Old 11-14-2004, 05:58 PM   #1756
Josh Cyrul's Avatar
Chris - The TC3 arms have the droop screws in a little better position to use them so they don't need to use the shock lengths.
Tony - Sarcasim....lol.... Bobby being a smart...... you can fill in the blank.....
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 11-14-2004, 07:39 PM   #1757
mcsquish's Avatar
Bobby being smart?? Oh, now I get it Bobby being A smart... Now I get it. Have a fun week
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Never argue with an idiot, they'll just drag you down to their level and beat you with experience.
Dirt Burners Racing - R.I.P. BB / Kolors by Kropy / CEFX / One Eighth Racers
mcsquish is offline   Reply With Quote
Old 11-16-2004, 09:12 AM   #1758
Send a message via ICQ to elvo
Josh,
did you ever get to test the longer T-BAr for the C12 properly? Any advantages?
And have you ever tried lowering the rear roll center on the C12, or any other 1/12 car?
elvo is offline   Reply With Quote
Old 11-16-2004, 10:25 AM   #1759
yea Bobby is a smart.... hows he doing as an employee at halo?
Tony Szep is offline   Reply With Quote
Old 11-18-2004, 07:51 AM   #1760
Josh you said you run the old carpet front shock tower. Would you know the part number ? I know you are not a walking catalog. LOL! I have the new lower foam tire front shock tower.
Team Associated, JConcepts, M2C Racing, Big Pimpin Paints
Chris Reilly is offline   Reply With Quote
Old 11-18-2004, 12:39 PM   #1761
Hi Josh,
on your nats set-up sheet you say that you are running the front diff tight....how tight?? close to a spool or just tight enought that the diff doesn't slip??
thanks and good luck at Cleveland!!
Pace
Pace72 is offline   Reply With Quote
Old 11-18-2004, 09:12 PM   #1762
Josh Cyrul's Avatar
elvo - We currently run the longer t-bar on the C12 as that's what it comes with. It does tend to be smoother to drive which is better for more flowing, high speed tracks. Lowering the rear roll center will give you more rear bite and especailly helps if you are loosing rear bite over a 8 minute run...
Tony - Bobby's doing fine...lol..
Chris - That's the one....
Pace72 - About 1/4 a turn tighter than the rear diff.....
Old 11-18-2004, 10:19 PM   #1763
Send a message via AIM to Bobby Flack
Wow..
Bobby Flack is offline   Reply With Quote
Old 11-19-2004, 01:53 PM   #1764
[B}
Tony - Bobby's doing fine...lol.. [/B]
thought so...LOL
Old 11-19-2004, 02:24 PM   #1765
CypressMidWest's Avatar
Josh: You actually gave Bobby a job? You don't let him speak with the customers do ya?
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 11-19-2004, 04:28 PM   #1766
RCsilly's Avatar
Location: Redford Mi. Trying to keep up with Tim Stamper
RCsilly is offline   Reply With Quote
Old 11-21-2004, 09:19 AM   #1767
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
josh - i am having little problem with hairpins on days with low traction.
when i prep for a hairpin turn as i reach the apex when off throttle my car suddenly spins out. this happens usually on the first few laps when tires are cold. so what happens is i always play catch up. i tired adding more droop (lower numerically on a droop guage). when on throttle the car is on rails. one more thing is that on chicanes and sweepers its really on rails.
any ideas or explanations?
S-T-R-l-K-E-R is offline   Reply With Quote
Old 11-21-2004, 10:07 AM   #1768
Scrad's Avatar
Trader Rating: 15 (100%+)
What tire sauce are you using?
Scrad is offline   Reply With Quote
Old 11-21-2004, 04:44 PM   #1769
Josh I'm building my FK and the rear suspension binds with everything tightened up. What do I need to do to cure this ? It has to do with the hinge pin angle in the mount I'm guessing. No shocks are on the car and the turnbuckles are free.
Old 11-21-2004, 06:27 PM   #1770
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
josh, i hope everything is going well,
i just got a new c12, and am running on carpet, do you have a starting setup??? i will be running stock, i have either, purple ft and grey rear tires, or double pink ft,and pink rears.. i have installed the thick t-bar, and at this point have used losi hydro fluid, (clear) in the dampner tubes.....
thanks
matt
Matt M. is offline   Reply With Quote
Josh Cyrul and T.O.P. Racing E.J. Evans Electric On-Road 18 11-29-2008 09:02 AM
josh cyrul at the 'birds b-man777 Electric On-Road 5 02-06-2008 09:23 AM
Josh Cyrul -> Novarossi rmdhawaii Nitro On-Road 11 09-20-2007 07:34 PM
josh cyrul and peak motors b-man777 Electric On-Road 43 02-15-2006 03:24 AM
Josh Cyrul on MTV2 teammediocre Chat Lounge 1 04-15-2005 05:46 PM
