Old 09-10-2004, 06:00 AM   #1651
Josh Cyrul's Avatar
losirob - My only recomendation would be to use my Carpet Nationals set-up...lol...
Reilly - Danger....
trackdesigner71 - Yep and hopefully I can get back to them after Halo Hobbies is up and running...
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 09-10-2004, 09:48 PM   #1652
Josh
On a tbar 12 scale car, what effect does putting 2 different size washers under the pivot balls(to angle the tbar) have on the way the car handles?
novak is offline   Reply With Quote
Old 09-11-2004, 07:34 AM   #1653
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
Reilly - Danger....
Sweet stuff! I remember hearing something about a CLMP 675 I believe. Is that still in the works or are you heading in another direction?
trackdesigner71 is offline   Reply With Quote
Old 09-11-2004, 09:20 AM   #1654
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
josh - im having problems with the exit steering on my car. initial turn is and mid corner is quite impressive but as i go deeper with the throttle as i exit it tends to push badly i tried various shock posisions and spring combinations both front and rear. i was able to get more steering using the low mounting hole on the front hingepins. would an anti squat set-up help me with this? or should i resort to another body. btw i am using a mazda 6.
S-T-R-l-K-E-R is offline   Reply With Quote
Old 09-11-2004, 09:43 AM   #1655
Korey Harbke's Avatar
I'm not Josh, but I think I can help. You could also decrease the amount of chassis lift up front by tightening the droops screws up front just a bit . It will allow for less weight transfer to go from the frotn to the back when on power.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 09-11-2004, 09:05 PM   #1656
Josh Cyrul's Avatar
novak - Usually, putting shims under the front of the t-bar will give you more steering as well as putting shims under both pivot ballls - Higher roll center....
striker - Mazda usually has this tendency - to turn in great and then give up and push through the center out. A different body may be a good idea to try. How much toe-in are you running?? Are you using a front diff, one-way or spool??
Old 09-11-2004, 09:26 PM   #1657
josh - i am using a one way, and a zero degree caster, 3mm chassis. i'm now using 3 deg tow-in (rear). would it be wise to go down to 2 deg?
Old 09-12-2004, 03:05 PM   #1658
Josh
If I go to a thinner TBar on my 12 scale, what effect will that have on its handling?
Old 09-12-2004, 07:50 PM   #1659
Josh Cyrul's Avatar
striker - 2 degrees would be better. Also, try moving the batteries forward if you can...
novak - Usually, a thinner t-bar will have more rear traction and handle better over a bumpy track. Steering will be less and the responce will be much slower than with a thick t-bar.
Old 09-13-2004, 12:56 AM   #1660
reilly's Avatar
CEFX, Express Motorsports, Parma, Reilly Paint
reilly is offline   Reply With Quote
Old 09-13-2004, 04:26 AM   #1661
i tried 2 deg rear toe-in and i was quite amazed by the diffrence in performance. there was less understeer i guess the body compensated for the less toe-in. one thing i noticed right away was the big diffrence in the speed on the straight. the 1 degree less drag was quite noticable.
i have another question. i noticed that under my chassis was scratches on both sides. does this mean that my fk is rolling too much when cornering that the sides of my chassis scrape onto the asphalt? what should i do to remedy this? (i tried raising the ride height from 6mm to 7mm and still have this problem).
Old 09-13-2004, 05:25 AM   #1662
Is the asphalt chassi for the C12 ready ?
When you moved the cells out did you move the cell as fare out as on the Yokomo
What is the wheel base ?
200 mm , 202 mm, 2004 mm ?
for asphalt
and what it is for carpet ?
Alf
alf.skaar is offline   Reply With Quote
Old 09-13-2004, 11:00 AM   #1663
mtveten's Avatar
Trader Rating: 27 (100%+)
Is there a 0 deg composit caster block available for the car or does it only come in aluminum?
How durable are the aluminum blocks, with my previous cars I have always avoided them for fear of bending them.
Mark
mtveten is offline   Reply With Quote
Old 09-13-2004, 11:06 AM   #1664
alf.skaar, check on Shoptron, that's where I got mine...
Currently taking a break from R/C, running 1/1 scale cars, they are cheaper then running Modified TC!!!
retired from RC in 2007, running 1:1 scale now
[email protected]
Greg Anthony is offline   Reply With Quote
Old 09-13-2004, 11:15 AM   #1665
Josh Cyrul's Avatar
striker - Try going 1 spring rate harder all the way around.... That may help and you may actually have to go slightly harder on dampening...
alf - The asphalt chassis is ready and shipping. I don't know the Yokomo battery location so I can't say if it's the same or not. The wheel base is exactly the same as the origional chassis. We were going to change it but then we thought against it...
mtveten - I think they come in plastic - both Soft and Medium... The plastic ones do flex a little but I have never broken one. The aluminum ones I have bent so that is still possible....
Josh Cyrul and T.O.P. Racing E.J. Evans Electric On-Road 18 11-29-2008 09:02 AM
josh cyrul at the 'birds b-man777 Electric On-Road 5 02-06-2008 09:23 AM
Josh Cyrul -> Novarossi rmdhawaii Nitro On-Road 11 09-20-2007 07:34 PM
josh cyrul and peak motors b-man777 Electric On-Road 43 02-15-2006 03:24 AM
Josh Cyrul on MTV2 teammediocre Chat Lounge 1 04-15-2005 05:46 PM
