Old 10-16-2008, 09:54 PM   #1
poochy's Avatar
Default tc5 pull left problem puzzling me
i cannot figure out this pull/push left on hard throttle problem im having--ideas?
poochy is offline   Reply With Quote
Old 10-16-2008, 10:06 PM   #2
Airflow's Avatar
Loosen the front ball diff.
Airflow is offline   Reply With Quote
Old 10-16-2008, 10:11 PM   #3
poochy's Avatar
slipper spool front/diff rear
Old 10-16-2008, 10:14 PM   #4
Airflow's Avatar
Try slightly loose front ball diff.
Old 10-16-2008, 10:16 PM   #5
poochy's Avatar
no balls in the slipper sppol
Old 10-16-2008, 10:17 PM   #6
Dave Bowser's Avatar
Trader Rating: 51 (100%+)
your slipper spool is loose i think you have to check that every run or use red lock tight
RCAmerica, X-Ray, Hudy, Ko Propo, Protoform, PRS, Jaco, JConcepts, SXT, RC3 Grafix, Kool-Aid, P-Nut, NEXT, www.SuperiorHobbies.com
We're going to skate to one song and one song only!
Dave Bowser is offline   Reply With Quote
Old 10-16-2008, 10:20 PM   #7
poochy's Avatar
how can i tell if the slipper loose-should i be able to the spin the wheels in opposite direction easily?
Old 10-16-2008, 10:29 PM   #8
no it should be pretty tight
Old 10-17-2008, 12:40 AM   #9
S_fender's Avatar
If you have the ITF top plate : Check out the 4 rear screws.
It's happen to a friend : One screw was tweaking the car.
S Fender
S_fender is offline   Reply With Quote
Old 10-17-2008, 01:13 AM   #10
Drifting101's Avatar
Is i balanced left to right?
and stupid q have you double checked your set up is equal left to right?
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 10-17-2008, 01:42 AM   #11
Default TC5
Some suggestions.
If you have a setup station make sure you have equal toe-in left and right on the rear.
I have noticed some arm mounts (blocks) give incorrect toe-in.
Make sure you have the same rear degree rear hub carriers left and right ( 0 or 1 degree)
Check droop settings are correctly done.
Try to keep the thread shock collar equal left and right.
Is your car weight balanced left to right about the same?
Make sure your wheel bearings are free and including the diff bearings.
Is your servo centering correctly?
Are your Tyres same diameter each side and glued well to the wheels?
Shocks working well smooth -no air bubbles? ...try softer springs too
Hope this helps
yeahyeah is offline   Reply With Quote
Old 10-17-2008, 01:58 AM   #12
Airflow's Avatar
A misbehaving TC4 was corrected by just loosening its front ball diff (not too loose though). Until now, it tracks straight. Its been running on dusty
tarmac ever since.
Old 10-17-2008, 05:57 AM   #13
poochy's Avatar
guys everything here checks out---im puzzled still-----i do not understand how the 4 rear screws on the top deck can cause the car to kick left on hard throttle---please elaborate
Old 10-17-2008, 06:07 AM   #14
poochy's Avatar
as for the rear hub--i will swap them around later-if they dont mismatch then ill expect a right kick after the swap
Old 10-17-2008, 06:59 AM   #15
Default tc5
Also if you are using the battery strap when you fasten try to get it just right -not too tight as it does bend and twists the chassis.
Check each shock bushing is fastened well
Front and rear arms not binding?
Problem with starting engine - Pull start Aceboy Electric Off-Road 17 05-02-2006 04:52 AM
Futaba 2pl problem scott_g Electric On-Road 4 05-18-2005 12:17 AM
Help: When I pull the pull starter, wheels of car move racer rich Nitro On-Road 3 01-04-2004 07:29 PM
Any 3PK owners have glitching problem? Aku-Man Electric On-Road 31 06-04-2003 04:51 PM
Newbie Help - Problem Priming Engine (HPI Nitro MT) joshb Australian Racing 13 12-02-2002 02:47 AM
