Old 09-28-2008, 09:28 AM   #1
DJ
Default ANYTHING BUT BRUSHLESS MOTOR
Hi can somebody educate me regarding "Motor Timing" I want to purchase a sensored brushless motor, but in any answerd i've got they always say "adjust the motor timing"
How can i do that?
any suggestion site with step by step procedure you can link?
DJ is offline   Reply With Quote
Old 09-28-2008, 09:41 AM   #2
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
loosen the 3 screws at the endbell and twist the end cap. to the left is advancing the timing, to the right is retarding the timing. use a timing jig to determin how many degrees to the left or right you're adjusting the timing
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 09-30-2008, 09:28 AM   #3
DJ
What will be the reaction of my motor if i increase the "advancing" timing?
same as changing the degree to "retarding" what will be the effect?
Old 09-30-2008, 09:56 AM   #4
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
The more timing you have the more RPM's you will have and the opposite when turning the timing down. Be aware if you advance the timing on your motor it will get hotter faster.
With that said, advancing the timing isn't always needed. It is a tuning option that can be used, but if you don't really know how to take advantage of it you don't need to use it. There are other ways to go faster.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 09-30-2008, 07:02 PM   #5
DJ
What is the natural/ok temp of a motor after running for brush and brushless?
Old 10-01-2008, 01:45 AM   #6
Drifting101's Avatar
Brushless after a 5 minute run should be about 160-175 degrees F according to novak
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 10-01-2008, 06:33 AM   #7
DJ
Thanks for all the answerd
I just wondering whether to get a brushed 19t motor or brushless 10.5 motor
thats the reason im gathering info before to jump to another boat.
Old 10-01-2008, 06:52 AM   #8
todd8603's Avatar
Default good work
IMHO Brushless because;
1) levels the playing field far more wiht these motors as tuning yields very minimal differences as compared to brushed.
2) far less maintenance
3) no fade as motor gets warmer
4) not sure how many more runs per motor but I think it is likely 2-3x (or more)the number of runs out of properly maintained brushed.
5)the move away from brushed is happneing very fast making much of the brushed stuff worthless in resale.
todd8603 is offline   Reply With Quote
Old 10-01-2008, 04:48 PM   #9
Also longer runtimes so your batt wont fade as much by the end of the run
Schumacher
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 06:16 AM
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 06:51 PM
MRT Brushless ESC or8ital Electric On-Road 42 12-06-2008 10:53 AM
On Road's Health Check Up. mrrcguy Electric On-Road 19 07-29-2008 09:29 PM
RC Pro Series Richmond,VA Onroad Race June 28-29 JetMD Racing Forum 40 06-30-2008 09:03 AM
brushless motors where are they at fasterdanu Australian Racing 434 06-13-2005 07:48 PM
Orion to ship brushless motor KerryG Electric On-Road 40 12-09-2001 06:26 AM
