Old 09-26-2008, 07:55 AM   #1
stehl's Avatar
Send a message via AIM to stehl
Default TC5 Problem
Hey there,
I just got a Tc5 and Got it all setup. I do have one problem tho, Its my first belt car and am not sure if its normal or not. When I give it throttle and dont turn the wheels it runs smoothly. Yet when I give it throttle and turn the wheels the car binds and starts to vibrate/chatter horrible.(only on throttle. IT free wheels fine) Is this Normal for all belt cars Or is something outta adjustment.
Thoughts and suggestions Are appreciated.
Thanks,
Josh
-PowerLine RC Driver
-Tekno
stehl is offline   Reply With Quote
Old 09-26-2008, 08:51 AM   #2
Check your end points on your steering, sounds like it might be trying to go past the mechanical stopping point and causing it to bind and vibrate.
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 09-26-2008, 09:13 AM   #3
Trader Rating: 38 (100%+)
it's normal that is what cvds do. You can reduce your EPA as appropriate. It will be fine on the track
or8ital is offline   Reply With Quote
Old 09-26-2008, 09:48 AM   #4
Trader Rating: 21 (100%+)
Default ...........
Also,Check the bearing holders..make sure they're positioned properly/the same on both sides of the diff.M
lotus1 is offline   Reply With Quote
Old 09-26-2008, 10:15 AM   #5
THeGame's Avatar
Send a message via AIM to THeGame
This could also be a problem if it was Tom's old car...
Team Gravity Rc - G's R/C Raceway and Hobbies - Waldorf RC - TheTrack
THeGame is offline   Reply With Quote
Old 09-26-2008, 10:45 AM   #6
Rick Hohwart's Avatar
Originally Posted by stehl View Post
Hey there,
Thanks,
Josh
The front CVA can bind and cause the problems you describe. Remove the CVA and turn them in your hands and it should be free even at maximum angle. If not, replace them.
Rick Hohwart is offline   Reply With Quote
Old 09-26-2008, 01:20 PM   #7
stehl's Avatar
Haha IT is his. I will check everything mentioned.
-Tekno
Old 09-27-2008, 01:35 PM   #8
stehl's Avatar
Hey I dialed the epa down and it solved it. It was trying to turn past the max angle of the cvd
-Tekno
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 08:58 AM
CRC Battle Axe, GenXPro 10, 1/10th pan, Brushless, Lipo,4c, Road, Oval,TipsandTricks John Stranahan Electric On-Road 1776 03-01-2016 01:18 PM
Team Associated B44. Race, Tune and Modify Shadows Electric Off-Road 6171 08-09-2015 08:32 AM
Trains and Lanes Onroad Racing Summer 08 edition t_laible Racing Forum 2280 06-09-2010 02:41 PM
Cheese City Xtreme RC carpet 08-09 yuk17bandit Wisconsin & Illinois Racing 779 10-09-2009 11:32 PM
Need Help Deciding, TC5 OR XRAY? capturefx Electric On-Road 26 07-16-2009 12:35 AM
