Old 08-29-2004, 09:12 AM   #1621
Send a message via Yahoo to Doug Gaut
Josh, new to carpet and was wondering what size in mm you normally start your foam tires at? Also would like to know how many runs one should expect from a set of double pink/orange and double pink tires when running mod? Thanks
Doug
Doug Gaut is offline   Reply With Quote
Old 08-29-2004, 09:43 AM   #1622
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
josh -i just ran my fk with the new chassis and it was awesome!!!! it was really predictable and so easy to drive it almost was a no brainer!!! the car is perfect!!
HOWEVER...... i couldnt use the low roll center for the rear anymore cause on how the 3D cut was done. there was no provisions for the the black plastic thingie that held the hinge pins in place.
BUT NEVERTHELESS the car was superb!!! just wanted you to know about it!!
kudos once again!!!
S-T-R-l-K-E-R is offline   Reply With Quote
Old 08-29-2004, 11:41 PM   #1623
Josh Cyrul's Avatar
Doug - I usually run 2.28-2.16 tires... I'm not sure what that is in mm.... I think about 58mm-55mm and I can usually get about 8-12 runs on a set....
striker - Sounds good. I always use the middle hole for foams and the upper hole for rubber tires so I never noticed that you can't use the lower roll center position....
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 08-31-2004, 10:37 AM   #1624
Josh.
I have some questions about the FK.
I know you feel more comfortable talking Foam carpet but I want to pick your mind about rubber/outside.
asuming I have a good starting point in set-up.
how would I get the following:
More onpower steering?
More low or off power steering?
More rear traction?
Less rear traction?
More corner speed? ( asuming I am using new proper tires for the track)
I have a spool, oneway and a diff, but I prefer the spool.
What real effect does the roll centers do to the car ? You mention you use the top rar hole for Rubber? can I sk why? what does it do compared to the mid hole in the rear? What about the front RC on rubber?
you you always run the car in the long wheelbase?
What does "moving out" on the top link do? ( making it shorter) What does raising the ball studs on the hubs do?
What about the short front link in the lower postion of the front tower ( new one) ?
I read somewhere that the car does not react like other cars in terms of front caster,
0 works for?
3 works for?
6 works for?
Sorry for al the questions, I just want to learn as much as possible about my new car. our racing events are short on practice so the more i learn from you the faster I wil be on the track.
P.S. I have the new chassis
Thank you so much it is a big help.
speed2004 is offline   Reply With Quote
Old 08-31-2004, 10:39 AM   #1625
Send a message via AIM to Adam Hartzell
Josh--Will you be in Toledo this week. I'm going to make the trip down on Thursday to watch practice.
Adam Hartzell is offline   Reply With Quote
Old 08-31-2004, 03:27 PM   #1626
Josh,
Can you post your radio settings that you use with your FK ? ( EX10) What features on the radio do you really use a lot with your FK?
thanks
Old 08-31-2004, 04:08 PM   #1627
TeamButter's Avatar
Send a message via AIM to TeamButter
Josh-Hey man what up tire toss champ? Hey if you have a chance can you call me at 561-301-1861....got a quick question regarding your track and the Halloween race.
Thank you,
Michael A.
Teambutter
Xray / BMI Racing / KO Propo / Team Epic / Parma-PSE / High Velocity Racing / TeamButter / P3 Graphics / MDI Racing
TeamButter is offline   Reply With Quote
Old 08-31-2004, 11:27 PM   #1628
TeamButter's Avatar
Old 09-06-2004, 07:55 PM   #1629
Josh Cyrul's Avatar
Hey Butter!! I won't be at the Halloween race this year as I will be down in Brazil for the Worlds. I'll give you a call this week though!!
speed2004 - WOW... First, my radio - I set my end points and drive. I don't use a lot of the other functions as I like to keep everything neutral and linear as it makes it easier for me to jump from one class of racing to another. Now, as to the rest of your questions.... it would take me hours to type replies to all of these. Please just ask one/two at a time and be more specific as to what you would like your car to do better or what it is doing wrong.
Old 09-07-2004, 11:50 AM   #1630
rayhuang's Avatar
Josh-I saw your post on hosting the NORRCA Nats. I was wondering-if you know yet what day qualifying will start? I saw its scheduled from Thursday to Sunday.
Old 09-07-2004, 06:45 PM   #1631
TeamButter's Avatar
Josh-Reception is real poor on cell phones here as result of the hurricane. If you get the mailbox just leave me a number where I can reach ya!!
P.S. Good job at the Gas nats.
Mike A
Old 09-07-2004, 07:19 PM   #1632
TFR
TFR's Avatar
Josh, where did you get the purple screws for your ex-10?
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
Old 09-08-2004, 01:05 PM   #1633
Josh,
any word on the servo mounts that your makeing for the cefx?
Tony Szep is offline   Reply With Quote
Old 09-08-2004, 03:29 PM   #1634
Originally posted by speed2004
Josh.
More rear traction?
Less rear traction?
0 works for?
3 works for?
6 works for?
xxx book!!
layedbackpimp is offline   Reply With Quote
Old 09-08-2004, 05:05 PM   #1635
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Josh.
More rear traction?
Less rear traction?
0 works for?
3 works for?
6 works for?
Hey Speed2004, I'm Josh's agent and I have a special offer for you!! For a meer $4500cash (plus expenses) (due upon arrival) Josh will come to your home town, spend every day with you at your home track answering your questions and teaching you to tune your TC like a pro. Not only that, but if you send the $1000 prepayment within the next 2 hours, he'll bring you a box full of FREE CEFX masks and stickers!!
Yp Josh- looking forward to getting up your way for some carpet racing. Looks like I'll get to do a little more racing this winter since Team Butter has offered me sponsorship with all travel and entry fees paid!!! I'm so lucky!!!
BigDogRacing is offline   Reply With Quote
Josh Cyrul and T.O.P. Racing E.J. Evans Electric On-Road 18 11-29-2008 09:02 AM
josh cyrul at the 'birds b-man777 Electric On-Road 5 02-06-2008 09:23 AM
Josh Cyrul -> Novarossi rmdhawaii Nitro On-Road 11 09-20-2007 07:34 PM
josh cyrul and peak motors b-man777 Electric On-Road 43 02-15-2006 03:24 AM
Josh Cyrul on MTV2 teammediocre Chat Lounge 1 04-15-2005 05:46 PM
