Old 11-01-2004, 10:31 AM   #1726
JDXray's Avatar
Send a message via AIM to JDXray
Thanks for Reply Josh, i know your a busy man.
Jon
JDXray is offline   Reply With Quote
Old 11-01-2004, 10:04 PM   #1727
thanks Josh! Much appreciated.
rcosmax is offline   Reply With Quote
Old 11-04-2004, 07:49 PM   #1728
jaysimpson's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to jaysimpson
Josh, whats the best camber link location to start with on carpet when using the newer front shock tower? Thanks!
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
jaysimpson is offline   Reply With Quote
Old 11-07-2004, 06:24 PM   #1729
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
Default 1/10 200mm worlds
hi josh......
at first congrats for you awesome job at the 1/10 200mm worlds.......
why did you run a larger front width on your car (according to your setup sheet posted on kyosho japanese site)
thanks!!!!
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 11-07-2004, 07:30 PM   #1730
Hey Josh,
I was wondering when you will have C12 setups and tips up on your site?
Tony Szep is offline   Reply With Quote
Old 11-08-2004, 03:41 PM   #1731
Josh Cyrul's Avatar
promatchrcr - I don't know...lol... I still use the old "carpet" tower as you can't get the body low enough with the new tower....
SalvadoriRacing - I liked the wide front to keep the car stable and I liked the rear more narrow as it really helped the car getting up the backstraight hill and highspeed sweeper onto the straight.
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 11-08-2004, 03:46 PM   #1732
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Hello Josh , I wanted to know what is the handling differences between the rear shock mounting in the upper level and the lower level? (bottom of the shocks) (FW-05R)
Old 11-08-2004, 03:49 PM   #1733
tboned_2002's Avatar
Josh,
Xray
When are you going to post a carpet setup for rubber tires on your website?
thanks
t
tboned_2002 is offline   Reply With Quote
Old 11-08-2004, 09:51 PM   #1734
jaysimpson's Avatar
Josh: Yeah I noticed that after I got it on...whats up with that,LOL??? Thanks anyway!
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
Old 11-10-2004, 06:22 AM   #1735
Default Servo?
Hello Josh
I just bought a BMI xray, Can you tell me what steering servo to run in it. Price range from low dollar to over a hundred.
And really how much torque do xrays need to steer. I am getting all kinds of disinformation.
I hope you can help me out.
Joe
powerpark2 is offline   Reply With Quote
Old 11-10-2004, 09:26 AM   #1736
rayhuang's Avatar
Default Xray rear arms
Hello Josh,
Welcome back-I hope you finally get to get some rest.
ON the XRay short rear arms-I drilled droop screw holes holes further out on arm (right next to original position) and asked BMI to make chassis wider there to accomodate the wider droop screw position. With the droop screw where they are at-the arms bend down very easily when the droop screw hits the chassis. Its made even worse with a stiff rear spring like Violet and up.
I am wanting your thoughts on if you think with this modification if it will effectively make the arm feel like a stiffer material arm-or if you think we could benefit from stiffer rear arms at this years Champs.
I am trying to figure out a way to stiffen the arms, but not make it heavy (like filling the webbing with JB weld).
Sorry-very long,
Take care,
Ray
Old 11-11-2004, 07:59 AM   #1737
Josh Cyrul's Avatar
Marcos - I never liked the lower mounting position so I'm not really sure on an exact answer. I tried it the first time I ran the car, changed it to the uppers and never looked back...
t_boned - I probably won't as we don't normally run rubber on carpet in the US.....
promatch - I dunno...lol...
powerpark2 - I would at least get a KO 2343. This has good torque and speed as I already have driven a few cars this year that had servos without enough torque.....
Ray - I never have that much trouble with the droop screws for 2 reasons... 1. I never pre-load my springs that much 2. I use the shock length to set the droop anyway... That mod doesn't really make a difference to the feel of arm stiffness as that's only on the down travel which we normally aren't in on the track anyway.... I've tested hard vs soft arms and I honestly can't tell any difference in stock. In mod I can slightly but I found the al. rear hubs were the most noticable and I actually didn't like the al. front end pieces as it made the car push too much as the front end would chatter...
Old 11-11-2004, 08:06 AM   #1738
mcsquish's Avatar
Hay, are thoes bells I hear ringing? You still have time. Oh, wait no you don't. You would be hunted down and drug back. lol! I forgot, I'll see you Sat. if you servive
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Never argue with an idiot, they'll just drag you down to their level and beat you with experience.
Dirt Burners Racing - R.I.P. BB / Kolors by Kropy / CEFX / One Eighth Racers
mcsquish is offline   Reply With Quote
Old 11-11-2004, 08:54 AM   #1739
rayhuang's Avatar
Thanks!! Thats what I needed to hear-cannot feel the difference in arms in stock-alls good now!! ONe less thing to worry about pre-champs.
Old 11-11-2004, 10:04 AM   #1740
Super Moderator
Marcos.J's Avatar
thanks Josh!
Josh Cyrul and T.O.P. Racing E.J. Evans Electric On-Road 18 11-29-2008 09:02 AM
josh cyrul at the 'birds b-man777 Electric On-Road 5 02-06-2008 09:23 AM
Josh Cyrul -> Novarossi rmdhawaii Nitro On-Road 11 09-20-2007 07:34 PM
josh cyrul and peak motors b-man777 Electric On-Road 43 02-15-2006 03:24 AM
Josh Cyrul on MTV2 teammediocre Chat Lounge 1 04-15-2005 05:46 PM
