Old 09-22-2003, 10:32 AM   #1
Send a message via ICQ to lawndoggie Send a message via Yahoo to lawndoggie
Default Battery Problems
Hi,
I am new to the hobby.
Just recently got the CDC charger to charge my batteries.
I got myself 3 packs of cheapie team mind 3000 NiMh batteries.
The first time I tried to charge one of them, I selected 5A, the CDC charger showed over 12V internal battery voltage and shut off!!! How can a 6 batteries 7.2V battery pack has 12 V of voltage!!??
So I tried to charge my 5 cells 750 NiMh at 0.5A, again my CDC charger showed a over 7V even before the charge!! 5 cells!! SHouldn't it be 6 volts?? BTW, I notice large IR measurement on the batteries from the CDC readout.
Can someone tell me what I am doing wrong?
lawndoggie is offline   Reply With Quote
Old 09-22-2003, 10:38 AM   #2
JohnA's Avatar
With the CDC you need to tell it how many cells you are trying to charge in the set-up. Sound like you are using a program for an incorrect number of cells??? something to check.
JohnA is offline   Reply With Quote
Old 09-22-2003, 10:58 AM   #3
I did select the number of cells... =(
Old 09-22-2003, 11:22 AM   #4
popsracer's Avatar
lawndoggie;
The final voltage of any pack will be considerably higher than 1.2v times the # of cells.
I find that my 5 cell nitro packs end around 7.5+ when they're done.
For 6 cell packs, the final voltage depends alot on the Internal Resistance of the Pack and what type of Cell is being charged. With lower quality cells having a much higher final voltage when peaked.
popsracer is offline   Reply With Quote
Old 09-22-2003, 12:30 PM   #5
hmm all my batteries seem to be running very high on voltage, just charged another 6 pack. Got it up to 11.5V!!!!
And now I am charging my TX pack, its getting to 11.75V and it just started charging!! Also the 2 fans on the CDC chargers are not spinning!! Is there something wrong with the charger?
ALso, when I get a new pack of batteries, should I discharge it before my first charge? Othereise, how do I know how full or empty is the pack?
Old 09-22-2003, 01:50 PM   #6
audiaudi's Avatar
Send a message via ICQ to audiaudi Send a message via MSN to audiaudi
Where do you often play you car?? (this is a alternative question... See I m from HK as well... and see if I know you..)
usually, a output voltage of the charger on most recent GP3300 will be arround 8.9V, some of them will be lower. The main reason for the high output voltage is the high IR (resistence), most caused by some dead cells (what kinda 3000 cells you've got?? Sanyo or Panasonic? where did you got them??). Sometimes one dead cell in a pack will make the charger's output voltage go over 9.5V... But 11V+ is not a usually case... are you sure it is the output voltage or input voltage of the charger??
Have you check if the program is for Nimh or else??
A whole new pack of batteries need to discharge before charge it. In most case, we'll cycle the batteries (discharge -> charge -> discharge) before really start to use it. This action will stablize the condition of the pack.
Well come to PM me for any local question.
https://www.facebook.com/aldusdesign
Trying very hard to jump back into RC with CRC Xti-wc.
audiaudi is offline   Reply With Quote
BATTERY PROBLEMS!! HELP!! TH691 Electric Off-Road 27 05-09-2007 04:54 PM
battery problems XXXracer Racing Forum 0 06-30-2006 03:42 PM
battery problems, need help!!! plz rcorvette Electric On-Road 5 01-04-2006 08:22 PM
Battery Problems foaley77 Australian Racing 22 12-20-2004 03:02 PM
Battery Problems! murfy Australian Racing 4 01-14-2004 04:49 AM
