Old 02-13-2012, 09:19 PM   #301
Trader Rating: 49 (100%+)
Originally Posted by Airflow View Post
Aint it bothering that the rear dogbone/cvd are too angled that it chews up the outdrives faster?
Yes, my dogbones end up getting jammed up inside the outdrives quite a bit, causing wear and tear on it, if I don't catch it soon enough. I've tried getting keeping the dogbones from moving much by using fuel tubing inside the outdrives, which helps, but doesn't eliminate the problem entirely. I'm considering the cvd's, but no one's has told me that it helps.
rody63 is offline   Reply With Quote
Old 02-16-2012, 01:38 AM   #302
GlennJapan's Avatar
I just installed the CVDs, "53792 Assembly universal Shaft TT-01-TA04"
These are a perfect drop in replacement and takes up all the slop that the dogbones had. (39mm shaft)
Glenn's Xtreme Radjicon BAKKA PROSHOP
RC Helicopters and CARS
Mt Fuji Japan
GlennJapan is offline   Reply With Quote
Old 02-16-2012, 02:17 PM   #303
Raman's Avatar
Trader Rating: 56 (100%+)
Cvd are a good addition. I have front and rear. They're still in good condition after 3 years of use
TRF419X USGT, Roche F1 '16, M06 Pro M Chassis
Raman is offline   Reply With Quote
Old 03-12-2012, 07:27 AM   #304
SerpentCT4S's Avatar
Trader Rating: 94 (96%+)
Send a message via AIM to SerpentCT4S
Hey guys.
I am running a DF03ra chassis and i want to upgrade my shocks. In the manual, they show part #42102 TRF shocks as an upgrade. Would these work well on the chassis? Are they the same length as the stock shocks? I dont want to lose ride height or ground clearance.
SerpentCT4S is offline   Reply With Quote
Old 03-12-2012, 08:18 PM   #305
Raman's Avatar
Originally Posted by SerpentCT4S View Post
Hey guys.
42102 will work great
Old 03-12-2012, 10:15 PM   #306
Airflow's Avatar
For the long term DF03RA users:
What needs to be upgraded/hopped up/mods ASAP?
What part/s wears out the most?
Can it handle 10.5T and below brushless setups?
Airflow is offline   Reply With Quote
Old 03-13-2012, 07:21 AM   #307
Will it affect my ground clearance or ride height?
Old 03-13-2012, 08:14 PM   #308
Modified23's Avatar
Yeah, I just putted around with mine tonight and from what I've been reading the dogbones are a problem. As soon as I press "reply" I'm off to the interweb super hi-way for some CVD shopping... Also, does anyone run shock limiters? I tried some in the front just putting around and, if you are.. Do yourself a favor and take them out. Fun little car though.
Speed=Good. Lightpost=Bad
Modified23 is offline   Reply With Quote
Old 03-14-2012, 05:53 PM   #309
Modified23's Avatar
I ran across this on a DF03ra search.
http://www.rccrawler.com/forum/non-c...ed-df03ra.html
Can anyone tell me how he got sooo much extra ground clearance?! The front shock tower doesn't look stock, that and he doesn't say what kind it is. I'd love to get that little bit extra! I really didn't feel like joining another RC Forum, so I'm hoping either someone else is a member with a DF and can ask him, or someone actually knows the guy haha! I ended up ordering 2 sets of CVDs (Tamiya#53792) from a place called Tamiya-model.com. Also, what are you guys running for shock pistons and shocks? I almost was thinking about running some AE B4 front shocks all the way around. But, I think they would be much too long.
Old 03-14-2012, 10:10 PM   #310
Raman's Avatar
Depends if want it too or not. You can build the shocks with a spacer inside the damper, either by adding an o-ring under the piston. For the DF03 I didn't bother since it will be offroad
You can also adjust that by the shock end caps.. the plastic pieces you thread on to the bottom of shaft that attach to lower suspension arm. There are two lengths on those, the longer ones will give you greater clearance.
Old 03-14-2012, 10:49 PM   #311
Theibault's Avatar
Just saw this thread. I love my DF-03Ra and I run it about once a month. Here's a really old video I have of mine. It was stock then, running brushless now.
+ YouTube Video
Theibault is offline   Reply With Quote
Old 03-15-2012, 05:24 AM   #312
GlennJapan's Avatar
Had some fun with my DF-03ra today. New paint scheme for all my cars this Year.
Mt Fuji Japan
Old 03-15-2012, 06:22 AM   #313
alien rc's Avatar
Hello guys,
Just discover this thread and I can say, I'm happy to find some people running the df03ra...
To protect my chassis in my dirt's run, I have done this soft protection which is light, easy to put on and off and let the Air flow to cool the ESC...
This is only a prototype at this time but it will be soon ready to run !!!
FB : ALIEN R/C
www.alienracing.fr
alien rc is offline   Reply With Quote
Old 03-15-2012, 07:57 AM   #314
Great find!
I am curious about the Traxxas wide hexes he is using. Does anyone know what part # those are?
Old 03-15-2012, 08:43 AM   #315
Theibault's Avatar
Love it! Nice and bright. I may have to pick up a Lancia body and paint it something bright like this.
Tamiya DF-03 type tom_chang79 Electric Off-Road 1048 01-17-2016 10:06 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
IMPORTANT: New Product Arrival Alert! (July 2008) rcmart rcMart.com Mega Online R/C Marketplace 55 07-31-2008 12:32 AM
IMPORTANT: New Product Arrival Alert! (June 2008) rcmart rcMart.com Mega Online R/C Marketplace 53 07-16-2008 03:51 AM
