Old 08-27-2009, 10:44 AM   #136
angrymelon's Avatar
I think my next test is to remove the foam pads completely. First, to just see if the suspension will start to move smoothly. Secondly, to see if the front drive train will stop binding up. I found this while bench testing that if I give the car throttle, and then crank the wheel in either direction it binds and stops the axles from spinning.
I followed the directions very closely, so I'm not sure where I went wrong.
-melon
P.S. Is it just me, or is the drive train of this car extremely noisy?
angrymelon is offline   Reply With Quote
Old 08-27-2009, 02:55 PM   #137
MrLesac's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to MrLesac
in all honesty the best way to fix the problem may just be going to a set of universals. i know a few of the hong kong stores sell them such as RCmart. but im unsure of the quality. i would think anything would be beter than the dogbones though.
Kevin --- Facebook.com/FormulaGraphics---
Exotek
Formula Graphics
MrLesac is offline   Reply With Quote
Old 08-27-2009, 10:41 PM   #138
angrymelon's Avatar
Is there any one online retailer that has the best selection of factory and aftermarket Tamiya parts?
-melon
Old 08-27-2009, 11:05 PM   #139
niznai's Avatar
-melon
Don't. Test on the bench without the pads if you want, make sure there's no real problem elsewhere, but then when everything is fine, put the pads back or you will lose the dogbones.
As I said, you need to find a best compromise by shifting some of the pads' thickness between the outdrive and the axle until you find the point of least binding but the dogbone is still securely in place. Slice the pads in two unequal lengths and try to swap them around until you get the best result.
Don't worry about a bit of binding. Give it a good bootful of a bashing outside and it will loosen up. The pads stop the spinning when there is little spinning force. In normal conditions under throttle, it won't make a significant difference.
About the gears being noisy, lube them up with as much lube as you want and they'll be a bit more silent, but not by much. This is where it counts if you sealed the gboxes. A properly sealed gbox will keep the grease in for longer so the driveline will be quieter and you can put more grease in to begin with so you won't have to open the gbox for a while.
Yes, universals do make a difference on the front, but are not absolutely necessary (Tamiya is sucking you in already). You need 39mm dogbones with DF03 (or similar) axles. I am not aware of a readily available part with the whole assembly. Look it up on ebay.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 08-28-2009, 07:25 AM   #140
MrLesac's Avatar
-melon
Rcmart.com
Rcstation.com
Rcmushroom.com
all out of hongkong all with most the same parts, but some have a few different ones.
Exotek
Formula Graphics
Old 08-28-2009, 10:15 AM   #141
angrymelon's Avatar
I have another rookie question. The manual doesn't specify how tight the diffs should be. I was basically going by feel. What have you found is the best way to determine correct diff tightness?
Thanks!
-melon
Old 09-02-2009, 03:27 AM   #142
Default Caster
Tthe DF-03ra does not have caster right?
And is that nasty angle on the drive shafts only at the short wheelbase version?
Nasty angle at the rear.
MatsNorway is offline   Reply With Quote
Old 09-02-2009, 04:40 PM   #143
mcdogboy's Avatar
re:rear axles, yeah, I think so.
Got the celica DF03RA sitting on my desk now, plan is to build over the weekend.
I wonder if the hobbywing 5.5T will fit
mcdogboy is offline   Reply With Quote
Old 09-02-2009, 04:46 PM   #144
mcdogboy's Avatar
Got unis and slipper ready to go in, any other parts I should look at beefing up from the get go?
Old 09-02-2009, 07:21 PM   #145
fat500's Avatar
Trader Rating: 29 (100%+)
Slipper is a must have in this car for any motor under 17.5 / 27 turn. I have not had a single issue with mine I use ceramic grease in the gearbox and it is actually very quiet. ck your pinion spur mesh too.
fat500 is offline   Reply With Quote
Old 09-02-2009, 07:28 PM   #146
mcdogboy's Avatar
Cheers mate, what sort of ceramic grease?
Probably go with whatever's in the box to start with, cuz I won't have time to get anything else pre build, but I habitually strip/clean/rebuild my cars.
Old 09-06-2009, 04:08 AM   #147
Does the Mamba Max motor fit in this? I heard you have to use 5mm spacers, at least on the Dark Impact you had to.
Can anyone fill me in, and if you have to use spacers, is there a suggested source or will I have to make my own using multiple washers?
Nautilus is offline   Reply With Quote
Old 09-06-2009, 05:19 PM   #148
mcdogboy's Avatar
All built and tested with a silver can, brilliant fun in the dirt.
Looks like it's gonna be a challenge to got a the hobbywing 5.5T in, but will know more when I have a fiddle tonight.
Old 09-07-2009, 01:48 AM   #149
mcdogboy's Avatar
I'm having dramas with the steering arm rubbing on the prop shaft, you can see how close it is in the quoted pic, mines closer.
Any ideas?
Old 09-07-2009, 02:08 AM   #150
niznai's Avatar
Any ideas?
Yes, mine did that too. Check the plastic joint spins true and if it does, leave it alone and shave the steering arm gently to give some clearance. If the joint wobbles, swap with rear joint, check again and decide. Tamiya offers aluminium joint cups which should fix the issue, but I didn't bother and just shaved a tiny bit of the steering arm.
Team Greasy Weasel
Tamiya DF-03 type tom_chang79 Electric Off-Road 1048 01-17-2016 10:06 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
IMPORTANT: New Product Arrival Alert! (July 2008) rcmart rcMart.com Mega Online R/C Marketplace 55 07-31-2008 12:32 AM
IMPORTANT: New Product Arrival Alert! (June 2008) rcmart rcMart.com Mega Online R/C Marketplace 53 07-16-2008 03:51 AM
