Old 11-15-2010, 01:59 PM   #211
SerpentCT4S's Avatar
Trader Rating: 94 (96%+)
Send a message via AIM to SerpentCT4S
Got my DF03RA all built. I just have to paint and finish my body.
I will post pics later!
SerpentCT4S is offline   Reply With Quote
Old 11-15-2010, 07:13 PM   #212
Here is my DF03-RA.
Old 11-21-2010, 10:58 AM   #213
Raman's Avatar
Trader Rating: 56 (100%+)
Hey guys, do any of you have a Lancia DF03-ra? Im in the process of putting a Lancia body that I had left over from tt01 on the DF03. Looks like Tamiya is using different mount holes in the back on the DF03 version.. also the foam bumper looks like it needs to be cut.. my kit was originally the Subaru ..
Any pictures or comments would be appreciated, since the manual is not online
TRF419X USGT, Roche F1 '16, M06 Pro M Chassis
Raman is offline   Reply With Quote
Old 11-22-2010, 07:39 PM   #214
MOTORMAN29's Avatar
Are all the different DF-03ra cars that Tamiya sells the same besides the bodies??
and which is better tt-01e or this one? (for off/on road)
thanks!
MOTORMAN29 is offline   Reply With Quote
Old 11-25-2010, 12:14 AM   #215
Sith Lord's Avatar
Trader Rating: 21 (100%+)
thanks!
Pretty much. Some have the inner body included. Other than that, not much.
DF03RA is basically the Off Road DF03 buggy converted to a road car, so does well on the dirt. TT01 is essentially a beginners on road car, so not so good.
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 11-30-2010, 08:42 PM   #216
Lethal Enforcer's Avatar
Trader Rating: 97 (100%+)
Just got a lancia DF03ra. I really like it.Alota nice features
Axial Scorpion ,Team Associated TC5R , Tamiya M03R, Tamiya RC Onroad.com
2012 TCS Best of show Mini
2012 TCS Best of show TT01
Lethal Enforcer is offline   Reply With Quote
Old 12-07-2010, 06:21 PM   #217
Looking to get universal cvds. Anyone know where I can get them
Old 12-11-2010, 02:13 AM   #218
Trader Rating: 16 (100%+)
Default I got one
http://cgi.ebay.com/Tamiya-TA04-TT-0...#ht_3006wt_907
I just bought one from ebay but I think u can try rcmart out. here
http://www.rcmart.com/catalog/rc-tt0...h=595_744_1292
This is located in USA. I already got CVD for front but I might get another for the back. Not sure yet but here's the website.
http://www.ampdraw.com/product.php?u...roductid=23191
I got so much hop up in my car
Now i'm wondering if I should get Carbon fiber shock towers. Good or bad?
kms7852 is offline   Reply With Quote
Old 12-11-2010, 07:36 AM   #219
Thanks, I figured out that they are the same as a tt01.I found aluminum ones on ebay ,but won't get those,i am sure they would bend. The CF shock towers would be sweet.Are you running a slipper clutch?
Old 12-12-2010, 01:14 AM   #220
Default Yup
What I am worried about Carbon Fibers are that they are very Brittle. It takes a lot of beating for them to "Break" (Snap) but it will happen if the hit is strong enough. Well, Aluminum ones, you're right, it bends. That's what I am worried about. I found out plastic ones are much more Flexible in the way that it will take some beating before it will bend. I know CF's are much higher quality material but why invest so much money if it will SNAP when Plastic parts can be more flexible. Let me know what you think.
I still haven't got my DF-03RA on mail yet. It will probably come on Monday I think. I got it used so it has Slipper Clutch on it. My previous owner says he put 48P 69T SC10 Spur Gear on that slipper clutch set. I am not sure what pinion gear is good for 4600KV castle sidewinder model. I am thinking of 48P 32T or 28T. If anyone can help me out on this, I would appreciate it.
I so far got Aluminum blue main shaft, with both aluminum blue housings.
Blue aluminum lower front and rear suspension arms.
Blue Aluminum front hub carrier.
Blue aluminum steering rod.
Blue Aluminum rear suspension brace.
CVD for front steering
TRF shocks
A dust cover DF03 Dark Impact Body.
I am not sure CVD in the back would help tremendously so I am just keeping stock dogbones for now.
I am considering the CF front and rear towers
Blue Aluminum gear cover (not sure it will fit with slipper kit)
Blue aluminum gear plate (also not sure if it will fit with slipper kit)
Lightweight battery pin (Looks like waste of money though)
Maybe blue aluminum battery cover (only for decoration)
Any other upgrades I should do?
I am not getting front one way or center one way though.
Old 12-12-2010, 07:43 AM   #221
niznai's Avatar
TRF shocks
Aluminium in steering and suspension arms (camber links) is best avoided. It is just a weak spot and it will bend and then snap. The kit steel dealies are much better (mine are still intact after a lot of abuse). Likewise lower suspension arms. The kit plastic is very good and will take any abuse. Liekwise the mainshaft. The kit shaft is very good and the plastic couplers are a lot better than aluminium ones, as they don't wear out.
About shock towers, you're spot on. Plastic is a lot more flexible, but it will last forever, especially if you're not a very good driver. Otherwise, the rear tower is likely to break (big jumps with landings wrong face down = landing on rear shock tower).
The rest is just bling (except for CVDs which are highly recommended both front and rear). Nobody wants to go home early becasue they lost a dogbone when they broke the suspension.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 12-12-2010, 08:24 AM   #222
I definitely want the cvds.The angle the dogbones are at right now ,looks like you would easily loose a bone
Old 12-12-2010, 09:29 AM   #223
Here is a couple of pics of my rally.Gonna race next friday night.The local track has a rally car class.They run 540 motors to help keep it more even
Old 12-12-2010, 11:19 PM   #224
Default Cool
Cool! Nice body! Very nice.
Does it have TRF Shocks? That's what it looks like to me.
What springs do you use? Soft?
Oil shocks?
You have any videos rallying?
By the way, do the rally tires wear out fast? Just wondering.
Old 12-12-2010, 11:29 PM   #225
Default Upgardes
Thanks for your input. I am actually running brushless so I need aluminum shaft and cup for sure. The plastic ones are torn apart after some abuse with brushless. The slipper Clutch was a must and I got that too.
I honestly wanted that bling of Blue aluminum parts so I got the steering and suspension arms in blue aluminum. You are right about bending and all. I am planning on putting the plastic ones first and use that until it breaks or something. For pictures, aluminum ones will do.
Shock towers, you're totally right, I won't go into Carbon Fibers till one of them bend or something. So plastic for now. I am using CVD on front steering and just normal dogbones in the rear. That way, If I loose dogbones in the rear, I have extra from front I can use.
I have 4600KV Castle Sidewinder with slipper clutch installed, SC10 69T 48P gear. Any idea what pinion gear I should use? Thanks!
Tamiya DF-03 type tom_chang79 Electric Off-Road 1048 01-17-2016 10:06 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
IMPORTANT: New Product Arrival Alert! (July 2008) rcmart rcMart.com Mega Online R/C Marketplace 55 07-31-2008 12:32 AM
IMPORTANT: New Product Arrival Alert! (June 2008) rcmart rcMart.com Mega Online R/C Marketplace 53 07-16-2008 03:51 AM
