Old 10-11-2008, 07:29 PM   #1
blade072's Avatar
Trader Rating: 98 (100%+)
Default excel spring rates in lbs
hello just wanting to know where i can find or has anyone worked out the lb rating for excel springs....
thankyou
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 10-11-2008, 07:50 PM   #2
thankyou
I have two other charts but they will not upload.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 10-11-2008, 07:57 PM   #3
vabroom's Avatar
Go to "file" then "save a copy", the program will tell you that you cannot make changes to the document unless you have an acrobat pro version. Click OK then select the folder you want to save to.
vabroom is offline   Reply With Quote
Old 10-26-2008, 05:19 PM   #4
No Excel springs on that chart, can you upload the other charts, or just list the Excel ones?
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Hot Bodies Cyclone Frank McKinney Electric On-Road 19762 07-26-2017 11:42 PM
Cebu RC Car Racing Club jpn Manila Racers 14147 05-27-2016 10:01 PM
Losi XXX-S TSR6 Electric On-Road 14329 01-26-2015 08:59 PM
SPRING RATES and set up help HAKYLIKESRDAD Electric Off-Road 22 05-05-2008 01:07 PM
Help..... Spring Rates WopArse Oval, Larger Scales and More 1 03-19-2007 01:54 AM
