Old 03-15-2012, 03:47 PM   #316
Modified23's Avatar
Originally Posted by SerpentCT4S View Post
Great find!
I am curious about the Traxxas wide hexes he is using. Does anyone know what part # those are?
If I had to take a guess, they look like they are off a Slash Front (2wd). I'm glad to see this Thread regaining speed! How do the most of you guys set your front and rear diffs? I was told to loosen up the diff untill one tire goes forward and one goes backward. The way I have the rear set now is that they both go in the same direction when spun. This goes for the front as well. I'm only running a Tekin 17.5 with a little timing with the slipper clutch option.
Speed=Good. Lightpost=Bad
Modified23 is offline   Reply With Quote
Old 03-15-2012, 05:25 PM   #317
Theibault's Avatar
As far as diffs go, after years of RC and racing, I've developed a "feel" for a diff. I guess not too loose and not "notchy" or too tight. Wish I could quantify it.
Theibault is offline   Reply With Quote
Old 03-15-2012, 06:47 PM   #318
Modified23's Avatar
Well from tightening down, how many turns out would you say if you had to guess?I've also seen a guy use Traxxas Slipper Pegs to tighten down his diff to act like a locker. That will be going in after my diff balls go south.
Old 03-17-2012, 11:59 AM   #319
Modified23's Avatar
Other than the Tamiya spring kit, what other springs will work on the shocks?
Old 03-18-2012, 07:26 PM   #320
wiscR56's Avatar
Default gear diff?
has anyone tried using a gear diff?
wiscR56 is offline   Reply With Quote
Old 03-18-2012, 08:16 PM   #321
Modified23's Avatar
Do they make one? I would run one if they had it.
Old 03-19-2012, 05:19 PM   #322
wiscR56's Avatar
not sure....
Has anyone attempted to use a gear diff?
Old 03-19-2012, 06:16 PM   #323
Raman's Avatar
Trader Rating: 56 (100%+)
To my knowledge, there are no gear diffs for the DF03. Possible close subs would be the gear diff from M05 / M06, although they're most likely too wide
TRF419X USGT, Roche F1 '16, M06 Pro M Chassis
Raman is offline   Reply With Quote
Old 03-28-2012, 10:13 PM   #324
sneako's Avatar
Default Old post - hope it can be answered
Originally Posted by Sith Lord View Post
Pretty much. Some have the inner body included. Other than that, not much.
DF03RA is basically the Off Road DF03 buggy converted to a road car, so does well on the dirt. TT01 is essentially a beginners on road car, so not so good.
Which kits have the inner body included? Google was no help.
I'm about to pick one of these up. They look cool and I want something to run when I can't get to a track.
The closer I get to buying one, the more questions I will post after looking through this thread a bit more.
AE SC10 - AE B4.1 FT - AE SC10 4X4 FT
Novak - Castle - Futaba
sneako is offline   Reply With Quote
Old 03-29-2012, 08:56 PM   #325
Raman's Avatar
None of them come with an inner body. You'll have to find one online.. they're out of stock at the moment on Tamiyausa.com
Old 03-31-2012, 08:18 AM   #326
doesn't the Lancer evo DF03ra come withthe inner 'dark impact' cover ???
alex_evo is offline   Reply With Quote
Old 03-31-2012, 05:23 PM   #327
angrymelon's Avatar
http://www3.towerhobbies.com/cgi-bin...?&I=LXXPW5&P=7
This shows on the TamiyaUSA site that it includes a Dark Impact inner body.
http://www.tamiyausa.com/product/ite...oduct-id=92203
Hope that helps.
-melon
angrymelon is offline   Reply With Quote
Old 03-31-2012, 05:28 PM   #328
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Forget google - straight to Tamiya.com
Lancer Evo IV - Has the inner cover
Toyota Celica - Has driver figures, so I assume it has the inner cover too. Maybe not though..
Yes
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 03-31-2012, 05:30 PM   #329
Sith Lord's Avatar
I ran across this on a DF03ra search.
http://www.rccrawler.com/forum/non-c...ed-df03ra.html
Can anyone tell me how he got sooo much extra ground clearance?! The front shock tower doesn't look stock, that and he doesn't say what kind it is. I'd love to get that little bit extra! I really didn't feel like joining another RC Forum, so I'm hoping either someone else is a member with a DF and can ask him, or someone actually knows the guy haha! I ended up ordering 2 sets of CVDs (Tamiya#53792) from a place called Tamiya-model.com. Also, what are you guys running for shock pistons and shocks? I almost was thinking about running some AE B4 front shocks all the way around. But, I think they would be much too long.
I'm guessing, but I reckon he has longer shock ends on the bottom to give him longer shocks, and has possible shaved some of the chassis to allow the A-arms to droop further.
Old 03-31-2012, 08:20 PM   #330
SerpentCT4S's Avatar
Trader Rating: 94 (96%+)
Send a message via AIM to SerpentCT4S
I just installed a few upgrades onto my chassis:
-blue aluminum motor plate
-blue aluminum heat sink bars
-blue aluminum steering rod
I also have a set of TRF shocks I might install as well.
What other upgrades should I get?
SerpentCT4S is offline   Reply With Quote
Tamiya DF-03 type tom_chang79 Electric Off-Road 1048 01-17-2016 10:06 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
IMPORTANT: New Product Arrival Alert! (July 2008) rcmart rcMart.com Mega Online R/C Marketplace 55 07-31-2008 12:32 AM
IMPORTANT: New Product Arrival Alert! (June 2008) rcmart rcMart.com Mega Online R/C Marketplace 53 07-16-2008 03:51 AM
