5 02-06-2008 09:23 AM
Josh Cyrul -> Novarossi rmdhawaii Nitro On-Road 11 09-20-2007 07:34 PM
josh cyrul and peak motors b-man777 Electric On-Road 43 02-15-2006 03:24 AM
Josh Cyrul on MTV2 teammediocre Chat Lounge 1 04-15-2005 05:46 PM
