Old 11-05-2008, 12:45 PM   #46
scootr117's Avatar
I just noticed the small rim BSR rime do both 2 and 3 bolt hubs.........they are being discontinued with the push for the large rim style........check them out for spares if needed.
Scooter EXperimental
RK Designs
CD SuperPro Motors
Mike Pulfer is my HERO....
scootr117 is offline   Reply With Quote
Old 11-05-2008, 12:52 PM   #47
reenmachine's Avatar
Trader Rating: 26 (100%+)
I called them a week or so ago and was told that that's an old photo and they don't have anything for the 2-bolt axle anymore.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 11-07-2008, 04:50 PM   #48
Default Help!
OK, I received the new wheels/tires today and there's a problem fitting the rears. Basically the way the bearings & diff interface with the drive-side wheel is completely different. There's a large, constant-diameter bore on the new wheels vs. a smaller, stepped bore on the originals. The originals also used flanged bearings. Is this as simple as a bearing swap? I've attached a pic so you can see what I'm dealing with.
Pete Waydo
Old 11-07-2008, 05:02 PM   #49
Send a message via AIM to Deznuts05
can you take a pic of the axle?
kinda hard to see how it all fits and what's not working
"Power is nothing without control" Ryuken
Deznuts05 is offline   Reply With Quote
Old 11-07-2008, 05:09 PM   #50
Don't mind the dirt -- it's fresh off the track...
But really, the problem lies with the differences within the wheels.
Pete Waydo
Old 11-07-2008, 07:15 PM   #51
I think the problem is that the current tires on the market don't work with your axle
Correct me if I'm wrong elders
Old 11-07-2008, 07:26 PM   #52
RCSteve93's Avatar
In that design the wheel is part of the diff. My BRP SC18 has the same design.
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 11-07-2008, 07:32 PM   #53
Yes, with the original wheels the thrust bearing and a couple other bits are on the outboard side of the wheel hub. Is this not the case with the newer setups? On a modern car can you take the wheels off without interfering with the diff?
In that case I'm SOL here...
Pete Waydo
Old 11-07-2008, 07:37 PM   #54
KHoff7's Avatar
Yes the wheels just unbolt and the diff held together by a diff nut independent from the wheels.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 11-07-2008, 09:00 PM   #55
Well, crap. I guess I'm thwarted as far as this approach to new tires goes.
Pete Waydo
Old 11-08-2008, 08:30 AM   #56
not really a newer axle could be had for pretty cheep
Old 11-08-2008, 02:38 PM   #57
RussB's Avatar
Send a message via MSN to RussB
is a whole new axle needed or just the diff hub?
RussB is offline   Reply With Quote
Old 11-10-2008, 08:00 AM   #58
Probably better off getting a new axle if I recall the older axles used some pretty primitive methods of clamping the left wheel.
Sneak peek at Tanner Stees bodies for worlds PIMP_9000 Nitro Off-Road 42 09-30-2008 07:56 PM
Pre-Worlds Again? FL State Race At Worlds Track Aug 21-22 AdrianM Electric On-Road 46 07-31-2004 08:06 PM
Speedlinehobbies - Official shop at the Worlds & Warm up Speedlinehobbie Florida Racing 9 05-06-2004 10:26 PM
2004 On Road Worlds Warm Up & Worlds At Full Throttle Speedway AdrianM Electric On-Road 418 05-05-2004 10:38 AM
Un-official Race Report - Off Road Worlds @ Minnreg Racer_Chick Racing Forum 25 11-29-2003 06:18 PM
