Old 05-15-2014, 11:39 PM   #901
EDWARD2003's Avatar
Originally Posted by PutAwayWet View Post
Looks pretty quick to me.
Not to say that the high voltage high turn combo isn't interesting. But slow, it's not.
https://www.youtube.com/watch?v=DJ0uWybYH1Q
s
It's fast alright, but the video you're watching is of the top tier drivers at that track. So their batteries and motors are being pushed to the limits.
EDWARD2003 is offline   Reply With Quote
Old 05-16-2014, 02:54 AM   #902
Originally Posted by EDWARD2003 View Post
I mentioned the chances of breaking is minimal.
Tire wear
Okay, I would say tire wear is reduced slightly. But, I can run one set of tires in a day 3 heats and qualifier without wearing them down to the rim. That's with tires trued at 44 front and 45 rear. Total laps would be in the 200-250 range before the tires are carpet worthy.
The above statements are just observations I have made while running both classes.
Yes but compared to what 1 cell version of 1/12th scale? Based on the video and what I've seen in F1 it looks like 2 cell 21.5 1/12th scale is moving at mod speeds. At the very least it looks significantly faster than 1 cell 13.5.
Old 05-16-2014, 03:13 AM   #903
howardcano's Avatar
Trader Rating: 35 (100%+)
21.5/2s gives almost exactly the same power as 10.5/1s.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 05-16-2014, 05:45 AM   #904
Chaz955i's Avatar
Thanks for your input InspGadgt
I too race F1 2 cell 21.5, but on foam tires . Obviously, you cant compare lap times with rubber tire F1 with 1/12th. However, I can tell you this. I run both F1 foam and 1/12th at the same track using the same motors. I can say with confidence the lap times only differ by 0.5-0.7 a lap. Yes, the 1/12th much lighter, faster and nimble in the infield, but the speed difference isn't all that much on the straight. The F1 in the infield is quite cumbersome and not as nimble in the handling department which results in slower lap times. But, it's straightway speed isn't far off from 1/12th. That being said, from my experience running F1 foam, I think it would easy for someone to transition from F1 21.5 to 1/12 21.5 with relative ease. Also, if someone can drive a F1 21.5 rubber with ease than 1/12th 21.5 will be a breeze to handle.
I can say I've broken more parts on my F1 than my 1/12. This is inherent with an open wheel design such as F1. The only part I've broken on my 1/12 is a pillow ball on my 1/12th. But, every driver is different and every circuit is different. I run on an outdoor asphalt track with no wood boards, just concrete curbing.
Tire wear
Sounds like a fun class. I'd love it if the standard was 2S for anything smaller than 1/8th scale in electric on-road.
Chaz955i is offline   Reply With Quote
Old 05-16-2014, 06:49 AM   #905
Zerodefect's Avatar
I had no idea that brushless goes all the way down to 25.5 now.
Zerodefect is offline   Reply With Quote
Old 05-16-2014, 06:53 AM   #906
higher voltage the better for all classes as far as i can see, also current voltage limitations also create battery wars with people looking for any edge whereas higher voltages can get away with lower spec batteries, for instance in the 1/10 pro 10 class i run in if you dont have a 90c 2s lipo your gone before you start whereas a 40 to 60c 3s or heaven forbid 4s would suffice, yeah sure after a while it would probably happen again with 3 or 4 s in this situation but would not be as critical as in 2s 1/10 classes. also if people reckon 2s 21.5 is too fast for novice 1/12th fair enough then bring in control brushed mabuchi motors or something like that, this will also be cheaper to run and closer racing and surely slow enough, if its still too fast then simply limit the gearing. maybe i am wrong so don't crucify me for my opinion but it looks like i am not alone in believing in higher voltages for 1/12th and other classes, changing is the hardest bit because everyone is invested in there own classes, and we don't like change.
the wheels can only turn slowly on this one i think.
cheers
oldenuff
P.s zerodefect has posted while i was creating my post with some great info about 25.5 t motors being available , this is also another option if 21.5 is too fast
oldenuff is offline   Reply With Quote
Old 05-16-2014, 06:57 AM   #907
EDWARD2003's Avatar
Brushless motors go down to 30.5 and they are perfect for 1/12 beginners. I'll take some video of them this weekend for you. I'll also take video of 21.5 1/12th and 21.5 F1.
Old 05-16-2014, 07:02 AM   #908
theproffesor's Avatar
Trader Rating: 58 (100%+)
I guess youve been hiding under that off road rock to not know that you can get 25.5 motors.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 05-16-2014, 07:12 AM   #909
Thumbs up
what the a 30.5t brushless motor surely that would be slow enough but i have never seen one where i live ( Australia ) but we do usually get things last...you see guys there is a solution!
Old 05-16-2014, 07:14 AM   #910
Send a message via MSN to Mark Stiles
What do people think are the most prevailent factors which influence the whether somebody decides to try racing 1/12 scale or not?
I guess the answers to this question could be different depending on whether the people in question are already experienced RC competitiors, or are completely new to the world of RC.
If you were stood on the outside and looking to come into 1/12 scale, what is attractive about it and what puts you off?
Yokomo - Reedy - Protoform - A-Paint - CML Distribution - Racer Magazine - Zen-Racing - MomentumRC
BRCA 1/12 Electric Circuit Section Chairman
Mark Stiles is offline   Reply With Quote
Old 05-16-2014, 07:18 AM   #911
Zerodefect's Avatar
Yup. Open 1/8th E, and 1/5th scale SCT.
Old 05-16-2014, 07:28 AM   #912
EDWARD2003's Avatar
http://www.redrc.net/2014/02/kawada-...shless-motors/
Kawada and a few other companies offer 30.5. The speed is perfect for beginners. Everyone runs the same motor, same timing, same lipo, same tires, same rollout and same chassis Kyosho 1/12 LM. The racing is extremely close regardless of your expertise. Close racing makes for great fun and builds the confidence in the drivers ability to navigate the course. Which will give them confidence in moving up to faster racing classes.
Old 05-16-2014, 07:30 AM   #913
howardcano's Avatar
higher voltage the better for all classes as far as i can see... higher voltages can get away with lower spec batteries
This doesn't apply in our case. The 2s batteries used in 1/12 scale are the same size and weight as 1s cells, so the energy storage is the same. If the motor wind is changed to maintain the same power level (i.e. 1s/10.5 versus 2s/21.5) then the battery will see the same C-rate load.
The only thing that the higher voltage buys for performance is that lighter gauge wires may be used. For a 1/12 scale car, that's a good thing!
Howard Cano
Old 05-16-2014, 07:37 AM   #914
Zerodefect's Avatar
I'm new.
+ultra fast
+clean
+indoor
+cheap
+attention to detail is fun tuning
+small tool boxes (my 5th scale box is bigger than a Smartcar)
+world class racing from the very beginning of RC.
+cool looking cars
+stupid easy repairs and dissassembly
-hard pileup crashes
-rules
-rules changing often can be annoying (1/8th has been the same for about my entire life)
-attention to detail can get tedious eventually
-tracks never have elevation changes, kinda boring
-chemical smells (back in the day)
The speed is a plus to us. We're hoping that off road will seem slower when we return to it in the spring. The sooner I can get to mod without being a hack or roadblock the better.
Old 05-16-2014, 07:42 AM   #915
EDWARD2003's Avatar
1 - close racing, cool looks and handling.
2 - simple maintenance
3 - setup and build assistance (my first set of tires were ruined because I glued them like sedan tires #fail)
4 - cost of the kit, motor, esc, battery, tires, body.
5 - everyone following the rules
6 - everyone helping each other out i.e setup assistance ect.
1/12 forum ovalnator Electric On-Road 46189 12-15-2017 08:13 AM
1/10th pan car Taz_S Oval, Larger Scales and More 16138 09-25-2014 10:03 AM
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 09:27 AM
new 19t motor from peak sukh Electric On-Road 77 07-13-2007 03:12 PM
The future of RC? - New Radio Technology stuff Electric On-Road 275 11-09-2005 01:49 PM
The Future Of The Nct....... Mike Dana Northwest Racers 122 09-02-2004 04:23 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
