Old 07-15-2004, 06:33 PM   #1516
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
hey Josh i have a question about Paragon traction for the tires. Can u use it on foam and rubber? will it make the tires wear out quiker? Will it make my car slide out on asphalt? Tell me every thing you know about Paragon traction for the tires.
thx
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
Old 07-15-2004, 09:10 PM   #1517
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
i am not josh but i can give you some info about paragaon traction compounds. it has 2 versions both are available commercially. both are also equally as effective; they also can be used for rubber/foam on carpet/asphalt. but be careful when using on asphalt if the track is dusty and uneven it would only add more problems like making your car spinout.
S-T-R-l-K-E-R is offline   Reply With Quote
Old 07-19-2004, 04:06 PM   #1518
Trader Rating: 17 (100%+)
Default hey josh
hey josh....sorry to bug you but i need to know what you used for a setup on the ntc3 at the toledo track....i would love to try it out and im running out of time im planning to go to the glc and the sedan nats so i would love to try it out....my buddy scott said you gave it to him but he lost it.... he said his car worked real good ......i like that oh and hey greg whats up eh??
RICK ENDLER
Hot Bodies Racing
www.greathobbies.com
SKY RC
Exotek
endler is offline   Reply With Quote
Old 07-19-2004, 10:39 PM   #1519
Josh Cyrul's Avatar
striker - It usually lets the back end roll more and generates more rear traction...
TL_XXX-S_racer - I would use Paragon Ground Effects on foam and rubber tires on carpet. The Ground Effects is also good on foam tires on asphalt. I would use the FX-II on rubber tires and somtimes on foam tires outdoors... I've tried the new Paragon (oderless) but I don't really like it at all....
endler - I never raced a NTC3 so I have no clue on a set-up... Scott must be mistaken.....
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 07-20-2004, 10:02 AM   #1520
TeamButter's Avatar
Send a message via AIM to TeamButter
Default Tire Toss
Josh are you ging to the Norcca nats? If so, it will be round 2 of the tire toss nats!! LOL!!
Later,
Mike A
Xray / BMI Racing / KO Propo / Team Epic / Parma-PSE / High Velocity Racing / TeamButter / P3 Graphics / MDI Racing
TeamButter is offline   Reply With Quote
Old 07-20-2004, 01:37 PM   #1521
well i know you ran the electric so i thought he may have been right but i had my doubts....thanks anyway....see ya there anyway....
RICK ENDLER
Hot Bodies Racing
SKY RC
Exotek
Old 07-21-2004, 08:54 AM   #1522
Josh Cyrul's Avatar
TeamButter - I don't know about that one...lol.. I have to check and see. As far as the tire toss - I have a secret weapon now!! Yesterday I had my tonsils out and already I feel a ton better - I'm lighter now!!... I doubt that will help my arm throw farther but ya never know!!!
Old 07-21-2004, 08:55 AM   #1523
Josh Cyrul's Avatar
endler - No problem!! Walter Henderson should be there and he has nis TC3 pretty dialed in out there...
Old 07-21-2004, 09:02 AM   #1524
At the nats did most guys run spools or one-ways in the Xray?
Ozwald Bates is offline   Reply With Quote
Old 07-21-2004, 10:18 AM   #1525
The Evicerator
Whatup Josh!?!?
I just heard something that makes me think that no one will be winning a race on carpet for the next 5 years except for one guy....
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 07-21-2004, 11:09 AM   #1526
etzkev's Avatar
Send a message via AIM to etzkev
Originally posted by Evicerator
Whatup Josh!?!?
Haha
etzkev is offline   Reply With Quote
Old 07-21-2004, 05:28 PM   #1527
jag88's Avatar
Hey Josh, on the Xray FK setup sheet they show the option to put 'clips' on the front hinge pin mounts. I know that there not used for toe out. What effect would angleing the front hinge pins have on handling ?
Thanks.
jag88 is offline   Reply With Quote
Old 07-21-2004, 08:49 PM   #1528
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
you get my email Josh?
trackdesigner71 is offline   Reply With Quote
Old 07-22-2004, 11:01 AM   #1529
Josh Cyrul's Avatar
Ozwald - We all ran spools (I tested with a diff a little bit)....
Evicerator - LOL... I guess only time will tell!!!
jag88 - It's supposed to give the car more steering but I can't say I have ever tried it....
trackdesigner - Nope....
Old 07-22-2004, 11:08 AM   #1530
prodrive's Avatar
Default battery dilema
hi josh, do you find that smc's batts give you more advantage than other matched brands? i am confused on choosing so help me make up my mind
prodrive is offline   Reply With Quote
Josh Cyrul and T.O.P. Racing E.J. Evans Electric On-Road 18 11-29-2008 09:02 AM
josh cyrul at the 'birds b-man777 Electric On-Road 5 02-06-2008 09:23 AM
Josh Cyrul -> Novarossi rmdhawaii Nitro On-Road 11 09-20-2007 07:34 PM
josh cyrul and peak motors b-man777 Electric On-Road 43 02-15-2006 03:24 AM
Josh Cyrul on MTV2 teammediocre Chat Lounge 1 04-15-2005 05:46 PM
