Old 12-13-2004, 09:12 PM   #1891
Corey Bernardo's Avatar
Send a message via AIM to Corey Bernardo
Front: cyan
50
light purple w/4 holes open
3rd hole out on carpet tower
center hole on bulkheads f/r
1mm swaybar
Rear: magenta
35
violets w/4holes open
4th hole out on tower
outer hole on arms
short camberlink lower hole
upper hole on bulkhead f/r(raised roll center)
using xrc chassis with battery foward a slot on left
let me know man, like i said that car is really responsive, just has a slight lift that is aggravating me lol.
*TLR* *Losi* *Horizon Hobby* *Factory Novak* *Team Trinity/Epic* * JConcepts* *Xcelorin* *Spektrum* *Nitrotec* *Nitrotane* *UpGrade RC* *Toyz4Boyz* * Team Cypress*
Corey Bernardo is offline   Reply With Quote
Old 12-13-2004, 09:23 PM   #1892
rayhuang's Avatar
Originally posted by Josh Cyrul
Ray - Never enough steering unless it's impossible to drive...lol.. Are you doing the full front tire with tire traction???
Josh-thanks-this helps more than you know!!! Then I will keep dialing in a car with more and more steering-driveable and balanced of course!! And yes-full Paragon front and rear. NO CA on fronts, 4.5 deg caster, no sway bar-even!! Still pushes mid-off in very fast 180's. BUt-Not the Split chassis this time. I am slowly building up enugh parts to build another split chassis car to go with my 350!! Chicky says his Split car has mad steering. OK-I am babbling!!
Old 12-13-2004, 09:31 PM   #1893
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Ray, I'm not Josh, but I have a suggestion. Why don't you try going to the outer hole on the steering knuckle without the ackerman extensions. That was better at my track for the real tight stuff.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 12-14-2004, 06:15 AM   #1894
Josh Cyrul's Avatar
Apex - I wanted the car to react faster and change directions faster for Cleveland's technical track this year. I tried it in the med position and it was easier to drive but it just wasn't as aggresive as I needed....
Corey - Try running 60wt in the front.... That might slow the front end down a bit keeping that rear tire on the ground....
Ray - 4.5 castor?? You guys and your 6 blocks with anti-dive...lol... I run no anti-dive and 3 degree blocks.... More steering The split chassis is much better with foam tires!!!
Brian - The only problem with that is you make the car more twitchy so it is better through the tight stuff but you usually loose a lot of steering high speed (sweepers) and the car becomes hard to drive once you hit high traction....
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 12-14-2004, 06:29 AM   #1895
chicky03's Avatar
Send a message via AIM to chicky03
Yea, Josh is right again. Everytime I think I find something better two weeks later I am back to his setup. I went back and forth at the champs with the anti dive and flat pins and was always faster with flat and 3 degrees. I will have to say that the split chassis for me in stock when trying to run Josh's setup made the front end dig but never lift. I had to go to stiffer springs in the front. For mod and 19t the split chassis with Josh's setup is by far better than the standard or XRC chassis. Basically you can drive the 19t and mod like a stock.
See ya Saturday Josh.
Paul
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 12-15-2004, 06:41 PM   #1896
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
Default FK SHOCK QUESTION
does anyone know how much shock oil weight is added by closing one hole? ex. if i have a 30wt with all holes open and i close one (1) hole on the shock piston what oil weight would it be equivalent to? 35? 40? 45?
thanks
S-T-R-l-K-E-R is offline   Reply With Quote
Old 12-15-2004, 06:49 PM   #1897
Thanks for the info, Josh. Actually, Ray, I would do what Josh said, 3 degrees and pins flat. Car steers a lot more!
USVTA Member #211
Old 12-15-2004, 07:03 PM   #1898
Rob Mincey's Avatar
Striker - I want to say that each click adds about 5wt each, but I can't be sure. For some reason, I think I remember someone telling me that.
Rob
Rob Mincey is offline   Reply With Quote
Old 12-15-2004, 09:04 PM   #1899
rayhuang's Avatar
JOsh-just got done putting my SPlit chasis together again. Should I show up Saturday with the Nats set-up on the car or the Champs set-up for MOdified?
Thanks,
Ray
Old 12-15-2004, 10:00 PM   #1900
Josh Cyrul's Avatar
chicky -
striker - Remember, when you change hole you are changing dampening feel but you are also changing the "pack" of the shock which dramatically effects performance... As far as what equals what... I have no clue.... Another thing, 4 holes open on the adjustable pistons is not the same as a 4 holes open on the standard pistons as the holes in the adjustables are bigger I believe....
Rob - 5wt Xray oil which equals about 10-15wt Asc....
Ray - Both set-ups are quite close actually... Start with the Nats one.....
Old 12-15-2004, 10:07 PM   #1901
Josh thanks for the insight! Do you use the adjustble pistons or no..
Old 12-15-2004, 10:23 PM   #1902
Josh Cyrul's Avatar
Nope, I change the oil - not the pack...
Old 12-15-2004, 10:34 PM   #1903
Na i didnt mean it like that... Was just curious if you run the adj. pistons. I be changing the shock oil too, but seem to usually keep 4holes open
Old 12-16-2004, 06:44 AM   #1904
Josh Cyrul's Avatar
Corey - I used the fixed ones...
Old 12-16-2004, 07:01 AM   #1905
John Tag's Avatar
Trader Rating: 42 (100%+)
Josh, so what your saying is 3* c-hubs and flat ,has more steering than 6* or 3*with 3*kick. I am running stock and seem to have a little tight condition mid corner out. I have ran 3* w/3* kick and 6* flat so far,
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Josh Cyrul and T.O.P. Racing E.J. Evans Electric On-Road 18 11-29-2008 09:02 AM
josh cyrul at the 'birds b-man777 Electric On-Road 5 02-06-2008 09:23 AM
Josh Cyrul -> Novarossi rmdhawaii Nitro On-Road 11 09-20-2007 07:34 PM
josh cyrul and peak motors b-man777 Electric On-Road 43 02-15-2006 03:24 AM
Josh Cyrul on MTV2 teammediocre Chat Lounge 1 04-15-2005 05:46 PM
