Old 10-07-2003, 10:24 PM   #166
Josh Cyrul's Avatar
JoshR85 - I will be in Cleveland. No doubt about that one!!
chicky03 - I will use spacers under the F block or I will grind a little off of the F-0 and bumper. I don't usually run more than .040 (2 degrees) of anti-dive. The best thing to do is to try it and see what you think - some tracks I like it, others I don't. I haven't played with it a lot so I don't have it down to a science as to when/or not to use it....
Josh Cyrul is offline   Reply With Quote
Old 10-07-2003, 11:04 PM   #167
The question everyone wants answered though is..................
Who will you be running for in Cleveland?
Barry
Barry Baker is offline   Reply With Quote
Old 10-08-2003, 01:18 AM   #168
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
Hi Josh
Just don't for get to drop me an email for your products
Tommy
*Tourer**Futaba***SpeedPassion
*F1**4PX***TORO
*12th**4PX***TORO
*8th**4PX***OS Speed XZ-R
*10th**4PX***OS Speed XZ
tl2111 is offline   Reply With Quote
Old 10-08-2003, 06:27 AM   #169
kt racing's Avatar
Send a message via AIM to kt racing
Josh, or Barry,
I have a NTC3 and I'm having problems with striping the front ring and pinion gear out of it. But I'm using the spool in the front as well. I have tried different cases and different gears and about a thousand different shim combo's but I can't fix it. Just wondering if you have any tricks for it.
kt racing is offline   Reply With Quote
Old 10-08-2003, 06:42 AM   #170
Manfredo's Avatar
Default anti dive
Hey josh !
Ive also tried to use anti-dive on the tc3 by using the r-block instead of the f-block. (since the r-block is a litle higher than the f-block).
The only concern I have with this setup is that the r-block is a little wider than the f-block too. Therefor it gives the fornt a little "toe in" and therefor a little longer wheelbase.
I drove with this setup on my hometrack an found that the car has more front bite than with the f-block (both with 4 castor blocks)
Is it possible that the gain of front bite can come more from the longer wheelbase than from the anti-dive ?
When do you use the lower rear roll center usually ?
Thax for your answers in advance.
Manfredo is offline   Reply With Quote
Old 10-08-2003, 06:47 AM   #171
Doug D's Avatar
Trader Rating: 54 (100%+)
Josh - Thanks.....I see the light!
Doug D is offline   Reply With Quote
Old 10-08-2003, 02:25 PM   #172
Hey, is this coffee talk with your host Josh Cyrul. How come the computer says your a rookie, doesn't the computer know who you are!!
Pong anyone?
willis is offline   Reply With Quote
Old 10-08-2003, 02:29 PM   #173
Matt Howard's Avatar
who let Barney in here? remember that one willis
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-08-2003, 02:43 PM   #174
Moderator
DaveVera's Avatar
What's up Josh? Good job in Ohio man............
Later....
Vera
DaveVera is offline   Reply With Quote
Old 10-08-2003, 07:18 PM   #175
JoshR 85's Avatar
HeY!!!
hey Josh about how high do you go in oil for shocks at the big events when groove is black or do you just go up in springs, or both, cause all i do really is just go up in heavier spring and it works good, should i do both or continue to do what i do???
JoshR 85 is offline   Reply With Quote
Old 10-08-2003, 07:19 PM   #176
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
Barry
Exactley!
do we all have to wait to find out?
another note, when you ran ae front arms in the rear, what hubs did you use(losi?). when i was running front arms in the rear it made the wheelbase very short(compaired to stock) and i see that you use a "f" block in place of the "r" block(which i would assume would make the wheelbase longer and less toe). but i was still thinking that it might be too short(but i think that the pic was of a car that you were driving on carpet, so a short wheelbase should be good right?).
Bubblestc3 is offline   Reply With Quote
Old 10-08-2003, 07:46 PM   #177
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
Hey Josh, Im kinda new to the TC3 family (I won one off of Ebay), what is a good baseline setup to start from?
trackdesigner71 is offline   Reply With Quote
Old 10-08-2003, 07:51 PM   #178
JoshR 85's Avatar
HeY!!!
trackside what are you gonna run rubber or foam that will help Josh out what to tell yo for setup.
Old 10-08-2003, 08:06 PM   #179
lazyboy's Avatar
Send a message via AIM to lazyboy
Originally posted by JoshR 85
HeY!!!
josh R buddy this will be the second time i corrected your spelling tonight.... instead of "yo" use "you" im jsut mess but yea i agree with what you said it all depeneds on what your are going to run.
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 10-08-2003, 08:08 PM   #180
jaysimpson's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to jaysimpson
Whats happening Josh?! When you going back out to Fernandos? From what he said carpet should be back by November.
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
jaysimpson is offline   Reply With Quote
Josh Cyrul and T.O.P. Racing E.J. Evans Electric On-Road 18 11-29-2008 09:02 AM
josh cyrul at the 'birds b-man777 Electric On-Road 5 02-06-2008 09:23 AM
Josh Cyrul -> Novarossi rmdhawaii Nitro On-Road 11 09-20-2007 07:34 PM
josh cyrul and peak motors b-man777 Electric On-Road 43 02-15-2006 03:24 AM
Josh Cyrul on MTV2 teammediocre Chat Lounge 1 04-15-2005 05:46 PM
