Old 01-16-2009, 09:33 AM   #16
John Tag's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Solara View Post
Going to use DUO 17.5 on up coming race, may I ask what is a good final drive for using on indooar carpet racing? And what temp? I am using it on Mi3.5 with Speed Passion GT V1.1...with software timing turning all the way up. And I think I would leave the mechanical timing on the motor in the middle position just to play safe..thanks.
3.80...160-165* Range
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 03-24-2009, 03:07 AM   #17
Does anyone know the ACTUAL motor timing on a DUO with endbell in the least advanced position? i.e. minimum timing is 0 deg or something else?
stocker is offline   Reply With Quote
Old 03-24-2009, 06:32 AM   #18
Trips's Avatar
Trader Rating: 16 (100%+)
Seems to be anywhere between 0 to 12 degrees, depending on who you ask...
The actual number is a closely guarded secret. One could probably learn the recipe for Coca Cola, the Colonel's secret blend of 13 spices, and the location of Jimmy Hoffa before finding out the actual timiing of a brushless motor.
MARSHAL!!
Trips is offline   Reply With Quote
Old 04-02-2009, 12:31 PM   #19
rack's Avatar
Trader Rating: 65 (100%+)
I just brought two 17.5 pulse ver 3 . I was thinking that these were the dou I was wrong. I got three laps in my sedan with the same gear ratio 4.1 as my hacker and the motor over heated. It was only 65 deg f. outside the track is large . I was very unhappy with this motor trinity over the years have been putting out good motor but not this one.
rack is offline   Reply With Quote
Old 04-02-2009, 12:56 PM   #20
Trader Rating: 16 (94%+)
The DUO timing settings are 0, 10, and 20-deg. Most come at 10-deg stock, but I have seen them at 0 and 20-deg as well.
kn7671 is offline   Reply With Quote
Old 04-02-2009, 01:07 PM   #21
Trader Rating: 18 (100%+)
I heard it was 10 degrees when set at 0.
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 04-02-2009, 06:43 PM   #22
its 12 degrees on the lowest setting. there is a bunch of jacked up info about but i measured it and it is the same as the no timing change of the speed passion motor. 12 degrees. it can be about .5 degrees off since the timing tree and be installed a little twisted but it will get you close.
12 22 32 is the degrees on each hole
e-team hobby: www.eteamhobbyplex.com
Fort Collins Colorado
Gorilla Boy Racing
mxzhonkey is offline   Reply With Quote
Old 04-02-2009, 09:28 PM   #23
adamge's Avatar
User failure isn't the same as bad product.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
BANZAI Motors Eddie Garrison Team and Company Discussions 11666 09-09-2015 01:43 PM
ROAR B/L motor Rules debate thread C_O_jones Electric On-Road 1080 01-21-2008 08:00 PM
ep4200 vs. intellect ib 4200wc b-man777 Electric On-Road 113 08-01-2007 08:02 PM
~~Getting out of Electric - CE Turbo 35GFX, Scalpel, Motor lathe, Novak, + more ~~ mbunker R/C Items: For Sale/Trade 58 06-16-2007 11:31 AM
trinity & BL (ahahahhahahhahha) utieh Electric On-Road 35 09-05-2006 11:27 AM
4 Brushless cars BL T4 BL B4 BL Mini-t BL Itsy Bitsy Spyder GS SUT Thunder Quake pcnutz R/C Items: For Sale/Trade 11 01-19-2006 10:59 AM
