Old 03-26-2011, 02:46 PM   #286
Raman's Avatar
Trader Rating: 56 (100%+)
On mine, instead of cutting the tub, I cut into the battery compartment to make esc fit. Im running a havoc 2 S,
So dimensions are different. Worked out quite nicely though.
TRF419X USGT, Roche F1 '16, M06 Pro M Chassis
Raman is offline   Reply With Quote
Old 04-14-2011, 07:44 PM   #287
I picked up the DF-03RA Lancia Delta Integrale Kit today.
I have a spare Hobbywing 13T / 35a combo lying around that I will be slapping in and a Savox SC-0254 digital servo.
I have no idea what to expect but if it goes half as good as the picture on the box looks I will be very happy.
TB-03, M-03, M-04,M-05, TT-01, DF-03ra, TRF201, SCX10, Stampede
tdunster is offline   Reply With Quote
Old 05-10-2011, 04:48 AM   #288
I slapped my DF-03ra together over the weekend. Very simple to build and great fun to drive. Highly recommended.
Add on's included:
Savox SC-0254MG Digital Servo
Tamiya #53925 Slipper Clutch
Hobbywing EZrun 4300kv / 35a Combo
Old 05-12-2011, 02:24 PM   #289
SerpentCT4S's Avatar
Trader Rating: 94 (96%+)
Send a message via AIM to SerpentCT4S
I recently put a new Castle Creations Sidewinder SV2 5700kv system in my DF03. I also got a 2s lipo for it.
I ran it today on the street for a bit. I then decided to finally find a "rally like" spot to drive. I went to the park and ran it in the parking lot. It had some gravel, sand, dirt, etc. It was a blast!!
I use the Dark Impact body under my Subaru body, but I still noticed alot of dust got in. When I got home, i used my air compressor and it looked new again.
Also, would you guys recommend the slipper clutch on my car? What will that do for me?
Here are some pictures.
SerpentCT4S is offline   Reply With Quote
Old 05-13-2011, 05:34 AM   #290
Awesome Subaru Df-03ra
The slipper clutch takes a lot of the load off the drivetrain on high grip surfaces.
In addition the slipper also allows the car to get the power down a lot better on loose surfaces such as gravel and reduces the stress on the drivetrain when you jump/land.
For around $30 and two mins of your time to fit it to the car it's a worthwhile upgrade for anyone running a brushless system in their df-03ra.
Old 05-16-2011, 03:42 PM   #291
I went to my LHS today and they had a DF03 slipper, so I bought it.
I just got done installing it, very quick and easy to do. I tightened the slipper as shown in the diagram, 1mm of the thread showing. Is that just a starting point or is that where it should stay? How will the car drive if its tighter or looser than that?
In my DF03 kit, then gave me a 72t and a 75t spur gear, and the slipper gives you a 82t spur gear. When I built my kit, I put on the 75t spur and a 29t pinion.
Is that good gearing? I mostly run in parking lots and occasionally in dirt.
Thanks for your help!
Old 05-27-2011, 04:23 AM   #292
Arctic Fire's Avatar
Slippers are exactly that, they are designed to slip and ease strain on the drive system. Looser, means more slip. If you are driving brushless on asphalt, loosen the slipper so that the grip of the tires doesn't rip apart your drivetrain. On gravel? I crank mine tighter, but leave a little for strain relief when i hammer the throttle. Just play around with it, it's a very useful tool.
Awesome looking Delta up there! and great pics of the Suuby
What tires are on the Subaru? kit tires? they look awesome...
-If it ain't broke.... break it!
Hummer Stampede, Monster Stampede, Porsche GT2 TT-01E, Mini-Z's
Arctic Fire is offline   Reply With Quote
Old 05-27-2011, 01:26 PM   #293
angrymelon's Avatar
Serpent's Subaru has out of production HPI Pirelli Rally tires. Not only do they look good, they work awesome too.
The kit tires are standard Tamiya Rally Blocks.
-melon
angrymelon is offline   Reply With Quote
Old 05-27-2011, 06:11 PM   #294
-melon
That is correct! Did I buy them from you on here?
I also have another new set, just waiting to pick out a nice set of rally rims for them. Any ideas?
Old 06-16-2011, 09:39 AM   #295
Hi does anyome have any experience with Speed Passion Cirtix Series "Stock Club Race" ESC and Motor Combo (13.5T)
http://www.amainhobbies.com/product_...tor-Combo-135T
Need to know if it will fit in a tamiya df03ra and if any good?
Thanks!
rayrush is offline   Reply With Quote
Old 06-16-2011, 01:07 PM   #296
superspeed's Avatar
Who thinks the TA06 took some design ideas from DF03? Bottom loading for battery pack is pretty slick but TA06 requires to loose few screws in order to install / uninstall the battery pack.
superspeed is offline   Reply With Quote
Old 06-17-2011, 03:29 AM   #297
Is anyone running a t bone front bumper?
Old 02-13-2012, 03:03 PM   #298
GlennJapan's Avatar
I had this box Sitting around for about 5 Months and decided to get her Done, Added a slipper, Tamiya BLS 16T ESC/Motor Combo, With HeatSink Fan for Motor, CArbon Fiber Damper Stay front and rear, Researching a better set of gears, im afraid these white plastic ones will explode... Hopefully i can find a delrin or black type set. Got a SEt of TRF Annodized Shocks will add to it later, Dont know why but this simple kit looks fun to bling out!
Glenn's Xtreme Radjicon BAKKA PROSHOP
RC Helicopters and CARS
Mt Fuji Japan
GlennJapan is offline   Reply With Quote
Old 02-13-2012, 08:08 PM   #299
Raman's Avatar
I have yet to blow any gears on this. With the slipper set to slip, it will protect the tranny. Also make sure you use good lube in the gear boxes. I didn't bling mine too much.. nothing worse then a flip on dirt to scratch those pretty blue anodized pieces...
I did purchase the carbon rear damper and left front stock.. the rear gives adjustability for damper position.. front the car really doesn't need it in my case since its mainly driven on dirt and snow.
Old 02-13-2012, 09:02 PM   #300
Airflow's Avatar
Aint it bothering that the rear dogbone/cvd are too angled that it chews up the outdrives faster?
Airflow is offline   Reply With Quote
Tamiya DF-03 type tom_chang79 Electric Off-Road 1048 01-17-2016 10:06 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
IMPORTANT: New Product Arrival Alert! (July 2008) rcmart rcMart.com Mega Online R/C Marketplace 55 07-31-2008 12:32 AM
IMPORTANT: New Product Arrival Alert! (June 2008) rcmart rcMart.com Mega Online R/C Marketplace 53 07-16-2008 03:51 AM
