Old 09-21-2003, 03:25 PM   #1
pro3racer's Avatar
Default intellipeak
i just got a duratrax intellipeak charger(pulse), the regular one, and it's a easy-bake-oven. I want to install a computer fan on top of it, how do i do it, it would be cool if i could hook it up to the motherboard, but who cares, how do i hook the fan up? any one know?
pro3racer is offline   Reply With Quote
Old 09-21-2003, 06:44 PM   #2
BuddhaTech's Avatar
I'd just put a long set of leads on a fan and have it seperate. You can use it for cooling your charger or motor or anything else. If you do want to hard-mount the fan to the charger then the wiring is pretty easy. Just hook it up to the input side of your D/C or if you're using the AC then find on the board where the output of the transformer is (probably the same place that your 12V input is at). You may want to put a switch in line as well as you might get tired of the fan going all of the time when you're not charging.
Mike Evans
____________________________________
Buddha Tech Race Services ~ Build-Prep-Tune
buddhatechraceservices @ gmail . com
BuddhaTech is offline   Reply With Quote
Old 09-22-2003, 03:42 PM   #3
pro3racer's Avatar
Default ?
does this charger charge 3300's, i can't remember, it has adjustable voltage, but could it read it(and can it charge nimhs(cuz most 3300's are nimhs)
Old 11-08-2003, 06:10 PM   #4
pro3racer's Avatar
i found my old thread, and have one more general ???, on my charger it says that nihms should only be charged at 3 amps on it. Can i charge with more amps than it says, or will it damage my charger or battery.
Old 11-08-2003, 06:33 PM   #5
pro3racer's Avatar
anybody???
Old 11-08-2003, 07:13 PM   #6
Regional Moderator
disaster999's Avatar
Originally posted by pro3racer
anybody???
who listens to them? all the manufacture of chargers tells you to charge nimh at 3amps or something like that...but who does it? the matchers uses 6amps to charge their batteries! so dont worry!
and for the fan, is there a fan installed in the first place or its broken or not powerful enough and you wanna change it? what i did was get those really small 3mm fan that used to cool motors...those are really powerful and will cool down your charger! find a place that you could mount them inside. you could go to excess-solutions.com and check out their fans..they have a ton of fans..but you have to buy at least 25 bucks from their website!
disaster999 is offline   Reply With Quote
Old 11-08-2003, 07:17 PM   #7
pro3racer's Avatar
my charger didn't have a fan, but i did mount one, it does the cooling job, i just wanted to know if it was okay, especially for my charger, to charge the 3300 at more than 3 amps.
Intellipeak Ice Motoxpro Electric Off-Road 3 06-09-2008 10:08 PM
ICE Duratrax Intellipeak Andrew Barr Australia For Sale/Trade 1 06-20-2007 02:04 AM
DuraTrax IntelliPeak ICE Formula1fan R/C Items: For Sale/Trade 0 03-14-2007 10:29 PM
Duratrax IntelliPeak ICE gearless Electric On-Road 1 01-12-2005 01:29 AM
Intellipeak Charger volav R/C Items: For Sale/Trade 1 03-29-2004 02:43 PM
