Old 10-11-2008, 10:04 PM   #1
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Default Spur and Pinion Math
I just want to see if this holds water.
P = Pitch
Diameter of the Spur = D, Number of teeth on the Spur = N.
diameter of the Pinion = d, Number of teeth on the pinion = n.
D = N/P for the working diameter of the Spur
d = n/P for the working diameter of the Pinion
Radius = D/2 or d/2 for Spur and pinion
My internal ratio for my car is 2.0588.
FDR = (Spur/Pinion) * 2.0588
If the distance between my spur gear center and the center of my motor shaft is 1.125 inches, I need a pinion and spur that the combined working radii are equal to 1.125 inches +/- the extra 1/8 inch my motor can still be adjusted. I calculate the the radius of the Spur, the radius of the pinion and add them together. My final number should end up between 1 and 1.25 inches. In my case I also had to end up with an FDR of 3.4 to match my 17.5 brushless.
so...
((93/64)/2) + ((56/64)/2)) = 1.164" which is between 1 and 1.25 inches.
and
(93/56) x 2.0588 = 3.419 FDR
Seem reasonable?
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 10-11-2008, 10:07 PM   #2
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
P = Pitch
so...
and
Seem reasonable?
for the E4 you need a total teeth count (pinion and pur) for 64 pitch between 137 to 140 to have a good mesh , so you will need a 88 spur and a 52 pinion to be in the 3.4 fdr range
for 48 pitch you need a total teeth counf of 105 teeth.
Old 10-11-2008, 10:29 PM   #3
for 48 pitch you need a total teeth count of 105 teeth.
Thanks! I do need to research the mesh count. The only thing I stumbled across tonight was that 48 pitch gears need at least 17 teeth on the pinion to make effective contact. I'm pretty careful when adjusting backlash, just didn't know I could over do it with teeth.
Old 10-12-2008, 05:26 AM   #4
Trader Rating: 21 (100%+)
P = Pitch
so...
and
Seem reasonable?
Try: http://www.rcracing.com/Gear_Ratio_Program_1100.cfm
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 10-12-2008, 07:44 AM   #5
Originally Posted by lidebt2 View Post
I was using that to find and chart my initial ratios. That is one nice program. The only thing it didn't have was the gear radius. I bought the right spurs and pinions to get my ratios, but ended up short distance wise. The spur and pinion almost made contact. Finding the pinions I need is going to be the hard part.
Old 10-12-2008, 09:35 AM   #6
Foxxrocket's Avatar
The only time I really need to use math is when I need to find my FDR. I gear by motor temperature. If I hit in the range of 160-170F then I'm geared right where I want to be.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 10-12-2008, 06:24 PM   #7
48P there are 48 teeth per inch, straight line not diameter or radius.
64P = 64 teeth per 1 inch.
Tim
got2bqik is offline   Reply With Quote
Old 10-13-2008, 07:37 AM   #8
Tim
Wrong.
http://www.robotgames.net/Resources/Gears/gears.htm
Diametral Pitch
Diametral Pitch (or just "Pitch") P = Number of teeth / Pitch Diameter.
The Pitch Diameter Circle goes to approximately half way up the height of the teeth.
Common (diametral) pitches are 12 (big teeth), 24, 32, 48, 64 (fine teeth).
Knowing the pitch diameter is very useful. To figure out how far apart the shafts of two gears should be, add the pitch radius of the first gear with the pitch radius of the second gear.
Old 11-01-2008, 11:22 AM   #9
HoaRC's Avatar
just look at the chart.. it has almost every rc car model you need
http://spreadsheets.google.com/pub?k...jA7nLsQ7N2eRfg
Share your RC gearing setups at [URL="http://rcgearing.com"]
[FONT="Lucida Sans Unicode"][SIZE="4"][COLOR="RoyalBlue"]RC[/COLOR][COLOR="Magenta"]Gearing[/COLOR][COLOR="RoyalBlue"].com[/COLOR][/SIZE][/FONT][/URL]
[URL="http://www.rctech.net/forum/chat-lounge/255446-rctech-ad-models-vote-your-favorite-model.html"]Vote for your favorite rc girl! [/URL]
HoaRC is offline   Reply With Quote
Old 11-01-2008, 12:17 PM   #10
razzor's Avatar
http://www.rctech.net/forum/electric...alculator.html
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Team Associated TC4 Kenshin Electric On-Road 15366 Today 10:16 PM
1/12 forum ovalnator Electric On-Road 46188 Today 08:58 PM
Sydney Model Autosports Inc [smaracing.org] The Ideas Man Australian Racing 25433 Today 05:42 PM
Team Magic E4 Thread gansei Electric On-Road 4124 02-07-2017 02:09 PM
Pro 4 Still Competitive? Twism86 Electric On-Road 45 05-11-2009 07:40 AM
Prairie Knights Classic CorallyBQuiK Minnesota and North/South Dakota Racing 337 09-19-2007 05:31 PM
