Old 09-20-2003, 10:53 PM   #1
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
Default SSG & Old School Carbon Fiber
just wondering whats the diffrence besides looks??
im planning/ thinking about getting this for my 414mII i know its suppose to handel a bit better because the battery holders are closer to the center but what else?
Calvin Ng is offline   Reply With Quote
Old 09-21-2003, 12:49 AM   #2
Super Moderator
Grizzbob's Avatar
It's mainly just the bling bling, though I've heard that the SSG coating may help prevent the carbon fiber plate from becoming brittle over time(supposedly, the UV rays in sunlight makes that stuff go brittle eventually). But it will have NO impact on a car's performance(unless it's a bit different than a stock chassis, like say moving the battery slots closer to the center).....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 09-21-2003, 08:36 AM   #3
R/C Tech Founder
R/C Tech Charter Subscriber
Just make sure that you sand down the edges of the chassis with a fine sandpaper and seal them with CA glue. With that treatment, your SSG chassis will last a long time.
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 09-21-2003, 09:23 AM   #4
Registered User
Calvin Ng's Avatar
im just gonna stick with normal carbon fiber
does this sanding and CA method work with normal carbon fiber
what kinda grit are you looking at when sanding down the edges and which kinda of CA is best??? thick thin or medium
Old 09-21-2003, 12:51 PM   #5
R/C Tech Founder
It will work (and is recommended) for any woven chassis plate, SSG or not. SSG (silver surface graphite) is just a decorative material used to plate the top and bottom surface. If you look at the material from the sides, you will see that it is a standard woven graphite material.
I just did a chassis last night, using 3M "very fine" sandpaper (anything that is 100 grit or finer will work) and medium CA glue. The medium glue is a bit more "runny" so it is easier to spread, but also takes longer to dry and may end up on the top/bottom of the chassis plate.
Sealing the chassis in this manner will also help prevent against electrical shorts, since you are blocking the conductivity of the material.
Old 09-21-2003, 05:13 PM   #6
Registered User
Calvin Ng's Avatar
so you mean you ca the whole chassis
at the last part in your quote it sounds like electricy only passes through the edges.............
Old 09-21-2003, 05:49 PM   #7
BuddhaTech's Avatar
calvin,
Yes, you should do the entire chassis. Not the top or bottom (horizontal surfaces) just the edges. This includes any cutouts for cells and any other cut out bigger than dime. This is done mainly to help prevent the layers of the chassis from de-laminating during an impact. Remember to slightly champfer the edges of the cell slots so that there is no sharp point to rub on the cell. Using CA on the battery slots can also prevent the shrink wrap on the cells from wearing through. This could lead to a shorted cell(s) as carbon fiber is conductive.
Mike Evans
____________________________________
Buddha Tech Race Services ~ Build-Prep-Tune
buddhatechraceservices @ gmail . com
BuddhaTech is offline   Reply With Quote
Old 09-21-2003, 05:50 PM   #8
Registered User
Calvin Ng's Avatar
any way to prevnt the ca from running on the surface of the chassis?
Old 09-21-2003, 06:13 PM   #9
BuddhaTech's Avatar
calvin,
Just use a small amount at a time and try to spread it out evenly. You can use a q-tipp but it needs to stay wet otherwise it will harden up and leave little rough spots. You'll also have rig up something to let you hang the chassis up. Don't put it down like I did once. I ended up with bitts of pit towel all over the edges...not so smooth !
Mike Evans
Old 09-21-2003, 08:43 PM   #10
Kenneth Tan's Avatar
Apply CA with the help of Q-tips! Just be prepared to use a number of them as CA will harden the Q-tips in no time...
Kenneth Tan is offline   Reply With Quote
Old 09-21-2003, 09:11 PM   #11
howard hudson's Avatar
click here and all your questions will be answered
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline   Reply With Quote
Old 09-21-2003, 09:12 PM   #12
Registered User
Calvin Ng's Avatar
i just finished the ca the dripped to the side i just used acetone and cleaned it off nooo problem
thanx you guyz
Old 09-21-2003, 09:21 PM   #13
BuddhaTech's Avatar
K Tan,
That's the way I've sealled every carbon fiber chassis for 20 years! I've never used mor than 2 or 3 per chassis. Maybe it's just all the practice...
Mike Evans
Old 09-21-2003, 09:34 PM   #14
Yup. Just the practice. Or maybe my hands were just shivering when handling megabuck pieces of carbon chassis...
Old 09-21-2003, 09:57 PM   #15
Post
FYI all the new colored Graphite chassis' that are out or are coming out are all flash...
The down side is that a colored chassis that is the same thickness as a standard black graphite chassis will FLEX more. The coloring affect is actually a thin layer of chemically treated fiberglass, thus taking away a top and bottom layer of graphite (stiffness). The only way to make an equal chassis is to make the colored chassis thicker thus also heavier. Coolness and flash do not make you go faster....
ECHOLogic is offline   Reply With Quote
carbon fiber look? Nitro Herb Painting, Designs, Graphics and Photography 11 12-28-2007 07:33 PM
looking for some Carbon Fiber Scott8ight Nitro Off-Road 1 09-17-2007 04:55 PM
carbon fiber i_got_m8_4_$85 Electric On-Road 14 04-08-2006 06:36 PM
carbon fiber dakrat Painting, Designs, Graphics and Photography 4 05-06-2005 08:50 PM
Carbon Fiber? SPC Racing Electric On-Road 17 02-26-2004 06:00 PM
