Old 09-28-2008, 12:49 PM   #1
BM1
Default Losi Speed-T Differential Question
I already ate up the differential gear in my Losi Speed-T. Is the Losi 1/10 Desert Truck differential a direct bolt-in replacement for my stocker? It looks a lot stronger.
BM1 is offline   Reply With Quote
Old 09-28-2008, 03:36 PM   #2
rocketron's Avatar
Trader Rating: 16 (100%+)
to iinstall the gear diff you need the gear diff tranmission case and the complete gear diff assy. all the other components are interchangable.
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 09-28-2008, 08:48 PM   #3
geeunit1014's Avatar
Lets think about this for a minute - the speed t is desinged to handle up to a 3s lipo with the BL motor, and open gear diffs like the DT's dont really handle much more than the stock motors well.. if your looking for a diff instead of a solid axle (what the ST is supposed to be) id just get diff balls and make it a ball diff, which will hold up better than the gear diff.
geeunit1014 is offline   Reply With Quote
Old 09-28-2008, 09:22 PM   #4
rocketron's Avatar
actually the ball diff typically does not last very long. especially if running high speed wheelie popping runs. the diff that comes in the speed-t must be oil free and very tight, and can last a fairly long time.
the gear diff in the desert truck will handle the speed-t power. BUT and here is the BUT if you are trying to do speed runs with the Speed-T using the gear diff it is a handful to drive at speed.
Old 09-29-2008, 03:40 PM   #5
BM1
Default Update
I called Losi today regarding the differential failures on these Speed-Ts, and they said I need to run a 17-tooth pinion gear instead of the stock 20-tooth gear to fix the differential failure issues. They said you need to drop a few tooth sizes on the pinion when running 3-Cell LiPo in on-road situations, so they instructed me to get the Losi 17-tooth pinion which I did.
I'll let you folks know how it turns out when I get it and install it.
Old 09-29-2008, 06:09 PM   #6
rocketron's Avatar
Was the diff gear black that broke? If so the new white ones are much better. made sure the pads are clean of any lubricant and use a NEW diff nut. The diff nuts are alum and fatigue after rebuild.
Old 09-29-2008, 06:19 PM   #7
BM1
Yes the diff that broke was the stock black one. I ordered 2 of the new white differentials. I'm hoping those are stronger than the stock black one.
I also ordered a couple new spur gears as well as the new 17T pinion gear. Hopefully the new differential in conjunction with the 17T pinion will solve the differential issues.
I looked through the book and didn't see a differential nut. All I see in the exploded view is a bolt that runs through the middle. Am I just missing it?
Old 09-30-2008, 06:44 PM   #8
BM1
UPDATE:
I rebuilt the differential tonight using one of the new white differential gears from Losi. I also installed a 17T pinion to replace the stock 20T and a new 88T spur gear.
I took it out on the street and ripped on it using a 3S 11.1 LiPo pack and the "medium" ESC setting to start out. Everything was working beautifully and it was ripping! I decided to bump it up to the "High" ESC setting and let 'er rip. Again everything was awesome with no grinding or issues. The thing pulls harder down low than it did before. It either blows the tires off or sits on the wheelie bar! So far I'm happy with this new combo.
For all you Speed-T folks out there tired of eating up differentials, I highly recommend going this route.
Old 10-16-2008, 01:20 PM   #9
Hi guys new to this thread, I just bought one of these rockets here in Australia, it has the new white diff but still chewed it up in the first 10min. My local hobby store has supplied me a new 1 free of charge and gave me a 18t pinion but I havent tried it yet, but with the new bottom end performance you are getting on the 17t I might go that way or even as lowas 16t.
Mick
Micko11 is offline   Reply With Quote
Old 10-21-2008, 02:54 AM   #10
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
Anyone know what the part number is for this white diff?
Drift_Buggy is offline   Reply With Quote
Old 10-21-2008, 10:25 AM   #11
rocketron's Avatar
LOSA2945 with pads
Old 10-25-2008, 02:29 PM   #12
y2kgtp's Avatar
Trader Rating: 35 (100%+)
Send a message via AIM to y2kgtp Send a message via Yahoo to y2kgtp
Anyone convert the Speed-T to Stadium truck racer? All I see is a ball diff and some different tires to make it competitive on the track. The shocks are about 3/4" shorter in length as well....but either play with shock mounting locations, or swap for some XXX-T shocks if it becomes a real issue.
y2kgtp is offline   Reply With Quote
Old 11-27-2008, 10:34 AM   #13
Do you guys know if the LOSA3036 will fit to replace the diff gear? It seems like its the same as part LOSA2945 but without the locker/pads. Thanks
phresko is offline   Reply With Quote
Old 11-27-2008, 11:17 AM   #14
y2kgtp's Avatar
I would think so....did you burn yours up?
"Yes my car is technically illegal, but still its either just as fast or slower than any other car on the track so whats the issue with it being illegal?"
Old 11-27-2008, 11:46 AM   #15
Chill_Will's Avatar
Trader Rating: 32 (100%+)
Also the shock towers are different. You won't get the same handling with it as the XXXT unless you changed them and the body.
Chill_Will is offline   Reply With Quote
Losi Constant Velocity Drive (LCD) vs MIP CVD John Stranahan Electric On-Road 263 01-24-2010 12:51 PM
