Old 12-09-2004, 09:52 PM   #1876
Josh,
Are you running hinge pin mounts in the middle hole front and rear on the bulkheads still? And is that how you ran in Cleveland?
Thank you.
Jamie Corrado is offline   Reply With Quote
Old 12-10-2004, 06:57 AM   #1877
kidDynomite's Avatar
Originally posted by Josh Cyrul
kid - Are you running the long wheel base setting?? When the car is in long wheel base then the shocks are about right....
Yes, I figured it out last night and forgot to post. Thank you, though!
kidDynomite is offline   Reply With Quote
Old 12-10-2004, 07:47 AM   #1878
Josh Cyrul's Avatar
Jamie - Middle front, high rear is what I ran in Cleveland....
kid - No problem!
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 12-10-2004, 08:11 AM   #1879
THANKS FOR THE QUICK REPLY JOSH!
Old 12-10-2004, 10:46 AM   #1880
Josh,
Congrats on Cleveland!!!
Got a quick question....when you say you are using the long wheel base do you mean the rear arms are as far back as they will go? i.e. you are using no spacer behind the arms??
Thanks!!!
Ozwald Bates is offline   Reply With Quote
Old 12-10-2004, 06:11 PM   #1881
raving-monkey's Avatar
Send a message via MSN to raving-monkey
Yep, no spacers behind the rear arms (it works really well actually, but i found my car drives better witha 2mm spacer behind the arm)
Josh, i;m not sure if you race stock or not but do you have any recomendations for a stock motor on rubbers...on a medium-large indoor sized track.
the surface is a rubbery type floor (indoor running track)
car is evo2 with low ratios.
thanks
Matt
raving-monkey is offline   Reply With Quote
Old 12-10-2004, 08:52 PM   #1882
Josh Cyrul's Avatar
Ozwald - I use all the spacers in the front so the wheel base is maxed out with the exception of a motor shim to take up the play.
monkey - I've always prefered the longer wheel base as it calms the car down in mod and gives a little more on-throttle steering... Stock??...uhh..... No clue...
Old 12-12-2004, 02:55 PM   #1883
Scrad's Avatar
Trader Rating: 15 (100%+)
Josh, I figured out that hooking problem I had. When I changed tires I forgot to trim the tire down, so it was rubbing on the shock eyelet when it cornered hard. Duhh LOL
Anyways you said before that you set droop with limiters in your rear shocks. What size kind of spacers are you using and what size? I have an older BMI chassis that I just got and the droop screw sit too far out on the chassis and it makes setting the droop inconsistant. Right now I have some spacers in my shocks, but I still have too much droop. Thanks.
Scrad is offline   Reply With Quote
Old 12-12-2004, 08:49 PM   #1884
Josh Cyrul's Avatar
Scrad - I don't remember the exact # or size of shims. I just measured the travel and put in enough shims to set things where I wanted - Remember, set the shims at the right setting but leave your shock bottom unscrewed about 1 full turn - this will give you the option to add or take away droop without taking the shocks apart....
Old 12-13-2004, 08:55 AM   #1885
rayhuang's Avatar
JOsh-we ran Modified Sedan for the first time in ages Sunday. Made lots of changes to the car-some on radio and alot on the car, but at end of day-I still felt like I needed a lot more steering-especially mid-corner. But I notice on all Pro XRay set-up sheets-the set-ups never look crazy on steering. Never too much caster, camber, toe-out, reduced rear toe.......
SoO my question is-when do you stop looking for mechanical steering and then just hit the brakes or lift earlier for the turns to get through the corners tight?
Thanks as always,
Ray
Old 12-13-2004, 01:57 PM   #1886
Sorry, i missed out a word in my post.
Should of said stock motor gearing, but ive got it sorted now
Old 12-13-2004, 02:13 PM   #1887
Corey Bernardo's Avatar
Send a message via AIM to Corey Bernardo
Josh I pretty much got my xray car dialed, working with a setup that is pretty close to yours. My question is when the rear end lifts a lil bit, should I put a rear swaybar on it or lower the rear roll center? thanks dawg
*TLR* *Losi* *Horizon Hobby* *Factory Novak* *Team Trinity/Epic* * JConcepts* *Xcelorin* *Spektrum* *Nitrotec* *Nitrotane* *UpGrade RC* *Toyz4Boyz* * Team Cypress*
Corey Bernardo is offline   Reply With Quote
Old 12-13-2004, 08:33 PM   #1888
whynot's Avatar
Trader Rating: 18 (100%+)
Josh,
What kind of wire do you use with your electrics on your 12 scale.Looks easier to lay down than the wire I am using.Where online can I order it from. thanks
mike
whynot is offline   Reply With Quote
Old 12-13-2004, 08:42 PM   #1889
Josh Cyrul's Avatar
Ray - Never enough steering unless it's impossible to drive...lol.. Are you doing the full front tire with tire traction???
Corey - Neither in my opinion.... What is your set-up??
whynot - I use Stage III wire...lol... It's so old, I've had it from back in the days when my parents owned Stage III battery matching company.....
Old 12-13-2004, 09:06 PM   #1890
Trader Rating: 45 (100%+)
Default roll center??
Josh,
I was looking at your Cleveland 2004 setup for the XRay and I'm curious how come you run a high roll center in the rear of the car ?
Thanks and congrats on your wins at Cleveland!
Apex is offline   Reply With Quote
Josh Cyrul and T.O.P. Racing E.J. Evans Electric On-Road 18 11-29-2008 09:02 AM
josh cyrul at the 'birds b-man777 Electric On-Road 5 02-06-2008 09:23 AM
Josh Cyrul -> Novarossi rmdhawaii Nitro On-Road 11 09-20-2007 07:34 PM
josh cyrul and peak motors b-man777 Electric On-Road 43 02-15-2006 03:24 AM
Josh Cyrul on MTV2 teammediocre Chat Lounge 1 04-15-2005 05:46 PM
