Old 10-12-2008, 08:50 AM   #1
Default Esc capacitor newbie needs help please
hey there im pretty new to electric on road but im having heaps of fun! ive got a tt01 with a 12t reedy worlds in it hooked up to a nosram magnum reverse esc http://www.nosram.com/products.asp?id=51 i was wondering weather or not i should or am even able to put a capacitor onto my esc, i heard that it makes it run with less heat and gives better acceleration but im not sure weather or not u can do it because it s a micro chip esc and the battery leads are inside the esc which i cant see any screws to open it up and it is a reverse esc and i want to keep it with reverse
thanks for any help
scottwhat12 is offline   Reply With Quote
Old 10-12-2008, 09:05 AM   #2
sosidge's Avatar
If the ESC would benefit from a power cap, the manufacturer would supply one or suggest one as an option.
If Nosram don't supply one there is probably no need for it.
Old 10-12-2008, 04:44 PM   #3
if i put 1 on anyway do you think it will make a difference?
Old 10-12-2008, 04:48 PM   #4
trailranger's Avatar
If you use Dean's plugs that would be a decent spot to solder a capacitor.
trailranger is offline   Reply With Quote
Old 10-12-2008, 04:52 PM   #5
yea i use deans. i was thinking of splicing them sumwere along the lead from the esc battery cable but do you think i could do it straight onto the deans ?
Old 10-12-2008, 06:27 PM   #6
If you solder the Capacitor to the Deans plug, the capacitor will need long leads so that the heat shrink can be used to cover the deans solder tabs. Both the wire and capacitor leads will need to pass through the heat shrink piror to soldering.
After soldering you can use electrical tape or 3/4" ~ 1" heat shrink tube to secure the capacitor to the wires.
I don't have any pictures, but I have seen it done.
Old 10-12-2008, 06:45 PM   #7
crazy4wdracer's Avatar
Trader Rating: 25 (100%+)
Send a message via AIM to crazy4wdracer
They sell them here:
http://cgi.ebay.com/Power-Capacitor-...742.m153.l1262
crazy4wdracer is offline   Reply With Quote
Old 10-12-2008, 08:38 PM   #8
double post....arg
Old 10-12-2008, 08:39 PM   #9
Originally Posted by crazy4wdracer View Post
Any high grade Low ESR capacitor will work. Just match the capacitor voltage to your batteries.
6.6V Cap is for 4-Cell NiMH
10V Cap is for 4cell, 6Cell or 2S Lipo
16V 3S Lipo and lower voltage
25V 5S Lipo and lower voltage
Any capacitor in the 1500uf to 10,000uf range will work.
FS:LRP Quantum 2 ESC, LRP Runner, Kopropo VFS-1 PRO ESC, & Kopropo 2143 digital servo jlee777 R/C Items: For Sale/Trade 9 12-04-2006 06:21 AM
question about esc zack221 Electric Off-Road 4 07-19-2006 11:08 PM
ESC burning hot, car stalls uniquexme Rookie Zone 12 04-12-2006 02:39 AM
FS: New and Used Highend ESC jlee777 R/C Items: For Sale/Trade 12 11-01-2004 11:06 AM
Futaba Plug melting, ESC Qs Vortex Buggy Electric On-Road 2 09-09-2003 12:48 AM
