Old 09-28-2004, 11:03 PM   #1681
Hi Josh,
do you know if Alex Lopez is running long wheelbase in stock on carpetor if he run the box set-up wheelbase?
thanks
Pace
Pace72 is offline   Reply With Quote
Old 09-29-2004, 07:00 AM   #1682
pucho's Avatar
Send a message via AIM to pucho
Originally posted by Pace72
Hi Josh,
thanks
Pace
Pace: I am not Josh or Alex but I do build the cars for Alex and he tends to like a shorter wheelbase, but not much shorter than stock.
pucho is offline   Reply With Quote
Old 09-29-2004, 12:30 PM   #1683
thanks pucho!
Pace
Old 09-30-2004, 06:50 AM   #1684
Josh Cyrul's Avatar
Pucho - I'm glad you got that one - I had no clue how Alex runs his car!!
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 10-02-2004, 02:15 AM   #1685
roll ctr
Josh,
Do you run hi or low roll ctr for 12 scale carpet?
thanks
eklips is offline   Reply With Quote
Old 10-03-2004, 01:43 PM   #1686
Send a message via ICQ to MattW
Josh, What motor set-up do you generally tend to run in 12th?? Can/arm and brush/spring if poss
cheers
MattW is offline   Reply With Quote
Old 10-04-2004, 06:03 AM   #1687
Josh Cyrul's Avatar
eklips - I run it standard unless the traction is reallly high or really low... For carpet - usually just the standard pivot balls down on the chassis...
MattW - Fantom (Reedy TI based), 8x1 with 20 degrees of timing and a 22/100. Green springs and I'm not sure of the brush # from Fantom....
Old 10-04-2004, 06:06 AM   #1688
Anders Myrberg's Avatar
Josh,
Can you please mail me on [email protected], eeh, now...
Anders Myrberg is offline   Reply With Quote
Old 10-04-2004, 07:11 AM   #1689
RandyB's Avatar
http://babelfish.altavista.com/babel...ko-yano.net%2f
Looks like the C12 is being represented in Japan. Kinda cool.
Randyb
RandyB is offline   Reply With Quote
Old 10-04-2004, 09:32 AM   #1690
Cheers Josh that's great, is it the 5mm arm?. Have you done much running with the PT can?? I run Fantom's and ran Ti's all last winter. Tried the Kr, but simply couldn't last and was thinking of at least trying the PT can this year.
Old 10-15-2004, 07:58 AM   #1691
Josh can you please describe step by step your shock bleeding process for the XRAY T1 FK ? What do you use behind your bladders and how many ?
Team Associated, JConcepts, M2C Racing, Big Pimpin Paints
Chris Reilly is offline   Reply With Quote
Old 10-15-2004, 07:33 PM   #1692
Company Representative
Trader Rating: 15 (100%+)
Hey Josh,
Can you tell us all what changes you have made to your setup since Carpet nats 04?
What changes have you made or tried since changing to the new 3.5 chassis. ( are you running the cells on the left one slot up)
Also last year you ran AE oil ( 50/30) Are you now running XRAY 30/30 or ??
Thanks, and good luck in the 200mm Finals, Bring it home for us!!.
WCICS- Competition Director
Korgae is offline   Reply With Quote
Old 10-17-2004, 09:11 PM   #1693
Who makes the .7mm sway bar that you use ? I thought maybe you made it.
Old 10-18-2004, 05:34 AM   #1694
mcsquish's Avatar
Josh, since I will not get up there before you leave again, congrats on fourth. I know you wanted to do better, but with the problems, fourth is good. Good luck at FL. and good luck with Angel's list.
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Never argue with an idiot, they'll just drag you down to their level and beat you with experience.
Dirt Burners Racing - R.I.P. BB / Kolors by Kropy / CEFX / One Eighth Racers
mcsquish is offline   Reply With Quote
Old 10-18-2004, 05:38 AM   #1695
reilly's Avatar
Yeah Chris,
Josh cuts down a 1mm bar to .7
Happy dremeling
James
CEFX, Express Motorsports, Parma, Reilly Paint
reilly is offline   Reply With Quote
Josh Cyrul and T.O.P. Racing E.J. Evans Electric On-Road 18 11-29-2008 09:02 AM
josh cyrul at the 'birds b-man777 Electric On-Road 5 02-06-2008 09:23 AM
Josh Cyrul -> Novarossi rmdhawaii Nitro On-Road 11 09-20-2007 07:34 PM
josh cyrul and peak motors b-man777 Electric On-Road 43 02-15-2006 03:24 AM
Josh Cyrul on MTV2 teammediocre Chat Lounge 1 04-15-2005 05:46 PM
