Old 10-15-2008, 09:14 AM   #1
doki71's Avatar
Default x-ray t2'008 gear ratio
good day guys! just new with this sport, i have x-ray t2'008 and i was hoping you can help me out with what final drive ratio im suppose to use in a 27turn rebuildable motor and a 23turn rebuildable motor..? thanks in advance and God bless!
doki71 is offline   Reply With Quote
Old 10-15-2008, 03:43 PM   #2
track-attack15's Avatar
That depends on what kind of track your running on but you could just get a set of pinion gears and make sure the motor stays at about 160-170 degrees tops.
track-attack15 is offline   Reply With Quote
Old 10-15-2008, 04:19 PM   #3
doki71's Avatar
thanks!
ill be running on an asphalt track.. maybe you could tell me whats the average ratio or at what ratio to start from.. i set up the fdr at 6.5 with the stock 27turn rebuildable motor..
Old 10-15-2008, 10:59 PM   #4
Goingfast's Avatar
Trader Rating: 29 (100%+)
160-170 too hot for stock 27T brushes motor...
The best way is to find the right gearing , What other racers their FDR is and go from there...
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 10-15-2008, 11:02 PM   #5
Goingfast's Avatar
Originally Posted by doki71 View Post
thanks!
dont' let the motor get over 150 deg. use the motor fan cooler,help
Run the car around the track three ot four times and check the brushes, to make sure the brushes is not turning colour or blue....( Blue is burnt)
Old 10-21-2008, 07:37 PM   #6
doki71's Avatar
thanks a lot guys.. knowing the temperature of the motor is another problem for me, i dont have the device to monitor it.. hehehe!
regarding the fdr of other drivers, they won't tell me. they say they don't know. they just experiment on their spur and pinion but they again wont tell what they use..
im from a tropical country so its hot in here.. ill try get those cooling fan.
Old 10-21-2008, 08:06 PM   #7
geeunit1014's Avatar
only if you want to be slow... 170 is fine after a 5 min run. It also depends on the motor somewhat. With trinity motors, over 180 is bad.with the reedy motors, they run hot (200ish).
My local track is a 110ft straight, and i run a 6.6 FDR.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 10-22-2008, 04:24 AM   #8
Szimon's Avatar
HI,
I use 17,5T on a carpet and my final ratio is around 4,45. (34T pulleys, 78/30)
I think you should use smaller spur gear (~74) for lower ratio.
Szimon is offline   Reply With Quote
Old 10-22-2008, 05:00 AM   #9
Essnowyt's Avatar
Send a message via AIM to Essnowyt
If you have a blue cobalt motor, start at a 7.5 ratio. If you have a green monster motor, start at a 8.0 ratio.
Sorry,I don't have info for the 23turn motors.
Hope that helps.
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 10-22-2008, 06:40 AM   #10
doki71's Avatar
thanks a lot for all the infos.. now i have an idea on where to start. really a big help.
general gear ratio question TRF-Powered Electric On-Road 10 06-09-2014 12:32 PM
Newbie Questions on Gear Ratio and Rollout SlamMan Electric On-Road 16 07-26-2006 09:20 AM
What's a good gear ratio for the RDX? teetwo Electric On-Road 2 01-03-2006 07:36 PM
Internal gear ratio difference advantage GTO2 Rookie Zone 1 05-25-2004 03:37 PM
Stock gear ratio on e-maxx? seriousre Monster Trucks 2 10-04-2003 09:56 PM
