Old 12-01-2008, 09:09 PM   #541
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Damn fine wiring job. Neat as a pin.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 12-01-2008, 09:28 PM   #542
Looks really good there Trailranger
Old 12-01-2008, 10:35 PM   #543
trailranger's Avatar
Thank you,
I even wired the LiPO from individual cells. I would have solderd the cells in RX pack too but for $7, I didn't mind it coming completed. . Still a few things left like Carbon Fiber Sticker for the LiPO Pack and rasing the O-ring snap stand-offs with a 6mm spacer so the O-ring will not pop off. I still need to paint a new body and buy some new body post.
"If everything seems under control, you're just not going fast enough." - Mario Andretti
trailranger is offline   Reply With Quote
Old 12-01-2008, 10:46 PM   #544
Shadows's Avatar
Trader Rating: 23 (100%+)
all the above layout looks great for straight pack designs... how bout for t-bar cars?
Shadows is offline   Reply With Quote
Old 12-01-2008, 10:51 PM   #545
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by trailranger View Post
Thank you,
Nicely done! What class are you racing and where did you get the cells to make the pack? Here is Oz there is only mod 12th so keeping up with 4 cell 5.5s is going to be a stretch with any of the available 3.7v lipos. 6300mah on the other hand should be plenty to propel a low wind motor (a 3.5 @ 3.7v should keep up with the 4.8v 5.5 I'm told) for 8 mins, that C rating might not work in mod tho
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 12-01-2008, 10:58 PM   #546
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Thats pretty ! All u need now is an angel on the top and you are all set for Sants!
John St.Amant is offline   Reply With Quote
Old 12-02-2008, 12:18 PM   #547
The pack is rated for 95A continous so I guess it would work in mod but I do not know how accurate the rating is after SMC pointed out ratings were just stickers. If you went used a 3.5 Velociti Light motor maybe the amp draw will be in check and the car light. Even if the battery performed at a 10C level, that would still be on par with NiMH. So even if the battery was a little on the weak side for max amps, the payoff could be at the 6+ minute mark with 1700mah more than the NiMH guys and 2300mah more than the SMC guys.
I'll have one of the local guys GFX my pack at 30 or 35A.
Old 12-02-2008, 12:28 PM   #548
I ran single cell with a 3.5 Novak a couple years ago. The 10C pack I was using worked fine and ran 8 minutes easily.
I have 35A numbers from my SMC pack at home so maybe I'll post them when I get a chance.
Your average current with a 4000 pack will need to be less than 35 amps to make time in 12th. Some of the peak currents will be pretty high in mod but I didn't see any problems with the pack I had.
Fred_B is offline   Reply With Quote
Old 12-02-2008, 07:51 PM   #549
Trader Rating: 26 (100%+)
anyone ever use a jr 3650 servo. i bought one today and noticed its quite a bit smaller than a futaba 9602. just wanna know if its a good servo
eddie10 is offline   Reply With Quote
Old 12-02-2008, 08:26 PM   #550
yep, the jr 3650 (and also the 3550) are excellent servos perfectly suited for 1/12th. only drawback, they are narrower than most others and so some cars are not predrilled to fit them. The notable exception is the CRC cars which are designed for jr servos. they also drill their chassis for the spacing of the more standard sized servos such as futabas, but the preferred choice for CRC cars is actually the jr's.
vafactor is online now   Reply With Quote
Old 12-04-2008, 08:35 PM   #551
PartTime's Avatar
I got to see my first single cell car run wed. He was running a smc pack with 13.5 motor. The other two cars were 17.5/4 cell. One had 3700 and the other 4600's. The 4 cell cars crushed the lipo on the infield and had just a touch more topend. 1 min in the round cells settled down and they all had the same top end but they still left the lipo for dead in the infield. 6 mins they slowed to the same pace. The last 1.5 mins the lipo had the advantage on the infield and maybe a touch down the straight. And enough to really reel them in at the end.
From what I saw
PRO's: the same power from start to finish
CON's: Needs more punch.
Maybe a 10.5 would be a better match ??
DK
PartTime is offline   Reply With Quote
Old 12-04-2008, 09:36 PM   #552
The new version of the BMI has a slotted chassis for the servo mount to fit more sizes
Old 12-04-2008, 10:02 PM   #553
CraigM's Avatar
What capacity was the pack you used?
Old 12-04-2008, 11:30 PM   #554
10.5! 10.5!
Old 12-05-2008, 03:42 AM   #555
hanulec's Avatar
Trader Rating: 27 (100%+)
did you run with a receiver pack or voltage booster? if so, which one?
what speedo?
what 13.5T motor?
i'm about to kick off some 1c SMC testing today in both 1/12th and WorldGT trying receiver packs and voltage boosters (my LVBoost from dimensionengineering just showed up).
From what I saw
DK
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
1/12 forum ovalnator Electric On-Road 46174 Today 10:07 AM
1/10th pan car Taz_S Oval, Larger Scales and More 16138 09-25-2014 10:03 AM
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 09:27 AM
new 19t motor from peak sukh Electric On-Road 77 07-13-2007 03:12 PM
The future of RC? - New Radio Technology stuff Electric On-Road 275 11-09-2005 01:49 PM
The Future Of The Nct....... Mike Dana Northwest Racers 122 09-02-2004 04:23 PM
