Old 10-22-2008, 02:37 PM   #16
Regional Moderator
CarbonJoe's Avatar
Here's a link to a nice Excel spreadsheet I made for figuring out rollout:
http://www.rctech.net/forum/4792583-post5349.html
There is no easy or exact answer for the best or correct rollout for carpet. It really depends on the motor you are using as well as the track layout. The rollouts for brushed vs brushless are drastically different for the high turn motors. For example, for a CO27, we were usually running about 1.80 inch rollout (45.72mmpr), and for 17.5 brushless, we're about 2x that (3.60 inch rollout [91.44 mmpr]). The rollout is determined by the tire diameter, pinion, and spur size. It tells you how far the car will move forward for one revolution of the motor shaft. To get the huge rollouts for brushless, most guys are running 78 tooth spurs. For brushed, 88 tooth spurs.
Oh, and I'd also true your tires down some. They will chunk more at the larger diameters. A lot of 1/12 scalers start their rear tires at 1.75 inches (~44.5mm).
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 10-23-2008, 04:31 AM   #17
Triton3d's Avatar
Trader Rating: 17 (100%+)
But how do i know that motor X gives me more or less than motor Y..ect??? any formula??
Mike
Triton3d is offline   Reply With Quote
Old 10-23-2008, 07:27 AM   #18
Regional Moderator
CarbonJoe's Avatar
Mike
Mike -
Unfortunately, no. Ask others that are running similar motors if you decide to race. Otherwise, that is what practice is for. Get a number of pinions and try each one to see what the net result is. And don't forget that your rollout changes as your tires wear, so to remain consistent you will need to change gearing as the tires wear.
Old 10-23-2008, 02:20 PM   #19
Triton3d's Avatar
Hey Joe, how do you know that a Brushless motor has more rollout than a brushed motor?? isnt a shaft turn the same in each motor???
Mike
Old 10-23-2008, 02:40 PM   #20
Mike, the power curves are different between the types of motor. Brushless has heaps more torque but doesn't rev as high as a brushed.
Thin along the lines of petrol (gas) engines and diesel engines....same job, different power bands
TraceRacing is offline   Reply With Quote
Old 10-23-2008, 02:40 PM   #21
Regional Moderator
CarbonJoe's Avatar
Mike
The calculation of rollout has nothing to do with the motor type. As stated before, it is the amount that the car will roll forward given one revolution of the motor shaft. On a 1/12 scale car, the only things that matter (since a 1/12 scale car is direct drive) are the gear ratio (pinion/spur) and tire diameter. It is the power band of the motor (RPM, torque) that you need to figure out for each type of motor. This takes experimentation at the track to see what the best gearing (thus rollout) is for a given motor. Brushless motors tend to have more torque (and less RPM) than a brushed motor. So they need to be geared differently.
As a general rule of thumb, for a brushless motor, add gearing (bigger pinion, usually) until your lap times aren't getting any faster, or the motor starts to heat up above the manufacturers recommendation. Then back off one tooth on the pinion. Of course this assumes that you drive consistently each time on the track.
1/12 forum ovalnator Electric On-Road 46171 Today 07:52 AM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
Team Serpent 1:12 Car??? Apex Electric On-Road 38 01-23-2008 10:29 AM
Why touring? BlackKat Electric On-Road 130 12-31-2005 02:30 AM
1/12 Tc...why???!!! Evoracer Electric On-Road 52 09-12-2003 12:58 PM
KO Propo VFS-2000 ESC AGR#7 Electric On-Road 9 01-06-2003 11:35 AM
New MARCCA Track futureal Wisconsin & Illinois Racing 52 11-13-2002 01:53 PM
