Old 08-05-2004, 09:30 AM   #1576
KMW
KMW's Avatar
Originally posted by promatchrcr
I don't think it will do any good. I just went up north and they asked me when I checked my luggage if they were unlocked in case they needed to search it.
It does do some good, and it's the only way I'll check in my gear, personally. What should happen with locked bags is that you have to actually go with them to luggage inspection--that's why they're asking. Then you unlock the bags in front of them and get to watch while they dig through everything. This is actually very helpful because they get to ask you questions about your RC gear and you get to see what's confiscated, if anything. You also ensure no one pockets any of your stuff during inspection. After they're done you lock the bag back up and can then head to your terminal.
I've done this twice now and although it adds a little time, it's worth it to me. I use Mugen bags with small locks I bought separately.
KMW is offline   Reply With Quote
Old 08-05-2004, 09:35 AM   #1577
JCB
JCB's Avatar
Hey Josh,
I'm currently running the 2174 on my 190mm car. Any benefit upgrading to the 2123?
thanks again,
JCB is offline   Reply With Quote
Old 08-05-2004, 06:50 PM   #1578
Josh Cyrul's Avatar
JCB - It's a little bit quicker but it does take the extra time of wiring the servo into the speed control... I presonally like it a lot and always run it in my TC. Normally I never run and steering curve or expo but when I run on rubber tires I use -15% due to the servo's ultra fast responce - it can make the car a bit twitchy.... I love it with foam tires at 0% though....
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 08-05-2004, 07:08 PM   #1579
Neil Rabara's Avatar
Josh, did you pass along the message to have Ralph call me when you were at the nats?
Neil Rabara is offline   Reply With Quote
Old 08-05-2004, 07:25 PM   #1580
whynot's Avatar
Trader Rating: 18 (100%+)
Default Evolva
Josh,
How do you go about setting your front droop on your Evolva? I cant seem to keep both sides the sameI keep having to adjust the cams on both sides been playing with the sway bar and still cant get them to even out.What steps to you go through.How do you set up the sway bar with the cup on the ball.Thank you in advance.
mike wannett
whynot is offline   Reply With Quote
Old 08-07-2004, 07:06 AM   #1581
Josh Cyrul's Avatar
Neil - I honestly don't think I did... Sorry...
whynot - I adjust my front lengths (with the bottom ball cup) until the droop is 0mm. Then I hook up and adjust the roll bar without the droop screws touching. Once the sway bar is set equal then I turn the droop screws down until they touch... It's the only way I can get my front end tweaked properly.....
Old 08-07-2004, 09:49 AM   #1582
lazyboy's Avatar
Send a message via AIM to lazyboy
Josh,
i have to say that xray makes one hell of a car... good luck at your up coming races, hopefuly you'll make it to the novak race this year..
peace,
lazybot
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 08-07-2004, 09:49 AM   #1583
whynot's Avatar
So just to make sure.
First I adjust the shocks bottom ball cup until it holds the droop at zero or what ever I want my droop at.
once I get that set is it ok if one shock is longer or shorter than the other?
Than I hook up the sway bay and adjust the cams so that everything stays even at zero. Where do you tighten down the sway bar cup at,how does it meet with the ball?And when that is all done you tighten the droop screws until they touch. and that will be it. Thank you very much josh I really appreaciate it.
mike wannett
Old 08-07-2004, 03:54 PM   #1584
No worries, is there a way you can pass along the word to him?
Old 08-07-2004, 09:31 PM   #1585
Josh Cyrul's Avatar
lazyboy - I should be at the Novak Race this year. It's hard to miss a race at Scotty's!!!
whynot - As long as the droop is equal then it's fine - don't worry about shock length. I set the cup with about 1-2mm of the center of the ball inside the cup. Then I adjust the cams and tighten them. Once they are set I tighten down the droop screws so they touch...
Neil - Next time I talk to Ralph I'll pass it on...
Old 08-08-2004, 05:48 PM   #1586
whynot's Avatar
Josh,
Thank you very much.
mike,
Old 08-08-2004, 07:43 PM   #1587
JDXray's Avatar
Send a message via AIM to JDXray
Hey josh could you maybe post some pics of your car right now at a couple different angles so we can see what it looks like. If not thats okay. Just curious to see what your up too.
JD
JDXray is offline   Reply With Quote
Old 08-09-2004, 10:34 AM   #1588
Josh gotta say Your CEFX flies
We had a sunday meet in the uk and Roger M was flying with it even though he fast with anything. The was 19t stock 1/12th on carpet
Smoking motor.. is offline   Reply With Quote
Old 08-10-2004, 03:36 AM   #1589
i was there too, josh your car looked fantastic.
can you please tell me, will the C12 work with calandra wheels and tires?
i'm pretty sure the rears will, as they're 3 bolt, but the fronts take an unflanged bearing, where as your jacos take a flanged....
if i took both flanged bearings off, replaced them both with unflanged, is that it to run crc wheels? and also, will the offsets be different to say someone using TRC or jaco?
thanks josh, congrats again.
matt rice
rice98w is offline   Reply With Quote
Old 08-10-2004, 08:34 AM   #1590
matt klnow anywhere where i can get a 1/12 cheap i thinking about starting up agian all i need is chassis wheels and servo and batts
Sammy
Josh Cyrul and T.O.P. Racing E.J. Evans Electric On-Road 18 11-29-2008 09:02 AM
josh cyrul at the 'birds b-man777 Electric On-Road 5 02-06-2008 09:23 AM
Josh Cyrul -> Novarossi rmdhawaii Nitro On-Road 11 09-20-2007 07:34 PM
josh cyrul and peak motors b-man777 Electric On-Road 43 02-15-2006 03:24 AM
Josh Cyrul on MTV2 teammediocre Chat Lounge 1 04-15-2005 05:46 PM
