Old 08-10-2004, 08:44 AM   #1591
Originally posted by rice98w
i was there too, josh your car looked fantastic.
can you please tell me, will the C12 work with calandra wheels and tires?
i'm pretty sure the rears will, as they're 3 bolt, but the fronts take an unflanged bearing, where as your jacos take a flanged....
if i took both flanged bearings off, replaced them both with unflanged, is that it to run crc wheels? and also, will the offsets be different to say someone using TRC or jaco?
thanks josh, congrats again.
matt rice
I'm pretty sure you can swap bearings
The Black Kat is offline   Reply With Quote
Old 08-10-2004, 10:05 AM   #1592
Josh Cyrul's Avatar
JDXray - What car are you talking about?? I have a few...lol..
Smoking motor - Great!! I'm very glad to hear that!!
Matt - The CRC's should work as the Jaco's take an unflanged bearing as well. Off-set wise I'm not 100% but I think TRC fronts will make the car about 1mm wider (total) and TRC rears would make the car about 2mm more narrow (total)...
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 08-10-2004, 01:06 PM   #1593
JDXray's Avatar
Send a message via AIM to JDXray
lol sorry about that, i was talking about the Xray. I should have told you in the last post, sorry.
JDXray is offline   Reply With Quote
Old 08-10-2004, 09:45 PM   #1594
Send a message via Yahoo to nomaak
i hope this question has not already come up.
josh...when using foam on asphalt (mod 8 turn Ti) how do you regulate droop & ride height to compensate for tire wear. and what's a good droop/ride height to start with? (tc3..58.35mm foams rear - 59.15mm front. thnx
nomaak is offline   Reply With Quote
Old 08-11-2004, 01:08 AM   #1595
Neil Rabara's Avatar
Originally posted by Josh Cyrul
Neil - Next time I talk to Ralph I'll pass it on...
Thanks Josh, but I've already spoken to him.
Neil Rabara is offline   Reply With Quote
Old 08-11-2004, 08:34 PM   #1596
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
have a little problem with rear end on highspeed sweepers. as the car reaches its apex the rear end tends to step out.
could adding spacers under the rear uprights help? or should i use the inner shock hole on the rear arms?. btw i'm already on the outermost hole on the shock tower.
S-T-R-l-K-E-R is offline   Reply With Quote
Old 08-11-2004, 09:56 PM   #1597
Josh Cyrul's Avatar
JDXray - Although the set-up is different the pics from the Carpet Nats, Reedy Race, Asphalt Nats are all the same car. Nothing new or special in the past few months...
nomaak - I would run 4 or 5mm ride height with the front end about .5mm lower than the rear. I usually run about .5mm droop from ride height in the rear and about 1-2mm droop from ride height in the front. I adjust the ride height and droop accordingly to the tire wear....
Neil - Ah, good!!
striker - Try leaning the shocks in - usually leaning them in on the rear tower gives you more rear traction, especially in the center of the corner or in long, high speed corners...
Old 08-12-2004, 09:52 AM   #1598
jag88's Avatar
Josh, I noticed on the new 3.5mm FK chassis that the batteries are moved forward and the servo is moved back. Why was this done ?
Thanks.
jag88 is offline   Reply With Quote
Old 08-12-2004, 10:27 AM   #1599
Josh Cyrul's Avatar
jag88 - We all liked the batteries forward a bit and the servo was always right into the suspension mount - they moved the servo back for clearance and ease of adjustment....
Old 08-15-2004, 12:39 PM   #1600
Registered User
tomlau's Avatar
hi josh,
i noticed in a recent pic of your c12, the cross brace for the damper tubes was mounted differently, and you had some green anod parts. Is this stuff ever going to make production?
tomlau is offline   Reply With Quote
Old 08-15-2004, 08:59 PM   #1601
Josh Cyrul's Avatar
tomlau - The geen anodized parts were samples I recieved from a friend. We are actually looking into getting green anodized parts for the future though..... The cross brace was a prototype part. It wasn't created for the handling but for the constuction as it eliminates a few screws and nuts....
Old 08-16-2004, 12:40 AM   #1602
Registered User
tomlau's Avatar
OK, cool. Im ordering my C12 tonight!
Old 08-17-2004, 11:37 AM   #1603
jag88's Avatar
Josh, any suggestions on what to do with the front shock tower on the FK? I can't slam the body without running into the tower.
Old 08-17-2004, 09:04 PM   #1604
jag88's Avatar
Josh, another question, Todd Hodge did an article in one of the magazines about setting up an XXXS. He said to move the front arms forward to take the angle out of the half shafts. This gave better and more consistent handling and turning. How would this work on an FK ? It would require some machining on the front arms but I know you are the 'King' of the dremel ! It would probably screw up the ackerman but you would just need longer extensions to get it back. Is it worth a try ? Have you tried it ?
Thanks.
Old 08-19-2004, 06:39 AM   #1605
Josh Cyrul's Avatar
tomlau - Awesome!!
jag88 - I'm not sure... We race at ROAR's legal height limits so I never try to just slam the bodies anymore... I actually do have a pair of a-arms to try and make the front end 1-2mm longer but I have never tried them. I will be testing it before the Worlds though!!
Josh Cyrul and T.O.P. Racing E.J. Evans Electric On-Road 18 11-29-2008 09:02 AM
josh cyrul at the 'birds b-man777 Electric On-Road 5 02-06-2008 09:23 AM
Josh Cyrul -> Novarossi rmdhawaii Nitro On-Road 11 09-20-2007 07:34 PM
josh cyrul and peak motors b-man777 Electric On-Road 43 02-15-2006 03:24 AM
Josh Cyrul on MTV2 teammediocre Chat Lounge 1 04-15-2005 05:46 PM
