Old 09-23-2003, 08:31 AM   #1
Rod M's Avatar
Default TA04 and saddle packs
I have a fully hopped up TA04 and I don't like using the stick packs,
this chassis is advertised as a saddle pack chassis for the TA04,
http://www2.towerhobbies.com/cgi-bin...?&I=LXWT99&P=7
questions:
1, will going from stick to saddle pack on the TA04 improve the handling (roll center) of the car?
2, I am assuming that some sort of velcro is used to strap the batterys to the chassis, is this right?
3, can I dissamble my current stickpacks and reuse them in saddle configuration?
4, are there any other benefits/disadvantages of doing this?
thanks
Rod M is offline   Reply With Quote
Old 09-23-2003, 09:17 AM   #2
JohnA's Avatar
Default Re: TA04 and saddle packs
The weight distribution will be better with saddles than sticks so the car will handle better.
You can use tape, velcro or modify another manufacturers holders, I've seen Xray and Schumacher bits used to good efect.
Yes
You can equalise your cells if tey are in saddle format.
thanks [/B][/QUOTE]
JohnA is offline   Reply With Quote
Old 09-24-2003, 09:14 PM   #3
Rod M's Avatar
thanks JohnA,
what does "equalise your cells" mean?
Old 09-25-2003, 02:46 AM   #4
JohnA's Avatar
You can get a device called an equalising tray. Try doing a search on 'realtime2' that's the trinity branded one.
Basically this allows each cell to be discharged equally where with a stick pack you cant do this as you cant get a connection on the cells in the middle of the pack.
Here's a pic:
TA04 Pro Saddle todd8603 R/C Items: For Sale/Trade 4 10-16-2006 02:44 PM
TA04 saddle pack grpahite chassis hardrider R/C Items: Wanted to Buy 5 04-28-2006 11:05 AM
Can You Use Saddle Packs , TA-04? Sushi Man Electric On-Road 3 09-13-2005 01:38 AM
Tamiya TA04 Saddle Pack Chassis and upper deck RCGaryK R/C Items: For Sale/Trade 2 10-13-2004 08:12 AM
TA04 Carbon Saddle Chassis Alvin Singapore R/C Racers 12 02-13-2002 10:53 PM
