Old 09-24-2003, 05:55 AM   #1
Exclamation new Orion Revolution (V2) Modified Motors
Team Orion's Revolution modified motors advance brush and endbell design to a new level. This completely new and revolutionary V2 technology is already taking the racing world by storm by setting new standards in power output, efficiency and longevity. Even though some concepts are revised versions of existing designs, many have never before been incorporated into R/C electric motors. This is evident in the fact that the Revolution has earned patent pending for 7 innovations but all in one patent!
Angled (V) brush orientation reduces brush bounce, resulting in increased brush and commutator life while extra contact area increases brush efficiency. This angle spreads the load between the motor spring and the brush guidance tube. Therefore spring tension can be reduced resulting in less friction, higher RPM, and increased efficiency.
Cylindrical brushes allow smoother brush overlap resulting in less arcing, which increases performance and reduces the likelihood of radio interference. Commutators develop fewer scars increasing the interval between commutator service and brush changes. Competition brushes last up to 12 times longer!
Precision CNC aluminium endbell provides additional cooling which extends the life of the motor's components. By lowering brush and spring temperatures, performance and consistency are maximized. Unlike plastic moulds that will wear out over time, CNC machining consistently produces the precision required in a hand wound modified motor. Round pure copper brush control tubes offer ultra low resistance, precision fit, and due to their close proximity to the commutator, increase brush stability.
Direct soldering reduces resistance resulting in more power and longer run times. Brush shunts and ESC wires are both soldered directly to the pure copper brush tubes creating a direct connection between your motor and electronics
Airflow cooling lowers operating temperatures. Strategically placed vents work in conjunction with the Ultra Flow motor can to circulate air through the motor. Lower motor temperatures reduce resistance, which increases power.
Inboard capacitor system with LED reduces the possibility of radio interference. A small circuit board containing three integrated capacitors is installed inside the endbell for extra protection. A small LED is also incorporated into the design to verify proper capacitor operation, indicate correct motor rotation, and help view the commutator conditions as the motor is running. It also looks extremely trick!
Intelligent anti-vibration spring system created with springs made of Inox steel formed in an unequal length coil to prevent vibration. The use of Inox, the most heat resistant steel, means consistent spring tension, hot or cold. Available in four different tensions, fine-tuning is easy to achieve
Zero vibration ball bearing system prevents vibrations from reaching the commutator. By mounting the endbell ball bearing between o-rings, ball bearing induced vibrations are prevented. The result is the elimination of power robbing brush bounce.
Swiss precision is recognized worldwide. The V2 endbell system is designed, developed, and produced in Switzerland.
Long life and power brushes available to suit any application. Two serrated face brush compounds are currently available with additional compounds and styles already in development.
Meets IFMAR, JMRCA, EFRA, BRCA, and ROAR specifications - suitable for use worldwide!
Revolution (V2) Modified Motors - Blue Endbell
29000 Revolution Modified Motor 6x1
29001 Revolution Modified Motor 6x2
29003 Revolution Modified Motor 7x1
29004 Revolution Modified Motor 7x2
29006 Revolution Modified Motor 8x1
29007 Revolution Modified Motor 8x2
29009 Revolution Modified Motor 9x1
29010 Revolution Modified Motor 9x2
29012 Revolution Modified Motor 10x1
29013 Revolution Modified Motor 10x2
29015 Revolution Modified Motor 11x1
29016 Revolution Modified Motor 11x2
29017 Revolution Modified Motor 11x3
29018 Revolution Modified Motor 12x1
Revolution (V2) Touring Motors - Black Endbell
29020 Revolution Touring Motor 10x1
29021 Revolution Touring Motor 10x2
29022 Revolution Touring Motor 11x1
29023 Revolution Touring Motor 11x2
29024 Revolution Touring Motor 12x1 HS
29025 Revolution Touring Motor 12x1 HT
29026 Revolution Touring Motor 12x2
29027 Revolution Touring Motor 13x1
29028 Revolution Touring Motor 13x2
29029 Revolution Touring Motor 14x1
29030 Revolution Touring Motor 14x2
29031 Revolution Touring Motor 15x2
29032 Revolution Touring Motor 16x2
Revolution (V2) Jukka Steenari Pro Edition Motors
29040 Revolution Steenari Pro Edition Motor 6X1
29041 Revolution Steenari Pro Edition Motor 7X1
29042 Revolution Steenari Pro Edition Motor 8X2
29043 Revolution Steenari Pro Edition Motor 9X2
29044 Revolution Steenari Pro Edition Motor 10X1
29045 Revolution Steenari Pro Edition Motor 10X2
29046 Revolution Steenari Pro Edition Motor 11x2
29047 Revolution Steenari Pro Edition Motor 12x1 HT
29048 Revolution Steenari Pro Edition Motor 12x1 HS
Revolution (V2) Atsushi Hara Pro Edition Motors
29060 Revolution Hara Pro Edition Motor 6X1
29061 Revolution Hara Pro Edition 7X1
29062 Revolution Hara Pro Edition 8X1
29063 Revolution Hara Pro Edition 9X1
29064 Revolution Hara Pro Edition 10X1
29065 Revolution Hara Pro Edition 12X1HT
29066 Revolution Hara Pro Edition 12X1HS
29067 Revolution Hara Pro Edition 12x2
29068 Revolution Hara Pro Edition 13x1
29069 Revolution Hara Pro Edition 14x1
Revolution (V2) Brushes
41090 Enduro Revolution (V2) Brush
41091 Sprint Revolution (V2) Brush
Revolution (V2) Springs
41390 Soft Spring Revolution (V2)
41391 Medium Spring Revolution (V2)
41392 Medium Hard Spring Revolution (V2)
41393 Hard Spring Revolution (V2)
snoboardin is offline   Reply With Quote
Old 09-24-2003, 06:00 AM   #2
JohnA's Avatar
Atsushi Hara showing great design taste as usual
JohnA is offline   Reply With Quote
Old 09-24-2003, 07:16 AM   #3
Horatio's Avatar
Talking
I've got to get me one of those!!! I think I'll have........the purple one!!
Horatio is offline   Reply With Quote
Old 09-24-2003, 07:19 AM   #4
Horatio's Avatar
I wonder how well these motors work? I wonder if the ultimate brushed motor would be:
Reedy Quad Magnet Can
Orion V2 Endbell
Trinity 'Flatwire' Armature.
Has anyone done this yet?
Old 09-24-2003, 07:36 AM   #5
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
any diffrence between the diffrent motors?
Calvin Ng is offline   Reply With Quote
Old 09-24-2003, 09:51 AM   #6
Calvin,
I saw a thread on Orion's site that "try's" to explain the difference.
http://www.team-orion.com/toptalk/sh...d&Number=11775
Thickness in wire on the Hara and Jukka editions and less efficent. See link for more details....
gtp03 is offline   Reply With Quote
Old 09-24-2003, 10:26 AM   #7
OSherman's Avatar
i was talking to someone who works for Orion this past weekend... told me that there is a difference in profile/shape of the armature blank between the Jukka and Hara...
Jukka is designed for offroad, Hara for onroad..
I have been a fan of Orion motors for a while now...looking forward to this one..
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 09-24-2003, 10:47 AM   #8
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I just wish that the touring series motors would go lower turns than 10. I dont see why they make a 6 turn for offroad, and only a 10 for onroad
Old 09-24-2003, 10:48 AM   #9
i already ordered a couple for myself....
Old 09-24-2003, 10:52 AM   #10
When are they going to be avalible?
Old 09-24-2003, 11:10 AM   #11
Trader Rating: 69 (100%+)
ive had good experience with orion motors - my old 11x3 chrome touring is still going strong for 1/12 duty. i hope the new series of orion motors will perform just as nicely. i was about to get a new motor (either a kr or d5), good thing i waited for this. ill just have to wait some more until it arrives in our lhs the downside is, what should i do with all my standard brushes ? i hope someone comes up with a jig to convert them into round brushes
marvi is offline   Reply With Quote
Old 09-24-2003, 11:25 AM   #12
i think they should be available mid oct . the earlier , the better!
Old 09-24-2003, 11:40 AM   #13
Looks like the Hara's go down to 6 as well:
Hopefully they will perform as good as they look. Wonder how long it will take them to put this technology into 19t and 27t spec motors (if ever).
Rampant is offline   Reply With Quote
Old 09-24-2003, 11:50 AM   #14
Roger's Avatar
Default Comm ??
How are you gonna cut the comm ?? Could we use our regular comm cutter or do we have to buy another lathe ??
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 09-24-2003, 11:57 AM   #15
mo
mo's Avatar
I believe it is still a standard sized armature so regular lathes will work.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
FS Team Orion Revolution Touring V2 7x1 Revolution Modified (2) darchard123 R/C Items: For Sale/Trade 1 01-30-2007 10:28 AM
***Orion Revolution Motors - CHEAP! FreqETag R/C Items: For Sale/Trade 3 09-30-2006 12:42 PM
Team Orion Revolution Modified Motor 8x2 - $25 shipped JKA R/C Items: For Sale/Trade 3 05-18-2006 05:21 AM
Team Orion Revolution 10x2 Modified Motor $30 shipped JKA R/C Items: For Sale/Trade 2 05-17-2006 04:06 PM
Orion Revolution v2 motors??? rayhuang Electric On-Road 47 03-27-2006 06:22 AM
