Old 11-18-2008, 03:38 PM   #421
PartTime's Avatar
Thats pretty cool. Should be small enough to fit just about anywhere on a 1/12th. Good price too.
DK
PartTime is offline   Reply With Quote
Old 11-19-2008, 12:24 PM   #422
trailranger's Avatar
I got my 3.7V 6300MAH 95A constant pack TODAY!!!
I won't be doing any 1:12 testing soon, but I will test 1:10 Oval with a 13.5 Motor this weekend. The 6300mah pack does fit into my CRC 3.2 by the slimist margin. The PCB terminal board for the solder tabs added an unexpected 1mm to the length of the pack. I will be testing the 3.7V with the $5 5V modual and no RX pack unless glitching occurs becuase of the 1.5A max current of the modual. In which case I have a 4.8V 900mah AAA RX pack that will use.
The pack came as a 11.1V 2100 pack, and I rewired the pack into 3.7V 6300 (DO NOT ATTEMPT UNLESS AWARE OF THE DANGERS OF LIPO FIRES!) I would have gone with the SMC pack, but I was under the impression when I placed my order the day before the Order Now announcement from SMC that the packs were still not ready. The hassle of taking apart a LiPO pack was enough to discourage me from ever doing that again. I would compare the disassembly process to being about as risking as the time I had to drive through a UXO and Mine field in Iraq or when I pulled the pin on a gerande. But I saved about $40 in the process and my nerves are still good . The individual 2100 cells are $20 a piece, and another $30 to assembley from BatterySpace.Com.
The battery had a PCB terminal board for soldering the copper tabs. I strongly reccommend that for any future rules concerning 3.7V batteries to require a PCB terminal board to protect the battery from impacts and abuse. My PCB was designed for 11.1V volt, but once I inverted the middle cell and folded the tab the opposite direction, the PCB board worked perfectly for 3.7V. This saved me a trip to Radioshack for a project board.
"If everything seems under control, you're just not going fast enough." - Mario Andretti
trailranger is offline   Reply With Quote
Old 11-19-2008, 12:31 PM   #423
reenmachine's Avatar
Trader Rating: 26 (100%+)
Hey Trailranger -- the quote "If you're under control, you're not going fast enough" is from Parnelli Jones!
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 11-19-2008, 12:36 PM   #424
JayBee's Avatar
Trader Rating: 31 (100%+)
Maybe Mario got it from Parnelli
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 11-19-2008, 12:36 PM   #425
Ahh shucks, well mario still said it just maybe not first
Old 11-21-2008, 07:29 AM   #426
nrtv20's Avatar
I remember a few pages back we talked about not being able to stuff enough wire in a can to create anything higher then a 21.5 motor, How do they make crawler motors and has anyone tried them with 7.4v 2 cell lipo?
Edit: the crawler motor is a 21.5
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 11-21-2008, 07:58 AM   #427
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Well.. I'm no expert but, 21.5 is a crawler motor. I use am outrunner motor myself . It's a Gust 1100k/V motor. As far as windings, I cant imagine needing any high amp draw applications for such a high wind and perhaps if more winds were necessary , they should use smaller guage wire. Maybe we should just use 540J Mabichi's.
John St.Amant is offline   Reply With Quote
Old 11-21-2008, 08:00 AM   #428
Yeah .. I think I'm gonna just use a flight pack.. fudge it in there somewhere.
Old 11-21-2008, 08:15 AM   #429
sportpak's Avatar
There is a difference between the pro 21.5 and crawler 21.5. I'm not sure what exaxctly it is, but a crawler motor must be used with a crawler esc for proper operation. It might have something to do with the drag brake. I run brushed in my crawler, so I'm not into all the details.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 11-21-2008, 08:20 AM   #430
Crawlers.. hmm,, I'm currently working on something special for us rocky horrer guys. Very trick and brushless powered, but not necessarily just so. Hope to have something available soon!
Old 11-21-2008, 08:51 AM   #431
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by John St.Amant View Post
Sanyo got out of making the cells we use for toy cars because we are only a fraction of a percentage point of the market for those cells. Now that industry has stopped using them for cordless drills and hand held vaccuums, the need for Ni-Mh cells is not worth it for them to make the cells just for us.
Mikita... Millwaukee... Craftsman... were the big purchasers of sub "C" cells and are no longer wanted by them. It's all about Li-Po's now ....And soon, something else... Get used to it and get over it! 7.4v is too much juice for the average racer in 1/12, almost with any motor. We need to use what cells are mainstream or the quality and cost will be compromised. BIG TIME!
Just buy one pack ,,, single cell lipo and be done with it. Ah'ite!?
Wrong. Go to any home depot and look at all the NICAD (!) powered drills for sale. The lithium drills are $50-100 more than the round cell stuff. Mostly tool freaks and tradesmen are buying lithium tools right now.
Old 11-21-2008, 08:57 AM   #432
Thats right , go look at them..... last years models!
All the new stuff is either Li-po or Li-Ion.
Old 11-21-2008, 08:58 AM   #433
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
gotta friend who will be testing that 1cell lipo deal. see how that goes. if i wasnt pondering a race myself, i'd prolly go watch. curious times for 12. or any1 class on foams, as most associated a higher tire bill with foam over rubber. granted i've always been an advocate for harder tires anyway. sadly that ship has sailed.
R
UltegraSTI is offline   Reply With Quote
Old 11-21-2008, 10:08 AM   #434
R
I got flamed almost to death for bringing it up a couple of months ago, but I'd still love to see a brushless, lipo, rubber tire 1/12 pan car...
Pete Waydo
Old 11-21-2008, 03:54 PM   #435
wingman2's Avatar
Not fussed about the LiPo bit, but brushless and Rubber tyres could work good. I would n't mind getting a set of rubber tyres for my 12th car and seeing how they go. Our local club runs a Winter Series on a large carpet and the grip levels only get to about a 'moderate' level, so may not be good there, but at a National were the grip level is 'High', they could work good! We'll see. Cheers, Chris.
wingman2 is offline   Reply With Quote
1/12 forum ovalnator Electric On-Road 46184 Today 09:37 AM
1/10th pan car Taz_S Oval, Larger Scales and More 16138 09-25-2014 10:03 AM
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 09:27 AM
new 19t motor from peak sukh Electric On-Road 77 07-13-2007 03:12 PM
The future of RC? - New Radio Technology stuff Electric On-Road 275 11-09-2005 01:49 PM
The Future Of The Nct....... Mike Dana Northwest Racers 122 09-02-2004 04:23 PM
