Old 09-19-2003, 10:24 PM   #1
yodace's Avatar
R/C Tech Charter Subscriber
Default Fantom Lathe Problems
Today I tried turn a stock motor. But the armture would not stay in the end stops. It would pop out and fly forward.
I am using the stock belts that came with the Fantom lathe.
The lathe worked when I was turning my mod arm. I installed the switch on the positive like manual side.
Please help.
yodace is offline   Reply With Quote
Old 09-19-2003, 10:31 PM   #2
if the belt that holds the arm down tight? It should be preaty tight, I don't have a fantom so I don't know if you can change it but may be you but is bad? I've had a bit that was so bad the arm would bounce its self off, or you could be spining the arm to fast withthe slave motor? Thats all i could tthink of
teamAE is offline   Reply With Quote
Old 09-19-2003, 10:37 PM   #3
SlobbaTech's Avatar
If you have the nylon screw too tight against the armature the arm will bounce a little or you have the slave motor spinning the wrong direction. The armature should be spinning away from the bit, clockwise if you are looking at the right/slave motor side of the lathe.
SlobbaTech is offline   Reply With Quote
Old 09-19-2003, 10:46 PM   #4
yodace's Avatar
The belts that came with lathe are sort of lose. I don't know the size of the belt. I did install the switch on the positive side like the manual said.
Old 09-19-2003, 10:50 PM   #5
yodace's Avatar
the arm is being thrown forward and looks to me like the piece that drive the belt is going forward.
Old 09-19-2003, 10:51 PM   #6
yodace's Avatar
Post picture of how your lathe are set up please.
Old 09-19-2003, 10:54 PM   #7
Moderator
Speedo's Avatar
The belt that comes with the Fantom is perfect. You're problem is you don't have the end screws set correctly, you'll have to change the setting when changing from a stock arm to a mod arm.
Speedo is offline   Reply With Quote
Old 09-20-2003, 08:08 AM   #8
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Could the shaft of the arm be bent? I thought he said he could cut a mod arm fine but just had the problem with a stock arm.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 09-20-2003, 09:26 AM   #9
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
I had the same problem with my Fantom I got three weeks ago. I think the newer lathes are shipped with a o ring that is too long. With a mod motor the o ring rides on the stacks. With a stock motor the oring rides on the wire wraps (its hard to make it stay on the stacks) and this makes it looser on the motor and it lets the arm bounce when you start to cut it. I picked up a smaller oring at the hardware store and havent had a problem since then.
Hope this helps
eric anderson
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 09-21-2003, 09:28 AM   #10
Also are you triing to remove too much material with 1 pass?? This will cause the arm to "chatter" or actually come off of the v-blocks.....
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 09-21-2003, 09:39 AM   #11
yodace's Avatar
I got a new heavier belt and its working better. It is pretty loud when I am cutting. I wondering if its just the surface, I am cutting on.
Old 09-21-2003, 10:06 AM   #12
Does you lathe have rubber feet under it for it to set on or is it aluminum on wood??? If the lathe didn't come with any then goto Wal-mart, or you local home supply store (lowes'/ Home Depot) and pick some self hadhesive rubber feet for furnature, get rubber and not plastic!!
Or is it the arm still bouncing a little in the lathe..... if so don't make such deep cuts!!!
Old 09-21-2003, 02:22 PM   #13
Team EAM
Impactplayer the depth of the cut didnt make a difference on mine...the oring was simply too loose. The smaller oring fixed mine 100%.
ea
Contact Us
Old 09-21-2003, 02:55 PM   #14
SlobbaTech's Avatar
OK, now I know what's wrong. You need to align the alum pulley that bolts onto the slave motor shaft so that when the o-ring is on it's pulling on the stock motor stacks and not the wire so that it retains it's tension. You might need to take the slave motor out to be able to access that set screw but I have mine set so that if you have the wrench in the set screw it hits or almost hits the alum base and cannot be pushed any further towards the motor. If it's still too loose even though it's pulling off of the stacks then just take your current o-ring with you to hardware store and buy a new one that is little shorter or thicker/stronger for like $0.50.
Fantom Lathe wallstreet R/C Items: For Sale/Trade 14 08-15-2007 06:47 PM
Thunder Zapper Fantom Dyno Fantom Lathe Spring dyno Brush Butcher Fussy full monte HenBeav R/C Items: For Sale/Trade 8 12-06-2006 11:38 AM
FANTOM LATHE/GENERAL LATHE QUESTIONS J.Gonzalez Electric On-Road 30 03-23-2006 10:46 AM
Fantom Dyno Problems NickDawg Electric On-Road 5 09-28-2004 10:42 PM
Like New Fantom com lathe $300 FL_Racer R/C Items: For Sale/Trade 4 05-23-2004 01:07 PM
