Old 09-29-2008, 11:07 AM   #1
teamcarpetfire's Avatar
Default 13.5 xxx-s gearing
i ordered a novak xbr/ex 13.5 sytem and i wanted to now what gearing to use with it.
teamcarpetfire is offline   Reply With Quote
Old 09-29-2008, 07:17 PM   #2
imjonah's Avatar
Default from novak site
13.5 = 4.5 from
http://www.teamnovak.com/tech_info/b...r_gearing.html
These gearings should be used as a starting point, but the motor and ESC temperatures should always be used to determine the final gearing.
Neither the motor (with sintered rotor) nor the ESC should be hotter than 160 to 175° F after a five minute run. If either temperature is higher than 160 to 175° F, the gearing should be lowered until both the ESC and the motor (with the sintered rotor) are under this temperature.
The cooler the ESC runs, the better the performance of the system.
if you were to go with 5.0 gear ratio
then you would have 128 spur 46 pinion, 118/43 108/40 90/33, 88/32
imjonah is offline   Reply With Quote
Old 09-29-2008, 07:25 PM   #3
Trader Rating: 23 (100%+)
if you ant to know how to find your correct pinion for the correct fdr's listen to this,
first find your internal gear ratio. once you have found that with a 13.5 motor you should run a 4.7-4.5 ish. now to do so you do this math.
(this is just an example) 88/44x2.0=4.5. (i didnt do the math just an example!)
spur (divided by) pinion (times internal gear ratio)=fdr
Mike Adamec
TEAM HACK-HACK OR BE HACKED
Trackside Hobbies
not home is offline   Reply With Quote
Old 09-30-2008, 01:13 PM   #4
i did the math and if i use a 86 tooth spur and a 35 tooth pinion it will give me a fdr very close to 4.5 i am going to get a fan for the esc so it will run cooler
Old 09-30-2008, 02:32 PM   #5
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
4.5 FDR is for the sintered motors. He ordered an EX system that has the bonded rotor.
My suggestion. Start 2-3 teeth higher than with a good brushed stock and move up from there, keeping an eye on temps. Try to aim for 150-180 degree temps.
Syber Serulean is offline   Reply With Quote
Old 09-30-2008, 04:53 PM   #6
i have the sintered rotor upgrade comeing with it so the 86/35 gearing will be good
XXX-CR Thread Matt Howard Electric Off-Road 5778 04-03-2017 01:45 PM
Team Losi XXX-T CR, What are yours opinions ? Jason Pelletier Electric Off-Road 2231 01-19-2012 10:16 PM
Long Island Raceway, NY...Forum JamesSchlick Electric Off-Road 11792 06-25-2009 10:21 AM
2008 NSW EP Off Road State Titles gillottine Australian Racing 179 09-24-2008 05:39 PM
xxx-t gtb 3.5 Gearing sparkplug1288j Electric Off-Road 16 12-14-2007 06:01 PM
13.5 novak brushless gearing chris c Electric Off-Road 35 12-05-2007 03:18 AM
