lipo based sedan >
lipo based sedan
lipo based sedan
Old 10-06-2008, 10:51 AM
bigemike's Avatar
Trader Rating: 36 (100%+)
Default lipo based sedan
Are there any new sedans in the works, something that is being built around the lipo. It seems that the losi is the only one close.
bigemike is offline
Old 10-06-2008, 10:16 PM
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
dont forget the Team Magic E4RS and FS
Marcos.J is offline
Old 10-07-2008, 03:42 AM
Drifting101's Avatar
I think most newer cars on the market were design with lipo in the back of the mind like Mi3 can exept a 5000 mak so can the TRF416 and there are lipo conversions on the market for such cars as TRF415 (exept t2008 that top deck is LOOOOOOW J/K)
Drifting101 is offline
Old 10-07-2008, 09:30 AM
I make a steel plate that locks in the chassis under the lipo that equals the
weight of a 4200 nickel metal.
JD
JDRAWE is offline
Old 10-07-2008, 09:43 AM
heretic's Avatar
I would suggest to wait for the next concept from kyosho... Since they bought Orion, i seems plausible that the car will be dedicated to lipo. Isn't it ?
heretic is offline
Old 10-07-2008, 10:10 AM
bigemike's Avatar
that is what I am thinking, I have two tc5's right now, but I was just wondering what was stirring in the rumer mill, lol
bigemike is offline
Old 10-07-2008, 11:01 AM
Adam?'s Avatar
How about an updated FK04? :-)
Adam? is offline
Old 10-08-2008, 12:52 AM
Also there is a company that gets cars and totally redesign the top deck bottoms deck to allow MASSIVE lipos
I think its called "TOKO"
Old 10-10-2008, 05:57 PM
Easiest way to 'update' a standard TC chassis for lipo would be to extend the chassis on the battery side all the way out almost to the body and set the lipo out as far from the center of the car as possible. Much like oval pan cars have been doing for a long time. With this setup, you wouldn't need to add 7.5 oz of lead to balance the car side to side. Corally has already come out with a retaining plate for the Phi that shifts the lipos out from under the top deck so you can use 5000+ mAh lipos, and make it easier to balance the car. http://www.corallyusa.com/istar.asp?a=6&id=SRC79863!SRC
Stealth_RT is offline
Old 10-11-2008, 08:24 AM
Super Moderator
Marcos.J's Avatar
yes they did but hanging the weight off the side of the car is not the best way to balance the car.
Marcos.J is offline
Old 10-11-2008, 11:32 AM
ricker96's Avatar
being a RDX PHI owner with the new lipo tray i have to say the car is very balanced, well designed, and still just as fast.
it just shifts the rear of the pack outward away from the top deck and actually help to balance the weight of the motor hanging out of the other side of the car.
xray could do the same, their just slow with new products
ricker96 is offline
Old 10-11-2008, 11:33 AM
it's not? i always thought if you had lighter weight on one side of the center line it would need to be farther from the center line to equal heavier weight on the other side that is closer to the center line.
mass x distance = mass x distance
HenBeav is offline
Old 10-11-2008, 11:40 AM
adamge's Avatar
As The Dude says, "Well, that's just like, your opinion, man." Disguising it as fact to promote your financial interest is a good move, though.
adamge is offline
Old 10-11-2008, 01:55 PM
J@UNE's Avatar
Does taping a lipo on the side (T2, TC5...) affect chassis flex? NIMH did flex with the chassis.
J@UNE is offline
Old 10-11-2008, 03:38 PM
Ferrarimk13's Avatar
the team magic is best suited for the moment, because the losi doesnt exactly fit all lipos with ease. Its well weighted for the lipo in the center.
Ferrarimk13 is offline
